After you mount the iso is there a better way to watch the movie than VLC? VlC seems to just look and play a single file, is there a way to view the download as an original Blu-ray disc, where youd see all the menus and added seens? I know u can see sceens by looking through all the files but i cant seem to ever see a menu like in a real player.
Thanks,
Sebastian
You might try the freeware VSO media player. It's all I use for BD playback. It does show some menus.
EDIT: I don't know why VSO didn't link to our tools section, but: https://www.videohelp.com/tools/VSO-Media-Player
I do have AnyDVD HD running in the background for decryption, but your ISO's are probably already decrypted.Last edited by redwudz; 16th Nov 2013 at 18:07.
The commercial players are very good at blu ray playback, including menu support. I prefer Arcsoft TMT 5 (unfortunately no longer available). The interface in TMT 6 is much worse.
I understand the DVDFab player is much improved over what they started with, but like the VSO program it only has partial support for menus. It is free to use for playback of ripped files and ISO files. -
yeah, once i mount the blu ray i usually see dirs like:
ANY!
BDMV
CERTIFICATE
I can play the movie with VLC, the issue i have is i cant play the "main menu" which lets u pick deleted scenes and stuff like that, I can just simply pick it apart. Theres has to be a way to watch it as if was in a blu-ray player.
Thanks,
Sebastian -
thx for reply, i installed the player you suggested but im getting same results i get with VLC as in that i cant see menu, i can just "play" the movie file. Its not the original as if i inserted a blu ray disk into a blu ray player where one can see added features menus etc.
VLC Blu-ray plugin - Watch encrypted Blu-rays directly in VLC 2.0+
By Baldrick in forum Latest Video NewsReplies: 63Last Post: 23rd Feb 2014, 21:34 -
What's needed to watch 3d Blu-ray movies?
By Big-Louis-1971 in forum Newbie / General discussionsReplies: 14Last Post: 27th Jul 2013, 20:26 -
blu ray iso to blu ray format
By minititan in forum Newbie / General discussionsReplies: 10Last Post: 30th Mar 2013, 14:49 -
Blu Ray slowly gets more out of sync longer you watch it... Using Leawo
By bigt85 in forum Authoring (Blu-ray)Replies: 10Last Post: 24th Jan 2012, 05:05 -
Blu ray iso
By Markfish in forum Blu-ray RippingReplies: 1Last Post: 27th Feb 2011, 17:57
