Hi,i export my 5.1 audio (edited by premiere) in WAV 5.1 then I use Aften (WAV to AC3 Encoder) to encode in AC3 format.
The result is a file with some more seconds at the end of the file with strange noise...
Do you know what is the problem and a way to encode WAV to AC3 without problems?
What command line do you use for Aften (or does the GUI show you the command line)? Not that I'm an expert, but my best guess would maybe try using "-readtoeof 1"
You'll find the explanation for it here.
Or alternatively, try a different GUI to see if the problem goes away. There's a few which use Aften for AC3 encoding. MeGUI's audio encoding section does (no need to encode video too). TAudioConverter probably does (I don't use it myself). If not Aften, it encodes to AC3 anyway. -
"-readtoeof 1" doesn't fix the problemI tried MeGUI. It works only if i select "Preferred decoder: Direct Show"
I tried also TAudioConverter an it works
But neither have many options... -
IIRC aften's DRC metadata isn't implemented correctly (it's not spec compliant, and doesn't work like certified Dolby AC3 encoders) and therefore it's not recommended to be used . I don't think it has been fixed or addressed
I think TAudioConverter uses ffmpeg in the backend, and dialnorm can be applied through the commandline -dialnorm
Trying to demux a canon .mov file into either .wav or .ac3
By Onceler2 in forum AudioReplies: 2Last Post: 2nd Jun 2013, 07:59 -
ImagoMPEG-Muxer: Beeping noise, bad audio problem. .M2V & .AC3
By Mamimi in forum Newbie / General discussionsReplies: 6Last Post: 27th Sep 2012, 07:30 -
Hissing noise in AC3 File
By koberulz in forum AudioReplies: 4Last Post: 19th Apr 2011, 11:33 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 16:26 -
Encoding wav file to ac3 specification
By gouletjo in forum Authoring (DVD)Replies: 1Last Post: 15th Feb 2010, 23:40
