I am currently using a oppo bd-103However it is not a region free device
it can not play the lord of the ring extend edition which i purchased in UK.
any though to fix this by software or updates? thx!
You will NEVER be able to fix this via software.
I don't keep up with Oppo so my information is NOT current, but in the past 3rd parties made hardware modifications you could add to an Oppo to make it region free. You'll have to research - perhaps one exists for your player. I can offer no personal expertise on how easy or difficult it is to add such hardware mods yourself to players.
It is possible to rip to a PC and reburn movies. The ripping will remove region coding. Doing so would eliminate the immediate need to hack the Oppo. -
You could have a look at this site -
http://www.bluraychip.dk/product.php?id_product=24
As usual, anything you do will be at your own risk.
Question for Oppo Owners
By Seeker47 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 20th Nov 2012, 19:47 -
MKV and Oppo BDP-93
By jabbo5150 in forum MacReplies: 7Last Post: 18th Jan 2012, 18:49 -
Oppo BD-93 Anyone got one?
By oldfart13 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 22nd Nov 2010, 16:09 -
OPPO DV-981HD shuts itself OFF
By ms.zebra in forum DVD & Blu-ray PlayersReplies: 0Last Post: 2nd Nov 2010, 23:42 -
Oppo 83 Vs Momitsu 799
By punkuk in forum DVD & Blu-ray PlayersReplies: 7Last Post: 9th Jun 2010, 21:31
