  1. I'm trying to view a video feed from a wireless camera on a smartphone (iPhone or Android), how would I go about setting this up? I've heard remote desktop or HLS feed work, but I don't know how to set up the HLS feed and I'm still hesitant on using a remote desktop app. I don't want to do the remote desktop, as this will be used on the go, and I don't want to have to have a desktop or laptop with me.
    Please give more information about the wireless camera.
    You might have to go through a computer like camera -> computer with a streamer like vlc -> iphone/android.
  3. All I can give you is the link to where I got the camera from, and that it didn't come with any software. http://www.007spycamera.com/Wireless-Video-Camera-Color-Ultra-Mini-Camera-With-2.4ghz-...etail-769.html
  4. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    You likely need to install the android app in order to control the camera.
  5. Ok, sorry about the really late reply, but how would I get the video feed to the computer? Either I am doing something wrong here, or a RCA to VGA cord isn't going to work. That or I don't know how to get the feed to VLC. Any help getting this to work would be greatly appreciated. Also, racer-x, the camera didn't come with a user manuel, and the website doesn't have any mention of software, for a computer or android.
    Feb 2004
    Australia
    After looking at the camera this is the wrong unit ... the way you wanted to do things you should have bought a wireless ip camera.
    This is one example
    This is what I use as wireless ... they can be hard wired in problematic positions.
    The camera you have will require connecting to a capture card on a pc ... from here you can use vlc to stream it from the pc using a wireless network router as the wireless connection end point for the phone to use and view.
