Im trying to load a video in virtualdub, but get the error message "failed to register FLVsplitter.ax error code 0x80070005"
,please can you advise me how to register successfully ?
Which OS is it?
You could open a CMD prompt as administrator and issue the regsvr32 command manually.
For example,
regsvr32 \my-tools\codecs\flvsplitter.ax << assuming that is where the splitter actually resides.
TMPGEnc Authoring works 4 - Access is Denied (Error code 0x80070005)
By The Roo in forum Newbie / General discussionsReplies: 3Last Post: 17th Mar 2021, 17:34 -
Process exits with error code, Indexing error: Audio decoding error (MeGUI)
By JokerX in forum Video ConversionReplies: 7Last Post: 18th May 2012, 17:18 -
FLVSplitter / FFDshow FLV resolution anomaly
By davexnet in forum Video ConversionReplies: 9Last Post: 15th Nov 2010, 23:22 -
testing thecoalman's suggestion of [code=php] test [/code] ... FAILED!
By vhelp in forum TestReplies: 1Last Post: 10th Jun 2009, 01:15 -
Unable to Run FLVSplitter
By ks47 in forum ComputerReplies: 4Last Post: 22nd May 2009, 23:25
