    Oct 2013
    India
    I am using the following command to convert video in 3gp
    ffmpeg -i video.mp4 -vcodec mpeg4 -s 320x240 -b 170 -aspect 4:3 -acodec aac -ab 32k -ar 44100 output.3gp
    The video quality is not so good.. It is rough at many parts..
    I have one another 3gp file which has same bitrate but its quality is very good.. Its not rough enough..
    Is there any way to increase 3gp quality..
    Post the details from the 3gp with the very good quality. Use mediainfo, open 3gp, view->text and copy everything.
    And how good is the video.mp4 quality? If it's low it will get even worse when using so low bitrate.
    Oct 2013
    India
    The video.mp4 file is HD 720p i have uploaded the sample of 3gp video which has high quality
    Oct 2013
    India
    Mediainfo of 3gp file having good quality
    Format profile                           : 3GPP Media Release 4
    Codec ID                                 : 3gp4
    File size                                : 2.99 MiB
    Duration                                 : 2mn 0s
    Overall bit rate mode                    : Variable
    Overall bit rate                         : 209 Kbps
    Video
    Format                                   : MPEG-4 Visual
    Format profile                           : Simple@L1
    Format settings, BVOP                    : No
    Format settings, QPel                    : No
    Format settings, GMC                     : No warppoints
    Format settings, Matrix                  : Default (H.263)
    Codec ID                                 : 20
    Duration                                 : 1mn 56s
    Bit rate                                 : 177 Kbps
    Width                                    : 320 pixels
    Height                                   : 240 pixels
    Display aspect ratio                     : 3:2
    Original display aspect ratio            : 4:3
    Frame rate mode                          : Constant
    Frame rate                               : 23.976 fps
    Bits/(Pixel*Frame)                       : 0.096
    Stream size                              : 2.47 MiB (83%)
    Writing library                          : Lavc55.12.100
    Language                                 : English
    Audio
    Format                                   : AAC
    Format/Info                              : Advanced Audio Codec
    Format profile                           : LC
    Codec ID                                 : 40
    Duration                                 : 2mn 0s
    Bit rate mode                            : Variable
    Bit rate                                 : 32.0 Kbps
    Original Channel count                   : 1 channel
    Channel positions                        : Front: C
    Sampling rate                            : 44.1 KHz
    Stream size                              : 469 KiB (15%)
  5. Is there any way to increase 3gp quality..
    using xvid and 2pass encoding
    Oct 2013
    India
    In 2 pass we have to keep bitrate high and it will increase video size.
  7. In 2 pass we have to keep bitrate high and it will increase video size.
    Why do you have to choose a higher bit rate?
    Also MediaInfo states:
    Width : 320 pixels
    Height : 240 pixels
    23.976 fps
    and
    Simple@L1
    but Simple@L1 doesn't allow such a high resolution, see: http://en.wikipedia.org/wiki/MPEG-4
    also when you aim for such low resolutions and bitrates you often can get away with halving the frame rate.
