I am brand new here and pretty new to capturing video as well. Basically the background is that for some projects I've recently began recording streaming videos. Up until today I never had any problems (only been doing this a week). However, I made a number of recordings today and when I went to review the files all of the video recorded flawlessly but the files play no audio. I checked repeatedly and my recorder indicated that it was picking up audio. However, each file has the same issue. Great video, no audio. I browsed some threads here and everyone said to provide mediainfo so I am attaching it below:
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 163 MiB
Duration : 2h 0mn
Overall bit rate : 190 Kbps
Writing application : Lavf53.4.0
Video
Format : AVC
Format profile : High@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Duration : 2h 0mn
Bit rate : 182 Kbps
Width : 620 pixels
Height : 384 pixels
Display aspect ratio : 16:10
Frame rate mode : Variable
Frame rate : 26.777 fps
Minimum frame rate : 1.429 fps
Maximum frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.029
Stream size : 156 MiB (96%)
Writing library : x264 core 125 r2209 68dfb7b
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-4 / threads=2 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=crf / mbtree=0 / crf=28.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 0mn
Bit rate mode : Variable
Bit rate : 3 100 bps
Maximum bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 2.66 MiB (2%)
Now I will fully admit, I have next to very little clue of what most of this means. I have tried playing the file in Quicktime and VLC, but still no audio. Should I be encouraged that it does have audio information in the mediainfo? I saw some threads that said if there was no audio information then there simply was no audio. Are there any suggestions on how to possibly "fix" and recover the audio. I don't really have the option to simply re-record the video since today's projects involved live streaming video - which up to this point I still had no issues. Any help would be greatly appreciated!
Try open the video/audio with an audio editor like goldwave or audacity(add the ffmpeg plugin to open video directly).
Or extract the audio with mymp4boxgui first and then open it in the audio editor.
It should look something like this if it contains audio, http://upload.wikimedia.org/wikipedia/commons/7/74/Pantallazo-Audacity.png -
The audio bit rate looks a little low 3K? I am not an expert but I would expect 128k? for mp4?
It helps to solve these problems if people supply details like what is my recorder ? then we can help find the issue.my recorder
This is becoming a tend here in the forum of late and a few are starting to become impatient.
2 hour video with those bitrate's, size ... and oh my ... variable video frame rate ... Id burn it.
Ok you might want to read this post
Down below is about virtualdub.
You'll probably need to install AAC ACM Codec (win 7, right click bat file to run with admin privileges or it wont install) and x264 VfW.
Once loaded set audio to full processing mode ... then audio conversion, set to 44.1, 16bit, stereo ... then audio compression to none (pcm) ... then File > save wav.
See if the audio plays ... for 2 hoursLast edited by Bjs; 3rd Dec 2013 at 02:06. Reason: Thinking ... lack of coffee
iTunes audio out of sync (Video File: Handbrake Mp4 -- PAL 50 FPS)
By Toonman in forum Video ConversionReplies: 3Last Post: 8th Oct 2013, 05:55 -
Let ffmpeg show used audio and video codec inside a (.mp4) video file?
By pxstein in forum Newbie / General discussionsReplies: 1Last Post: 26th Jan 2013, 02:47 -
mp4 file not playing in an application that supports mp4 files
By mindstormer in forum Video ConversionReplies: 2Last Post: 1st Jan 2013, 21:17 -
how to enhance audio in an mp4 / avi video file
By antinikhil in forum Video ConversionReplies: 6Last Post: 15th Jul 2012, 01:00 -
How to add an mp3 audio file onto an mp4 video file?
By Tintin11 in forum RestorationReplies: 4Last Post: 4th Nov 2010, 06:01
