I have been playing around with the settings on various things, trying to get the playback on my DVD player to look as sharp and edge-enhanced as possible with as little artifacting as possible. Will using an HDMI cable to connect my TV to the DVD player produce better results with this than the red white and yellow cables? And is it best to have my DVD player set to progressive scan mode?
				Results 1 to 20 of 20
	sharpen + edge-enhanced = artifacts.
 Yes.
 Yes.
 http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=Audioquest%20HDMI
 http://www.whathifi.com/review/audioquest-pearl-hdmi
 Monoprice fanboys, have at it.Last edited by sanlyn; 19th Mar 2014 at 14:48.
	Amazon sells their own brand of HDMI cables for about $6 each that I have been using for years.
 I cannot personally recommend sanlyn's cable advice as I feel that those cables are unnecessarily expensive and I warn you that such a recommendation is going to lead to a religious war and take this thread very far from your original simple questions.
	Monoprice sells decent budget cables. I have 3 of them. I have tried their 3ft and 6ft cables with 2 different computers, 3 different TVs, a DVD recorder, a DVD player, a cable box, and a Blu-ray player and had no connectivity problems with any of them. Same story with some no-name cables and another cheap cable brand purchased from Amazon.
 sanlyn is the only member of this forum I know of who has tried Monprice cables and claims to have had a problem. The fact that he tried other brands of HDMI cables too that he says didn't work right for him leads me to believe that there is something about his gear that is slightly off the mark, but since he paid a fortune for said gear, he blames the cables. Maybe he should read this: http://www.techradar.com/us/news/home-cinema/high-definition/common-hdmi-problems-and-...lutions-923327Last edited by usually_quiet; 14th Nov 2013 at 13:29.
	Red-White-Yellow RCA connection (Composite) => 480i resolution
 HDMI connection => up to 1080p resolution
 Unless you have an old TV with a built-in up-converter there's no contest. Some receivers offer up-conversion of analog inputs, this works best with the Red-Green-Blue connections (Component). HDMI is the only digital output on your DVD player and if it has up-conversion capabilities, you'll get the best results possible. If it does it will allow you to manually set the HDMI resolution.
	The only one you know of. True.
 I read that. B.S. from the blind. The O.P. likely can't see any better than the average joe. I'd suggest http://www.amazon.com/Mediabridge-High-Speed-Cable-Ethernet/dp/B0019EHU8G .Last edited by sanlyn; 19th Mar 2014 at 14:48.
	Looks like sanlyn did not actually bother to read that article. It does NOT claim that all HDMI cable are alike, as one would expect since the source for the information presented owns a company which tests HDMI cables, although it does point out that cables are not always the root cause of HDMI-related problems. Last edited by usually_quiet; 14th Nov 2013 at 18:51.
	IF your DVD player has HDMI output, the answer is absolutely yes, compared to the yellow/white/red cables that come with most standard DVD players.
 If your DVD doesn´t have HDMI output, the next best thing is component output; red, green and blue RCA connectors just for video (again, if your DVD player has that)
	You're not paying attention. The problems discussed in that article are not the poor imaging and f*k'd up audio I complain about with many cables, whether they are HDMI or otherwise.
 You seem to have some kind of personal jihad against any opinion that differs from yours, experience that goes beyond your glass eye or tin ear, or equipment better than what you own, or anything that's priced above your low-rent, clearance bin standards. You just enjoy spoiling it for the rest of us. I won't apologize for lowering my standards to yours or others' big-box-store mentality or mass marketing hype.Last edited by sanlyn; 19th Mar 2014 at 14:48.
	I would also try letting the TV do the upscaling from 480p, to see if I preferred that to upscaling by the DVD player.
 If the TV is a 720p HDTV, the screens actual resolution will probably not be 720x1280 to match the standard video resolution. Most have an actual resolution of 768x1366 instead. Since the TV will need to scale regardless, it might do a better job by itself. I'd do the same with a 1080p TV because some TVs upscale better than some DVD players.
 Also, DVD players sometimes don't do a good job upscaling their own menus. That has been the case with the DVD player I bought for my parents. The 4:3 menu is easier to read if the TV upscales.Last edited by usually_quiet; 15th Nov 2013 at 12:48. Reason: typo
	True mentality and personality?  I dunno, haven't we had enough of this? I dunno, haven't we had enough of this?
 Lunch. Listening to the soundtrack of O Brother, Where Art Thou? via my Oppo player, MSB Link outboard DAC, ADCOM GFP-565 preamp and head amp, and Grado headphones. It's amazing how lifelike Alison Krauss sounds with that chorus (Down To The River And Pray). Depth. Deep space. The spread of the chorus is wider than the room I sit in, sounds about 20 feet back. Count every voice, place all four choral sections. Alison singing, hell....when she breathes through this setup and you hear her lips part, it's a revelation. Amazing how much better $3.2K sounds than $99.95 at BestBuy. I consider it well spent.
 With $10 to #20 budget I'd go with MediaBridge or, even better, ThatCable.com
 Time to calibrate my monitor again.Last edited by sanlyn; 19th Mar 2014 at 14:48.
	An "average joe"? Not a ... ahem ... connoisseur like yourself?
 (Insert derisive snort emoticon here)
 Look, here it is:
 A cable should have good quality mechanically ... good shielding, connectors etc. I wouldn't really recommend buying them at the dollar store.
 Speaker wire does matter. The resistance shouldn't be too high. An audio power amplifier is a current source into low impedance. The sum of the speaker cable resistance and the amp's output impedance (the inverse of the damping factor) should be no more than 5% of the speaker impedance rating.
 However, low level signals are voltage source into high input impedance. For audio there are no electrical characteristics that a cable can have that aren't completely swamped by other deviations from ideal in other components. Especially speaker crossovers.
 For things like digital audio or video, the impedance of the cable does matter because, unlike with audio, the frequencies involved are high enough for transmission line effects. I can't believe people think that you can have transmission line problems with speaker cable ... maybe if your speakers were 50 miles from your amp ... God, it's stupid. Anyway, for hdmi there's a standard cable impedance. No problems there.
 High priced audio/video cables are completely snake oil.
 All those perceived differences among cables that don't have electrical faults are 100% placebo effect. Which is very popular with audio/video salespeople.
	Likely not. (Insert second derisive snort emoticon here  ) )
 I don't buy price. But most people do: the cheaper the better (Insert third derisive snort emoticon here).
 I don't talk to salespeople about cables. If I wanted advice, I wouldn't come here to read snorts from the herd.Last edited by sanlyn; 19th Mar 2014 at 14:48.
	Since you apparently either weren't raised properly or never paid attention to what your elders told you, bragging about one's possessions and their high price has always been considered vulgar. ...but since you also feel the need to brag about having better taste, better hearing , better eyesight, more intelligence and being otherwise superior to the general public and much of the active membership here, maybe this behavior is more of a mental health issue in your case.
 Who is bragging about being a cheapskate? I buy what are generally considered to be average-price consumer products. ...but most of my "cheap" A.K.A. ordinary stuff has lasted a long time, 8, 10, 12, 20 years. Maybe you abuse your possessions if you didn't pay much for them and I don't.Last edited by usually_quiet; 16th Nov 2013 at 14:19.
	quality equipment is great as long as you can afford to keep replacing it as standards change. my grace tonearm on my thorens turntable is wonderful and sounds primo through the all-tube macintosh stuff i have but it's all useless as part of a current a/v setup. so it's all in a different room and only heated up to play the occasional vinyl. listenting to compressed source digital audio through analog tube equipment just has no upside to me, a/b'ing the same music on vinyl and cd and hearing the difference is depressing. just like i wouldn't ever hook up a turntable to a transistor powered amp. --
	Agreed. But some things don't change much. Tonearms like Grace (wish I had one) are made to last, provided you don't treat them the way dj's handle those godawful bonky-bass Technics tables.
 Got a $20 HDMI that had to go to a technician, lost a contact inside the shell. Not surprised. I bought it for image and sound, not for construction or price. Tech said it's molded plugs, no way to fix. Okay, another 20 bucks + overseas shipping. Ordered two in case they stop making 'em -- and they did. I checked a few months back, no more 3-meter stock in that model. So I still have a 3-meter spare. Good cheap HDMI's are hard to find. In that respect, most of them really are alike. Friends of mine have the same cable, no problems. You never can tell.
 When it comes to good stuff that's a bit more pricey, Black Friday and Dec. 25th can be your friends. Closeouts help, too.Last edited by sanlyn; 19th Mar 2014 at 14:49.
	mine's a wooden grace 714 on the old ugly td124. most people who look at it think it must be a worthless pos.
 i love online holiday deals, in-store first come first served not so much. staples, newegg and best buy on-line deal of the days are all year long treats.
 digital cables either work or the 1s and 0s aren't getting to where they belong. trash em. not sure what i think of the "redmere" chipped cables with undersized copper. personally i pass on those and just buy thicker un-assisted cables. i do have 3d and audio return over hdmi so i do use the proper rated cables even though they do weigh a ton and don't bend.
 speaker cables i make myself with 12ga o.f. copper and soldier on gold plated ends. i've had copper cables turn green and create flakey connections without the gold ends.--
  What type of TBC will fix this type of wiggling in the video?By ChibiBoi in forum RestorationReplies: 38Last Post: 24th Apr 2013, 06:34
  Help me indentify cable needed. Sold a faulty cable with PVR2By exbngr in forum EditingReplies: 29Last Post: 12th Dec 2012, 02:17
  How to convert a trp type file to Mpeg2 type?By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 16:59
  PC controlling a cable box (USA time warner cable)By marcolisi in forum Capturing and VCRReplies: 2Last Post: 4th Aug 2010, 17:24
  Unable to use HDMI cable with Scientific ATlanta 8300 DVR cable boxBy aimee43 in forum DVB / IPTVReplies: 11Last Post: 28th May 2009, 13:21
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Well at least now that you have fully exposed your true mentality and personality for all the world to see, anyone reading this thread can consider the source before taking any advice you give.
