I need some help please. I am using rtmpdump to download a live stream. I need to convert the live stream to mp4. I need it to be done with a command line tool, something that can be initiated and terminated thru a batch file. After some more reading I think using ffmpeg to listen for rtmp might be the way. Any help on the syntax to do this.Thanks
As suggested what I need is to convert or transcode the rtmp to mp4 as it's being streamed.
It depends on what codecs are being used in the FLV. IF they are compatible with MP4 container (e.g. h264 video/aac audio), it would be best to stream copy it (faster, no quality loss)
ffmpeg -i input.flv -vcodec copy -acodec copy output.mp4
But I don't know how to do this for a live stream (only after the dump has finished) . And if that's what you need, consider editing the thread title to something more specific
How to lossless convert FLV to MP4 with ffmpeg?
By pxstein in forum Newbie / General discussionsReplies: 3Last Post: 24th Apr 2013, 06:28 -
How to convert mp4 to flv in virtualdub?
By sgbd in forum Video ConversionReplies: 9Last Post: 2nd Oct 2011, 16:17 -
How to convert DVD to flv, mp4 and mp3 at the same time ?
By csc12345678 in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2011, 13:05 -
convert flv to mp4
By tracyselena in forum Video ConversionReplies: 11Last Post: 1st Oct 2009, 10:05 -
Should I convert .flv files to .avi or .mp4?
By johnharlin in forum Newbie / General discussionsReplies: 6Last Post: 1st Dec 2008, 14:51
