I have recently started working with CS6 as a hobby and am working on a short video. Now i know this is a stupid question but im not sure how o fix it so i came here. My capture was done on a Blackmagic 2k Camera shooting ProRes 24fps now when i took the un graded footage into CS6 Premier and did a bit of colour correction then exported it as a test. and it turned out like this (bellow) :http://imgur.com/c5TwyxJ
Now for the newbie part. can anyone tell me how to fix this issue?
Thanks ever so much
-Processfailed
processfailed, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz -
you f'd something bad. the image shows an un-deinterlaced blended field interlaced video. shouldn't happen ever when working with 24p.
If you right click on import file in Premiere and select New Sequence From Clip
then export this from this Sequence, you have same result?
on MAC - converting MTS file to something I can import to Premier Pro CS6
By bdaul in forum MacReplies: 1Last Post: 19th Jan 2013, 05:12 -
Help please with After Effects Cs6 and Premier pro
By FUJAU in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2012, 07:23 -
Export Multi Audio using Premier Pro CS5. How ?!
By SB4 in forum EditingReplies: 16Last Post: 21st Nov 2010, 03:08 -
Premier Pro CS4 Crashes during Export
By Don Man in forum EditingReplies: 9Last Post: 26th Jun 2010, 11:35 -
Looking around for a solution to this problem.
By chrisyroid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th May 2010, 08:44
