While opening VirtualDub, VD detects an improper VBR audio encoding in the source AVI file (laymens terms, the audio is off form the video) Like in the Kong Fu movies. VD suggests to decompress the entire audio stream(which I've done) to an uncompressed WAV. File. Then to recompress w/ a constant bitrate encoder. Bitrate 190.4+/- 22.3kbps.
My questions are: what do I use to recompress the WAV file and where sould I put that file? I'm using TMPGE to encode the video. I will also use that Wav file to encode the Divx to a SVCD.
Any help would be appreciate.
Thank you,
LAne
Results 1 to 1 of 1
Variable Bitrate or Constant Bitrate?
By i am x in forum Video ConversionReplies: 3Last Post: 12th Feb 2010, 08:49 -
How to reduce bitrate of Xvid without recompressing or faster than this?
By dzsoul in forum Video ConversionReplies: 2Last Post: 18th Jan 2010, 06:59 -
Both constant bitrate and two press bitrate are the same,right?
By tendra in forum Video ConversionReplies: 2Last Post: 1st Nov 2009, 05:35 -
I need a constant bitrate
By alexv305 in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2008, 07:38 -
Variable and Constant bitrate ??
By VEBouto in forum Newbie / General discussionsReplies: 4Last Post: 18th Oct 2007, 00:56
