Hi
I have online tv channel and i have get over 50 DVD and now i try to convert this to MPEG2 files but when i convert i dont get fullscreen the video its like frame with black around the video. I have try iSkysoft, WinX DVD Ripper Platinum, Wondershare Video Converter Ultimate. I choice 720X576 but still its not fullscreen the video, the DVD is fullscreen. What is the best way to convert the DVD to MPEG2?
DVD's are already in mpeg2 format, it is just inside of those VOB files, so all you need is to "take them out" of those VOB's. There are programs like mpeg2VOB, PGCDemux, Avidemux(if you want to re-encodeit at the same time) etc....
bitrate of those files might range from around 2-3000 to 6000kbps and that might be too much for streaming though, so if you want to stream something you have to know at what bitrate and then you go from there ...
Setup default dvd player
By bambam in forum Software PlayingReplies: 15Last Post: 26th Jul 2014, 20:07 -
Assign default audio and default subpicture streams for movie only backups.
By mattstan in forum DVD RippingReplies: 12Last Post: 11th Sep 2012, 04:59 -
VlC became default audio player, some how, but I can't default 2 foobar?
By Denvers Dawgs in forum ComputerReplies: 1Last Post: 17th Sep 2011, 17:38 -
How to enable a DVD subtitle by default?
By dexter30 in forum SubtitleReplies: 1Last Post: 26th Dec 2009, 22:18 -
Subtitle Creator - Unable to set Default Subtitle Colors & Default Prof
By blue2 in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 22:47
