I read another post and saw that it was a while ago now, but that post did not help me. In my case the 'RipBot264 Encoding Client' window does not even open, as is the video tutorial that comes with the download folder...
Follow my log:
C:\>"C:\Users\Joao\Desktop\RipBot264v1.17.4\tools\ avs2yuv\avs2yuv.exe" "C:\Temp\RipBot264temp\job1\job1.avs" -o - | "C:\Users\Joao\Desktop\RipBot264v1.17.4\tools\x264 \x264_x64.exe" --crf 20 --stats "C:\Temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --force-cfr --min-keyint 24 --keyint 240 --frames 126370 --sar 1:1 --level 4.0 --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --b-pyramid none --stdin y4m --output "C:\Temp\RipBot264temp\video.264" -
error: failed to load avisynth.dll
x264 [error]: could not open input file `-'
C:\>"C:\Users\Joao\Desktop\RipBot264v1.17.4\tools\mkvtoolnix\mkvmerge.exe" -o "C:\Users\Joao\Desktop\Project X.mkv" --compression 0:none --title "Project X" --default-duration 0:24000/1001fps "C:\Temp\RipBot264temp\video.264" --compression 0:none --language 0:eng --sync 0:0 "C:\Temp\RipBot264temp\job1\1_audio_English.ac 3" --forced-track 0:yes --language 0: por -s 0 -D -A "C:\Temp\RipBot264temp\job1\2_subtitles_Portuguese .srt" --chapters "C:\Temp\RipBot264temp\job1\chapters.txt"
mkvmerge v6.0.0 ('Coming Up For Air') built on Jan 20 2013 12:38:35
Error: The file 'C:\Temp\RipBot264temp\video.264' has unknown type. Please have a look at the supported file types ('mkvmerge --list-types') and contact the author Moritz Bunkus <moritz@bunkus.org> if your file type is supported but not recognized properly.
Elapsed Time: 00h:00m:01s
Please, help me!
Several possibilities.
Has Ripbot ever worked? If not, damaged files?
Have you tried any other input files? A corrupted input file (Your video) can cause RipBot to close.
Make sure you have the correct versions of the support files/programs that RipBot requires. Especially AVIsynth.
If all else fails, uninstall the program and all the support files and reinstall. Ripbot uses quite a few files/programs internally and one of them may be damaged/corrupt.
One of our other members may see something in your log files that I missed.
And welcome to our forums. -
RipBot downloaded today, so it never worked for me.
Have tried with another file, an MP4.
I suppose if the RipBot is opening without pop up window saying that's missing programs, as happened to me on account of JAVA when I ran the program for the 1st time, I think all programs are properly installed.
What do I do? -
Thanks to the two who helped me, I managed to reduce the bitrate of a movie to perfection. Great program!
need with RIPBOT264
By hector1980 in forum Blu-ray RippingReplies: 2Last Post: 31st Mar 2013, 11:43 -
Robin Hood Prince of Thieves problems with finishing
By asiafan in forum Blu-ray RippingReplies: 6Last Post: 26th Jan 2013, 08:25 -
Ripbot264 1.17
By rapunzel in forum Newbie / General discussionsReplies: 7Last Post: 6th Jan 2012, 17:05 -
how does Ripbot264 think ... ?
By zero7404 in forum Blu-ray RippingReplies: 42Last Post: 3rd Oct 2011, 20:23 -
Ripbot264 Question
By titot4u in forum Blu-ray RippingReplies: 10Last Post: 8th Jan 2010, 17:17
