I have a question I have a 776 mb or so file it is RM and i am wondering if it is possible to fit it on a cd
yes.
1) really good compression program
2) 90 minute cd-r
3) 99 minute cd-r
4) sony double-density cd-r
5) a regular cd-r that allows for some good overburning
6) cutting the rm down some
7) converting it to a different format -
Whats a good compression program ? And I don't think you can buy those 90/99 min cd-r's in stores you have to buy them on the net right ? I tried overburning but it is still 35mb too big. How do you cut RM files ?
winrar, winace.. but i dont know if those will let you compress 35mb for a rm file.. and to cut an rm file.. look over there to the left of your screen, you see "convert"? good. click on it, convert it to mpeg.. okay, now do you see "edit" to the left of your screen? good, click it.. that'll tell you how to cut it.. okay, now you want it back to rm format.. go to real.com, you'll find how to do it there.. dont ask me where. and dont ask anymore questions. you've been equipped with all you need to know. no one is going to hold your hand from here. either you move ahead, or you just fail.
