Hello!
I recently installed an LG bluray writer (WH14NS40) in my Vista system. It reads blank dvds, audio cds, and blu-rays perfectly. It also reads burned dvds that I have previously shrunk using dvd decrypter and dvdshrink (using another dvd-writer).
I have just discovered that it does not read store-bought dvds. VLC player, Windows Media Player, and dvd-decrypter will not recognize the dvds, giving me the error
Device Not Ready (Incompatible Medium Installed)
I am assuming this is a region issue, or some new copyright issue that I am experiencing for some reason since installing the drive, but I have no idea what.
The fact that it reads burned dvds tells me that it's not the dvd-format itself that is the problem. I updated to the most recent LG firmware after experiencing this problem, but the problem remains.
Any help would be most appreciated.
Edit:
The problem is temporarily fixed using the Microsoft "Fixit" tool here:
http://support.microsoft.com/mats/cd_dvd_drive_problems
Unfortunately, once I eject the disc and reload it, the original problem returns.
If it were me, I would use either anydvd or dvdfab or makemkv for decryption instead of dvd decrypter which only will work for real old dvd titles.
You might have some other issues...I see you have install firmware and fiddled with MS.
First, try what I mentioned above and see what that does....I am not too crazy about WMP either... -
Well, like I said, I didn't touch the firmware until after I started having this problem, so that is not the cause of it. By "MS," do you refer to Windows? If so, I only used the "fixit" program that actually does fix the problem, although temporarily. But I'd really rather not have to run that thing everytime I want to use a DVD.
I will try the other decryption programs. I don't use WMP, but dvds used to start automatically with that program, and they no longer do.
Thanks for the response. -
Is the writer new enough that you can just exchange it for another one and try that? I'd certainly do that before I'd completely reinstall or (better choice if you can) do a system restore as suggested. Based on what you read I can't rule out that there's simply a problem with the drive. If the drive is defective, all the other suggestions will make no difference.
*** Now that you have read me, do some other things. ***
DVD Decrypter error:Failed to set data for "DVDDecrypterPlayMovieOnArr
By rachelsmiley in forum DVD RippingReplies: 17Last Post: 22nd Dec 2017, 11:40 -
VDub "incompatible data formats" error
By coyote2 in forum EditingReplies: 10Last Post: 1st Nov 2011, 11:28 -
Tip: How to add "detele" and "up" buttons in Vista/7
By roma_turok in forum ComputerReplies: 1Last Post: 3rd Jul 2010, 14:54 -
"Device not ready, medium may have changed"
By mobie29 in forum MediaReplies: 0Last Post: 20th Jan 2010, 22:46 -
Can't burn CDs with ImgBurn - "Incompatible Medium Installed"
By Lawbringer in forum DVD & Blu-ray WritersReplies: 5Last Post: 11th Oct 2009, 16:35
