Hello to everyone
I Have a DVD with menu and chapters, but menu doesnt' work
This is the list of the files inside VIDEO_TS folder:
VIDEO_TS.BUP
VIDEO_TS.IFO
VTS_01_0.BUP
VTS_01_0.IFO
VTS_01_01.VOB
VTS_02_0.BUP
VTS_03_0.IFO
VTS_03_01.VOB
VTS_04_0.BUP
VTS_04_0.IFO
VTS_04_1.VOB
VTS_05_0.BUP
VTS_05_0.IFO
VTS_05_1.VOB
VTS_05_2.VOB
When I open a .ifo file the menu appears only for 1 second and then skips to the next menu until the beginning of the video,so I cannot use it!
I must say that only VTS_5_1 and 5_2 are the video, while the previous files are only menu, but maybe the DVD needs more files missing for open correctly the menu.
There's a way to know if there are missing files? And how I can fix these ''holes'' without re-create the dvd?
Thanks in advance
Results 1 to 10 of 10
Check 'What is DVD' on the left of this reply.
There are many missing files. And you will have to recreate the dvd. -
I contacted the author of this dvd
He tell me that He doesn't create well the menu, so it doesn't work
There's a way to cut off the menu without re-create the dvd in order to keep only video and chapters ?? -
It deletes the menu? I want only to delete menu without re-create the dvd
I can take the vobs and re-author it, But I don't want to do that -
That's exactly what you want to do - have the DVD play properly, either removing the menu or skipping the menu. Nothing gets reencoded. Anyway, DVDShrink in reauthor mode is one way (out of dozens) and will remove the menu and reauthor just the movie.
http://www.dvdshrink.info/re-author.phpLast edited by manono; 21st Nov 2013 at 17:30.
The problem with this disk is that the menu is simply not there. DVDShrink can hardly remove something that is not there in the first place.
But the file structure is crazy. Just what do the vob files before 5 do ?. I hardly think this disk was created in software. No software is that bad. A dvd-recorder where the user simply did not know what he was doing and the unit screwed up the result? -
It doesn't matter as he said the actual video he wants is in the VTS_05_1.VOB and VTS_05_2.VOB. Maybe Shrink won't open it. Never know until you try. I wouldn't use it anyway, but suggested it because it's easy. Me, I'd demux and use Muxman. Or PGCEdit if it'll open the DVD, and then change/create the commands so it goes straight to the main video.
I used the reauthor mode of dvd shrink
It does exactly what I want: now there are only movie and chapters, just like the first dvd, and the good thing is that the two VOBS of the movie have the same size of the original ones.
thank you a lot
LG Blu-Ray player disc menu button doesn't go to the menu
By brassplyer in forum DVD & Blu-ray PlayersReplies: 6Last Post: 5th Dec 2012, 23:48 -
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
ffmpeg doesn't work at all
By Paulo2009 in forum ffmpegX general discussionReplies: 27Last Post: 4th Aug 2009, 23:55 -
My still menu w/ music doesn't work right in some players
By Radish in forum Authoring (DVD)Replies: 9Last Post: 26th Mar 2009, 19:19 -
Subrip doesn't work
By mtc in forum SubtitleReplies: 7Last Post: 1st Feb 2009, 21:54
