hi friends
how can i change/convert video frame rate (fps)
for example i want to change 25.000 to 23.976
is there any softwar for this ?
please help me
thanks
Results 1 to 27 of 27
Why? Is the video interlaced? Pulldown applied? Film source or video source? Or was it originally 24FPS PAL film and speeded up to play at 25FPS? Or was it originally NTSC film and modified to play at 25FPS?
And welcome.Last edited by sanlyn; 19th Mar 2014 at 13:32.
Your question is much more complex than you realize. The answer depends on what container and codecs are used, the properties of the video (interlaced, telecined or progressive), whether you need to keep the audio in sync, and what you plan to play the video with.
There is many software solutions, form very simple to very sophisticated but none of them provide perfect frame rate conversion - imperfections are highly related to the video itself.
For example http://compression.ru/video/frame_rate_conversion/index_en_frcn.html something like this can be interesting for you - as a free software i can recommend Avisynth + MVTools but this combination (free) have some limitations...
http://avisynth.org.ru/mvtools/mvtools.html#examples
http://avisynth.org.ru/mvtools/mvtools2.html#examples
Generally frame rate conversion is most expensive (time and money) part for the typical video flow... -
That's a beginning, but it's only a small part of the story. Is it MPEG from a retail DVD? Is it a DVD that you or someone made at home or recorded off cable TV? Do yourself and us a favor: download the free MediaInfo utility and open the MPEG file with it. It will give lots of info about the nature and structure of the MPEG. You can post that information here as text. Please do not take a huge screen capture of the report and post. You can use MediaInfo's "Text" view under the "View" menu option, and select/copy/and paste that report into a text file. You can either post the text file here or copy/paste the text itself into a post.
Please provide a sample, since you seem incapable of telling us exactly what you have. 'MPEG' is a step in the right direction, but not the complete answer.
And are you planning on and/or willing to reencode it, or must this be done without reencoding. -
clear : i want software that convert dvd and vcd's fps from 25.000 to 23.976
or software that can supports most of video formats for converting frame rate
mkv too ...Last edited by fps; 19th Nov 2013 at 14:38.
What do you want to do this for, sending home movies to friends overseas, additional editing...? In many cases a framerate conversion is damaging and unnecessary.
i want it and it's very necessary for me please help me to find software that converts frame rate movies please
Again, you're not supplying nearly enough information and you have no idea what you're asking. For example, there are no DVDs that output 23.976fps; not PAL, not NTSC. However, if you're interested in converting from PAL to NTSC, try Avs2DVD.
Just guessing here, but if you're from India or thereabouts your DVDs (and some VCDs) are often so messed up that a straight PAL->NTSC conversion sometimes isn't enough to give even acceptable quality.
This should be handled on a case-by-case basis and, again, a sample of one you're interested in converting would be helpful. 10 seconds or so is enough. -
TFM Audio Tool can convert audio from 25 to 23.96. TSmuxer can change the video frame rate to 23.96(24000/1001) Add your audio from TFM to TSmuxer.
Without a sample of your video, there's no effective way to answer your question in detail. You need to know how your video is structured (telecine, interlaced, blended frames, plain interlace, etc.). We still don't know why 23.976 is required. There are ways to solve the problem, but you have to know what you're doing and I doubt there's a simple one-button answer. Video restoral from its encoded playback rates are restored to their original film rates all the time; it's not an unusual request. But more needs to be known about the nature of the original video. To add to the problem, 23.976 is not a standard playback rate for MPEG/BD/AVCHD video disc. Without more info from you, there's not much anyone can do with any certainty.
As you constantly refusing to provide all data required to solve your problem i will limit myself to general recommendation:
http://sox.sourceforge.net/sox.html#EFFECTS
alternatively audio can be resampled and new sample rate can be set to arbitrary value to extend or shorten audio length (it will change pitch).tempo [−q] [−m|−s|−l] factor [segment [search [overlap]]]
Change the audio playback speed but not its pitch. This effect uses the WSOLA algorithm. The audio is chopped up into segments which are then shifted in the time domain and overlapped (cross-faded) at points where their waveforms are most similar as determined by measurement of ‘least squares’.
By default, linear searches are used to find the best overlapping points. If the optional −q parameter is given, tree searches are used instead. This makes the effect work more quickly, but the result may not sound as good. However, if you must improve the processing speed, this generally reduces the sound quality less than reducing the search or overlap values.
The −m option is used to optimize default values of segment, search and overlap for music processing.
The −s option is used to optimize default values of segment, search and overlap for speech processing.
The −l option is used to optimize default values of segment, search and overlap for ‘linear’ processing that tends to cause more noticeable distortion but may be useful when factor is close to 1.
If −m, −s, or −l is specified, the default value of segment will be calculated based on factor, while default search and overlap values are based on segment. Any values you provide still override these default values.
factor gives the ratio of new tempo to the old tempo, so e.g. 1.1 speeds up the tempo by 10%, and 0.9 slows it down by 10%.
The optional segment parameter selects the algorithm’s segment size in milliseconds. If no other flags are specified, the default value is 82 and is typically suited to making small changes to the tempo of music. For larger changes (e.g. a factor of 2), 41 ms may give a better result. The −m, −s, and −l flags will cause the segment default to be automatically adjusted based on factor. For example using −s (for speech) with a tempo of 1.25 will calculate a default segment value of 32.
The optional search parameter gives the audio length in milliseconds over which the algorithm will search for overlapping points. If no other flags are specified, the default value is 14.68. Larger values use more processing time and may or may not produce better results. A practical maximum is half the value of segment. Search can be reduced to cut processing time at the risk of degrading output quality. The −m, −s, and −l flags will cause the search default to be automatically adjusted based on segment.
The optional overlap parameter gives the segment overlap length in milliseconds. Default value is 12, but −m, −s, or −l flags automatically adjust overlap based on segment size. Increasing overlap increases processing time and may increase quality. A practical maximum for overlap is the value of search, with overlap typically being (at least) a little smaller then search.
See also speed for an effect that changes tempo and pitch together, pitch and bend for effects that change pitch only, and stretch for an effect that changes tempo using a different algorithm. -
How to change Frame rate?????
By Choey in forum Video ConversionReplies: 9Last Post: 29th Jun 2013, 01:23 -
Frame Rate/23.976 vs. 29.97
By mltwitz in forum Video ConversionReplies: 11Last Post: 20th Dec 2012, 07:23 -
Change frame rate?
By cincilator in forum EditingReplies: 6Last Post: 15th Oct 2012, 13:45 -
Change the frame rate on a bunch of mp4 videos?
By Jameszzz in forum Video ConversionReplies: 10Last Post: 29th Aug 2012, 14:46 -
how to change frame rate on staxrip?
By VistaXP in forum Video ConversionReplies: 6Last Post: 6th Apr 2011, 14:13
