hello, Anyone know why EzRecorder stops recording when you turn off the tv?
	Does this only happen when you use a remote control to shut off the TV or does it also happen when you use the off button on the TV itself?
	I also had the same issue using a TiVo set to 1080i and a 720p Vizio TV with recordings that are from non-cable broadcasts. So I just mute the TV and set the sleep timer for a minute longer than the movie.
	Many devices stop putting out all video when no valid HDMI/HDCP sink is available.
  mpg2 avermediaBy JAX75 in forum Video ConversionReplies: 2Last Post: 28th Jul 2013, 14:00
  Problem with AvermediaBy JustRyuzaka in forum Capturing and VCRReplies: 0Last Post: 12th Apr 2013, 09:34
  record hd tv signal with m780 avermedia only get one audioBy godai in forum Capturing and VCRReplies: 30Last Post: 8th Mar 2013, 17:01
  Cannot record SD content from component output - avermedia game capture hdBy techspark in forum Capturing and VCRReplies: 9Last Post: 24th Feb 2013, 03:45
  Confused with AVerMediaBy v19 in forum Newbie / General discussionsReplies: 13Last Post: 21st Jan 2013, 16:43
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
