Hi everyone
I've been trying to convert avi files to mpeg using virtual dub 2 extract the audio first then TMPEG to cut the movies in 2
But I've been loosing quality each time . The curves kind of loose their softness and I get squarry ugly pictures. I thought it had to do with converting from 1:1 VGA to 3/4 but when I kept the aspect ratio at 1:1 It didn't solve the problem
Anyone knows what's triggering this ?? or if there is a way to bypass it somehow ??
Source bitrate/resolution/codec?
Destination bitrate/resolution/codec?As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Source bitrate/aspect ratio /size/ frame rate :
1150 bit/s
1:1 VGA
640x272
25fs
Destination bitrate/aspect ratio / frame rate :
1150
4/3
320x204
23.9fs -
i might be asking stupid questions here, but any help is very very veryyyy appreciated
how do I convert .divx files to .avi without loss in quality
By Onceler2 in forum Video ConversionReplies: 2Last Post: 17th Oct 2009, 11:03 -
OpenDivx4 to Divx without quality loss?
By bizzybody in forum Video ConversionReplies: 2Last Post: 28th Mar 2009, 14:21 -
avi to MPEG quality loss?
By prcole18 in forum Video ConversionReplies: 1Last Post: 7th Oct 2008, 11:38 -
Quality loss in converting from DIVX to XVID?
By fwtong in forum DVD RippingReplies: 7Last Post: 25th Jan 2008, 18:37 -
Divx to DVD and quality loss
By marioval in forum Authoring (DVD)Replies: 5Last Post: 21st Jan 2008, 17:05
