Results 1 to 11 of 11
  1. Hy,
    I would like to know what's the best Hi-Re paper for printing paper sleeves/covers for cd and dvd.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    HP Brochure paper.....if you can find it.
  3. Also, Epson Premium Presentation paper is excellent. A little easier to find than the HP.
    --dES
    "You can observe a lot by watching." - Yogi Bera
    http://www.areturningadultstudent.com
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I use Epson: http://www.newegg.com/Product/Product.aspx?Item=N82E16828103049
    Note you will need legal size for DVD covers.
    Google is your Friend
  5. Thanks for the replies
    I've bought HP Brochure paper through Ebay. I got HP professioanl paper 180 instead. It's the same thing right?
    Anyway the paper looks good but I may be looking for something a bit more thick/rigid.
  6. Member dragonkeeper's Avatar
    Jul 2003
    Not necessarily, if you have a photo printer or any printer that does edge to edge printing, your covers will come out just fine. Go to Office Depot, Staples, Office Max or similar you can find a heavy weight stock paper in a bright white or photo finish.
    Murphy's law taught me everything I know.
  7. Member p_l's Avatar
    Montreal, Canada
    Yup, a standard DVD cover measures 184mm (7.25") by 273mm (10.75"). Standard letter paper is 8½" by 11", so it should fit if your printer does borderless printing.
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Pull an insert out of store-bought DVD. Is it thick or rigid?
  9. Hey, It must work with external slevees like this.
  10. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    The back-side of the heavy photo paper I buy would scratch the crap out of a CD or DVD if you are talking about making your own SLEEVES.
  11. Originally Posted by hech54 View Post
    That's not a problem. I'll use extra plastic caps.
    I recently bought Epson Premium Semigloss Paper (250g/m). It sucks, it doesn't bend.
    It must also be foldable.
