Hello
I shot a 3h30 MPEG video with my camcorder and would like to share it with friends. As they'll watch it on their computer, quality can be reduced and make upload/download faster.
I attached a screenshot of the codec infos per VLC. What would you recommend I change and using which Windows application?
Thank you.
Depends on how you want to share it with your friends, and whether quality is a high priority. Probably easiest to just do what Baldrick said: pass it through Handbrake and upload the resulting mp4 to youtube.
If you want to go more old school you could use, say, DVDFlick to make a DVD out of it. Beware that DVDFlick usually works, but its encoding settings aren't that great. -
Thanks for the tips.
I converted the original 10GB file into an MP4 file with the H264 video codec; The output generated by ffmpeg is down to 1.8GB while the output generated by VidCoder is 2.7GB.
Is there something I could try to further reduce the size significantly? -
Increase the constant quality setting under the video tab. Try around 25-30.
Or in vidcoder under settings->video set the exact target file size directly(use 2-pass for better quality but it's slower).
You could also lower the audio bitrate and convert to aac audio. -
Thanks for the tips. Using the default settings, the original 10GB file was compressed to 2.7GB by VidCoder and 2.2GB by Handbrake.
I ended up using ffmpeg with the following settings, which go the file down to a respectable 1GB:
Code:ffmpeg.exe -i input.mpg -c:v libx264 -b:v 900k -s 640x360 -strict experimental -c:a aac -ab 192k -ac 2 -ar 44100 -preset slower output.mp4
You can adjust same settings in both vidcoder and handbrake....but if you prefer command line tools then it doesn't matter what you use. Both are using x264 encoder.
Thanks for the info. I prefered to use a CLI so I could understand a bit more about what is being done.
Recommended MPEG Streamclip settings for export to FCPX-friendly format?
By thetallest in forum MacReplies: 2Last Post: 5th Jun 2013, 15:44 -
Software to split 10GB Blu-Ray File for the PS3
By Euroconvert in forum Video ConversionReplies: 7Last Post: 2nd Jan 2011, 16:48 -
Best Ripbot settings for 1080p mkv? I'm thinking ~10gb should be enough?
By AndyD in forum Blu-ray RippingReplies: 20Last Post: 26th Aug 2010, 23:13 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
Any recommended settings for TMPGencXpress color filter?
By Anonymous5394 in forum Newbie / General discussionsReplies: 0Last Post: 27th Mar 2010, 12:29
