Okay, so I've burnt many a 16x DVD-R DVD's in the past, with very quick times, and minimum coasters. Approximately 4 minutes/disc.
I've also burn quite a few DVD+DL discs, with approximately 20minutes/disc.
Unfortunately, i've got about 50 DVD's to burn, and you can see the problem.
My question is, why such a huge difference? My average write speeds on a DVD+DL is about 8 KiB/s.
Is this normal?
Here's the Imgburn log..
Please help me decipher what this means.
Short answer = Yes
Log is normal
Better answer = Get a duplication tower to speed up the process. -
Increase of "speed" doesnt decrease the time necessary the same way....
*** Now that you have read me, do some other things. *** -
Oy, CMC MAG D03. I know them well.
I used quite a few back when I did Blu-Ray backups to DVD+R_DLs (BD9). For unimportant backups that could be done over any time, in other words. And I did do lots of them over again.
Reliability is poor, to be kind. Thinking back now, they did best at the lowest rated speed, but that was never any better than 80% success rate, IIRC. They *are* inexpensive though, which is about the best that can be said for them. I went through several spindles of 50 each.
No double-layer DVD media is worth using but Verbatims, IMO. That's the consensus here, and it's true. You eventually tire of doing discs over again and verifying/scanning them.Pull! Bang! Darn! -
Unfortunately, i couldn't get my hands on Verbatims at the time, and I needed them ASAP...
I totally understand the gamble with this media..
From a spindle pack of 50, I've lost 4. My bigger concern is player compatibility with these cheapos..
BTW, my supplier is only selling Verbatim DVD+R DL (inkjet hub printables) in packets of 10..
IS there some sort of conspiracy going around? I can't seem to buy or find them locally anymore..
A general newbie question handbreak vs Makemkv
By Ryan Charles in forum Newbie / General discussionsReplies: 1Last Post: 5th May 2012, 11:35 -
burn MP4 AVC H.264 to play on general DVD player
By surfers in forum Newbie / General discussionsReplies: 2Last Post: 5th Jan 2011, 07:44 -
General Cable question
By acrumbacker in forum Newbie / General discussionsReplies: 5Last Post: 1st Jan 2011, 21:00 -
can someone answer a general aspect ration question to me
By consumerx in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 10:58 -
General question about blu ray files and HD
By True Colors in forum Newbie / General discussionsReplies: 8Last Post: 22nd Dec 2009, 17:23
