Hello,
my smart TV not let me record from hdmi signal. it allow me only to record from a DTV channels(from the antenna)
I thought of an interesting solution - if I can somehow create a virtual DTV channel in HD and broadcast the virtual channel through cable (no need to use antenna. the dtv signal will come from some device to the tv through antenna cable)
so this way i can record the signal (as a normal dtv channel)!
all i need is a device the get HDMI input and send dtv output.
My question is -
- Is there such a thing? Is there a way to do this?
- How much it could cost?
Thanks for helpers!
There are such things but you can't afford one, considering you can only afford to spend $65 for an HDMI HD capture device. A device capable of converting HDMI input into an HDTV cable signal of some kind will cost at least 10 times that much and up.
Losing HDMI signal to TV
By branhamr in forum Media Center PC / MediaCentersReplies: 1Last Post: 9th Apr 2011, 13:04 -
Need help with HDMI, DVI-HDMI and "high definition audio device"
By uart in forum Newbie / General discussionsReplies: 7Last Post: 16th Mar 2010, 00:15 -
PC to TV DVI to HDMI signal issues
By GokuuSon in forum Media Center PC / MediaCentersReplies: 12Last Post: 12th Jan 2010, 11:34 -
What happened to DTV channel 7 to 13 ?
By SingSing in forum Newbie / General discussionsReplies: 59Last Post: 1st Aug 2009, 09:51 -
WDTV...no HDMI signal
By holmerz in forum Media Center PC / MediaCentersReplies: 1Last Post: 2nd Apr 2009, 14:19
