Hey guys. Newbie here.
So.. I've got some MKV videos, that mostly look like these (through MediaInfo):
Three issues with these are:Code:General Complete name : X:\XXX\123.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 1.10 GiB Duration : 2h 45mn Overall bit rate mode : Variable Overall bit rate : 952 Kbps Encoded date : UTC 2013-03-26 07:00:52 Tagged date : UTC 2013-03-26 07:00:52 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 2h 45mn Bit rate : 852 Kbps Maximum bit rate : 6 085 Kbps Width : 1 280 pixels Height : 536 pixels Display aspect ratio : 2.40:1 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.052 Stream size : 1 008 MiB (89%) Title : 123.mkv.264#trackID=1:fps=23.976@GPAC0.5.1-DEV-rev4283 Writing library : x264 core 129 r2245 bc13772 Encoding settings : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=852 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2013-03-26 07:00:52 Tagged date : UTC 2013-03-26 07:02:35 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 2h 45mn Bit rate mode : Variable Bit rate : 96.0 Kbps Maximum bit rate : 136 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 114 MiB (10%) Language : English Encoded date : UTC 2013-03-26 04:25:24 Tagged date : UTC 2013-03-26 07:02:35
- They already come with embedded SRT subtitles in a foreign language.
- The 2:40 Aspect Ratio is a bit too wide for my taste, I'd like to change it to 2:25.
- The audio volume level changes drastically everytime. So I extract the audio and apply compression to attenuate loud transients, save to lossless audio file, and watch the clip on MPC with my custom-made file as the selected audio source (on the fly, no mux needed).
Normally I watch these in my PC, but since I want to now watch them in a LCD TV, I've to correct some things:
1. Remove the embedded SRT subs, and replace it with my own.
2. Change AR without re-encoding.
3. Replace the AAC file, with my own custom version of it (now using AAC instead of lossless).
Preferably in one go.
I already have the SRT and the audio work is done. I just need to put everything together.
I already have a few tools to work with:
- mkvmerge GUI v6.1.0 ('Old Devil')
- tsMuxeR GUI 1.10.6
- Yamb 1.6.0
- AVI-Mux_GUI-1.17.8.3
But I don't know how to used them properly (what's the whole ts and m2ts??).
However, maybe you can suggest other software (or different/proper version of the one I already have). I've seen you guys work with command line programs, but I'm clueless about how to use those. GUIs are easier for me, although I could learn to use commands (in case these work better, or if there's no other way).
I hope you guys can help me.
YOu can do most with mkvmergegui. Replace subtitles, change display aspect ratio(BUT this will make the video look stretched and the player must support the mkv aspect ratio). and replace the audio.
HOW TO Multi subtitle & .mkv files mux [HELP]
By MoleofWar in forum Newbie / General discussionsReplies: 1Last Post: 21st Oct 2013, 12:28 -
By MoleofWar in forum SubtitleReplies: 1Last Post: 17th Oct 2013, 02:31 -
[HELP][ANIME] MKV (H.264 + AAC) to AVI (PS3 - Compatible) with soft-subs.
By mooshimuushi in forum Newbie / General discussionsReplies: 4Last Post: 21st Aug 2010, 02:42 -
Batch re-mux .mkv to DiVX w subs
By nbarzgar in forum EditingReplies: 6Last Post: 3rd Jun 2009, 07:18 -
eac3to mux audio into MKV in one step?
By jameson_uk in forum Blu-ray RippingReplies: 1Last Post: 24th Feb 2009, 04:14
