I came on here about a week ago or so asking about ways to convert movie files to the video_ts files so I can make a dvd out of them, and dvd styler and avstodvd were recommended. I tried avstodvd and it does a good job but there's a small problem. the backgrounds for the home screen of the dvd are limited. as a matter of fact I think there's only one and it looks gray colored. is there a way to get more backgrounds? or do you think dvd styler is the only way to do that?
Yes there are ways to use other backgrounds for AVStoDVD menus.
You can create a custom template. Open AVStoDVD Help. Find the page for "DVD Menu Wizard - Template" in the Index tab. it explains how to create a custom template.
You can also replace the default background in the Menu Editor. Open the editor and select Mode->Edit. Select Background from the DVD Menu Items list, then choose the background you want to substitute via the Item Graphic Properties->Image. -
yeah I stumbled on to that not long after I posted the above thread. problem now is I can download the file but I can't open it as it is a .7z extension, and I have no idea how to open a .7z extension.
AVStoDVD question re encoding - or not.
By sambat in forum Video ConversionReplies: 7Last Post: 18th Aug 2013, 16:46 -
Ye Olde vhs letterbox to 16:9 question - where is it in avstodvd for 16:9?
By yoda313 in forum Video ConversionReplies: 6Last Post: 4th Oct 2010, 15:43 -
AVSTODVD: Avisynth script edit - colorspace conversion question...
By JRM75 in forum Video ConversionReplies: 2Last Post: 26th Jul 2010, 19:43 -
AVStoDVD
By Dooker in forum Authoring (DVD)Replies: 10Last Post: 24th Aug 2009, 08:29 -
AVStoDVD!
By Milardo in forum Authoring (DVD)Replies: 12Last Post: 15th Feb 2009, 06:01
