H.264/MPEG-4 AVC is the codec and it's name is H.264/MPEG-4 AVC. BUT, in GSpot I see that the codec is AVC1 and it's name is H.264/MPEG-4 AVC. So, I'm confused, what is the difference between the words "codec" and "codec name"? I mean, isn't AVC1 and H.264/MPEG-4 AVC the same thing?
As the article said, containers like MP4 and MKV don't need the start codes in the AVC elementary stream. OTOH, containers like MPG, TS and AVI work better when the AVC elementary stream includes the start codes. The Fourcc "H264" normally means the AVI file contains AVC in the so-called Annex B format. Using the Fourcc "AVC1" is not recommended, because it may break the functionality of several splitters and/or decoders.
I use libavcodec library and I don't set any fourcc. I just set the codec to H264 and container to MP4 and the library, probably, sets automatically the code to "AVC1".
In general, I just wanted to know if the "codec" in GSpot refers to fourcc code?
Cant play AVC1/H.264 converted from Canon 5DmkII mov with MPEG Streamclip
By void143 in forum Video ConversionReplies: 3Last Post: 19th Nov 2011, 06:14 -
Video Player for MPEG-4 AVC/H.264
By wingspar in forum Software PlayingReplies: 3Last Post: 15th Jun 2011, 23:56 -
mpeg-4 AVC/H.264
By wingspar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 9th Dec 2009, 03:46 -
Converting H.264/MPEG-4 AVC to DVD
By KiteFlyer in forum Video ConversionReplies: 1Last Post: 23rd Jan 2009, 14:36 -
codec- H.264/MPEG-4 AVC Help
By spooky24 in forum Video ConversionReplies: 3Last Post: 12th Jan 2009, 19:04
