hi, I have some movies that I have converted to avi. They play fine on my computer but when i try to play them on my tv through my usb they are playing upside down and the colours are all wrong. Its not all movies either. any help would be appreciated.
Results 1 to 9 of 9
Mediainfo is an invaluable free tool for determining what is inside a media file.
Download it from here: https://www.videohelp.com/tools/MediaInfo
(Anything on the tools section of this site is reliably safe from malware)
When you install be sure to read each screen and refuse any adware that comes bundled with it.
Once installed, drop your file on the Mediainfo icon, switch to "tree" view and post the results here.
Any other information you can provide such as whether this video was shot on a phone is also useful. -
i have all the media info but how do i post it here? sorry im new to all of this
Not a problem. For some reason it has gotten more complicated lately. What I do is open the file in Tree view, then under 'File' to the left side of the program, choose 'Export>Text' and save it somewhere easy to find. Then in your post, choose 'Upload files/Manage attachments' below the post window and browse to your Mediainfo file. Then 'Upload', close the window and 'Submit Reply' of your post to the forum.
General
Complete name : C:\Users\Tania\Downloads\Download\Grown Ups 21.avi
Format : AVI
Format profile : OpenDML
File size : 4.71 GiB
Duration : 1h 40mn
Overall bit rate : 6 680 Kbps
Movie name : Grown Ups 2
Director : WinX HD Video Converter Deluxe
Writing application : Lavf54.63.104
Video
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 40mn
Bit rate : 6 542 Kbps
Width : 1 920 pixels
Height : 1 040 pixels
Display aspect ratio : 1.85:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.137
Stream size : 4.61 GiB (98%)
Writing library : Lavc54.92.100
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 40mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 92.4 MiB (2%)
Alignment : Aligned on interleaves
Interleave, duration : 26 ms (0.63 video frame)
Interleave, preload duration : 130 ms
Writing library : LAME3.99.5 -
Try use a lower resolution like around 720x576 or lower. Most avi hardware players doesn't support hd resolutions.
Or try other converters like free xvid4psp 5, xmedia recode, freemake video converter. Use the avi dvd player/hardware presets with xvid video and mp3 audio.
Playing movies backwards ??
By skan in forum Software PlayingReplies: 7Last Post: 12th Oct 2013, 09:58 -
HTPC for playing 3/4 movies.
By hanugro in forum Media Center PC / MediaCentersReplies: 11Last Post: 20th Nov 2012, 20:31 -
Colors Reversed? Inverted?
By Abbadon21 in forum RestorationReplies: 3Last Post: 17th Dec 2011, 09:00 -
Playing movies from my PC
By rossvickicampbell in forum ComputerReplies: 1Last Post: 16th Jun 2011, 20:56 -
Inverted Video
By PaPaDeath in forum Video ConversionReplies: 4Last Post: 20th Nov 2008, 22:48
