Thanks anyway.
"I would like to use it for professional work as well as for fun." You probably need to define that a little more. Most pro videographers today are using both types of cameras. DSLR's and Video Cameras. DSLR's can take good video but have a time limit. If you are just a hobby video kind of person you can get either and be very happy.
Extraordinary claims require extraordinary evidence -Carl Sagan -
Not unfortunately, mostly that's a good thing unless you are making hollywood features.
rture/DOF) with excellent IQ, in that case I will accept only one lens.)
DV is standard def. To answer the question you think you're asking, there's little point in going tape based these days.
And that is? So we have an idea of your experience.
ANY camera in your price range will have both options.
Since you're looking to drop substantial coin, why not pick out a model or two and do a daily rental? You don't say where you're located, so this may or may not be convenient.Last edited by smrpix; 14th Nov 2013 at 11:39.
hi, it seems that your a bit of a pixel peeper from what you have written so far, however thats besides the point.
i shoot weddings, and recently upgraded to panasonic AG-AC90 cameras for this, and there was one reason why i went for this camera.
i shoot entirely in hand held mode, using my own custom made camera mounting rigs, and i need the best Image Stabilization and Auto Focus systems i can get, and they must be built into the body, and for this, i chose that camera.
i wanted to go the Sony nex VG900 which is a full frame 35mm camera with interchangeable lens system, but it has no AF or IS built into the body, they are totally lens dependent.
the VG900 was also double the price, both shoot avchd onto card, but the deal breaker for me was the AC90 shoots 1080/50p @ 28Mbps and the VG900 only shoots 1080/25p, and for my style of shooting, where i do lots of slow panning shooting progressive 50fps is a no brainer, 25fps just doesnt cut it for me.
i am now in the process of buying a couple of australian made Atomos Ninja 2 recording units to run with my cams during some of my shoots, but these units only record 1080/25p not my preferred 1080/50p.
http://www.atomos.com/ninja/
the up side to these Ninja 2 recording boxes is the recording format.
i will be able to shoot and record 1080/25p ProRes HD @ up to 220Mbps directly from the camera sensor thru hdmi onto a laptop hdd inside the Ninja 2, plus the Ninja also becomes an external 5" preview screen, and it can also be used as an external battery power supply for the camera.
for the most part i will probably still shoot weddings in 1080/50p avchd @ 28Mbps, but having this ninja unit will give me the added bonus of going ProRes if i need to.
the AG-AC90 cameras cost me $2000au each, the ninja 2 units are $650au, so i get a brilliant camera plus ProRes recording for under $3000au and the VG900 is $3500au for the body, add another $1500+ for one decent lens with AF/IS built in, plus $650au for the ninja to shoot ProRes, i was up for around $6000.
i personally cant tolerate using DSLR type cameras for shooting video, i am more a traditionalist, and just prefer using a dedicated video camera.
oh, btw i also have a Black Magic Pocket Cinema Camera and i can shoot in RawDNG and ProRes HQ using that, but the body is so small and with a big lens attached, it really is a handful to shoot with, plus it has to have an external screen attached because the screen on the camera is fixed, cant move the camera around and shoot from any angle except from in front of your face.
will be selling it, not that happy with it unfortunately.
DSLR or HD camcorder
By rbacevac in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 36Last Post: 30th Nov 2013, 07:03 -
How to mount modern DSLR or Camcorder on a Vintage Studio Pedestal?
By erek in forum Newbie / General discussionsReplies: 6Last Post: 14th Oct 2013, 12:38 -
Mix footage from dslr and camcorder
By gerlos in forum Newbie / General discussionsReplies: 7Last Post: 24th May 2013, 05:46 -
What shoots better HD video...a HD camcorder or a high end DSLR?
By Moontrash in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 8th Sep 2012, 23:47 -
Camcorder or DSLR camera reccomendation wanted
By ZombieTrev in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 17th May 2012, 09:26
