    Nov 2010
    Centennial CO USA Near Denver Colorado
    Hi
    I recently downloaded a music concert only available to me in 3-D. I do not have a 3-D monitor or television, but thought that perhaps one of my media players would be able to play this 3-D video in 2-D. This does not seem to be the case. At least not in a simple way. I found this post on the VCL player forum which seems to say it can be done in a very complicated way. However is there another player which can make playing back this video in 2-D simply a matter of choosing an option? Some particular is about the video are posted below. I would appreciate any ideas you have to play this video in 2-D the simplest way possible.
    General
    UniqueID/String : 239819422709339672604680433853914801161 (0xB46B8A6E358910F4834512B1BAADE409)
    CompleteName : C:\Users\Marc\Downloads\Experience.Montreux.Quincy .Jones.And.The.Global.Gumbo.Allstars.3D.2010.720p. MBluRay.Half-SBS.x264-LOUNG3D [PublicHD]\lng-emqjatgga3d720p.mkv
    Format : Matroska
    Format_Version : Version 4 / Version 2
    FileSize/String : 2.18 GiB
    Duration/String : 59mn 49s
    OverallBitRate/String : 5 208 Kbps
    Encoded_Date : UTC 2013-08-14 01:10:15
    Encoded_Application : mkvmerge v6.3.0 ('You can't stop me!') built on Jun 28 2013 20:09:41
    Encoded_Library/String : libebml v1.3.0 + libmatroska v1.4.0
    Video
    ID/String : 1
    Format : AVC
    Format_Profile : High@L4.1
    Format_Settings_CABAC/String : Yes
    Format_Settings_RefFrames/String : 5 frames
    CodecID : V_MPEG4/ISO/AVC
    BitRate/String : 4 445 Kbps
    Width/String : 1 280 pixels
    Height/String : 720 pixels
    DisplayAspectRatio/String : 16:9
    FrameRate_Mode/String : Constant
    FrameRate/String : 23.976 fps
    ColorSpace : YUV
    ChromaSubsampling : 4:2:0
    BitDepth/String : 8 bits
    ScanType/String : Progressive
    Bits-(Pixel*Frame) : 0.201
    StreamSize/String : 1.81 GiB (83%)
    Encoded_Library/String : x264 core 133 r2334 a3ac64b
    Encoded_Library_Settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4445 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
    Language/String : English
    Default/String : Yes
    Forced/String : No
    Audio
    ID/String : 2
    Format : DTS
    Format/Info : Digital Theater Systems
    Format_Settings_Mode : 16
    Format_Settings_Endianness : Big
    CodecID : A_DTS
    BitRate_Mode/String : Constant
    BitRate/String : 768 Kbps
    Channel(s)/String : 6 channels
    ChannelPositions : Front: L C R, Side: L R, LFE
    SamplingRate/String : 48.0 KHz
    BitDepth/String : 24 bits
    Compression_Mode/String : Lossy
    StreamSize/String : 329 MiB (15%)
    Forced/String : No
    Menu
    00:00:00.000 : en:00:00:00.000
    00:06:51.244 : en:00:06:51.244
    00:13:54.709 : en:00:13:54.709
    00:20:08.332 : en:00:20:08.332
    00:29:27.891 : en:00:29:27.891
    00:34:44.916 : en:00:34:44.916
    00:42:54.906 : en:00:42:54.906
    00:45:23.262 : en:00:45:23.262
    00:51:10.276 : en:00:51:10.276
  2. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    Buying instead of pirating + Blu-ray drive + whichever decryption software you choose + whichever software player you choose. The individual M2TS files allow playback of the 2D base view.
  3. Banned
    Freedonia
    ArcSoft's Total Media Theater offers the ability to switch between 3D and 2D, but it's not free.
  4. I use KMPlayer for playing 3D video on 2D monitor, and it's free: http://www.kmpmedia.net/
  5. You can try potplayer too. I believe potplayer can automatically switch 3d to 2d mode by detecting the strings like sbs, 3d etc in a filename. It must be pre-configured in preferences though. KMPlayer has this feature (configuration management) too but I'm not sure if it works without any problem.
