  1. hello!'m a new member! have a big problem! hope I helped!
    I was given a TV PANASONIC TX P42C3E .... I can not see the video of the sd card because I always say: "video format not supported" I have more than 10 video formats to flv avi!, and I can not see this on TV!
    help me and I explained step by step what should I do?
    thanks
    I found this
    VIERA Image Viewer yes (AVCHD/SD-VIDEO/JPEG/MP3/AAC playback)
    But it doesn't say what formats. I would try convert to avi divx/xvid with for example freemake video converter, choose to avi and select the avi xvid mp3 preset. You could also try convert to mp4 in same converter.
  3. I already tried to convert these formats! but nothing happens!
    I always say the video format is not valid!
    I would then give up and buy a separate player like wd live player, popcorn player etc.
  5. Mentally Deficient Mr.Delusional's Avatar
    Aug 2012
    The ghetto of Emerald City
    I looked up the manual for your television and this is what your television supports video wise.
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Not many converters can output avchd mts. You could try video to video converter.
  7. Note how the chart Mr.Delusional posted refers to folder structure. What it appears to want/accept is the files created by panasonic cameras within their proper metadata folders.
    http://en.wikipedia.org/wiki/AVCHD
    http://en.wikipedia.org/wiki/MOD_and_TOD
  8. thank you! |! but I want to transfer the videos to the sd directly from the PC ..! not the camera ...!
    please help me?, and I explained step by step what should I do?
    I have already downloaded the program "MULTI AVCHD"! but do not know how to use it or what I should do ... thanks
