Results 1 to 10 of 10
    Nov 2013
    India
    I was looking at some examples by searching on google, and most title credit scripts I see are for rolling credits, or credits fading in or fading out etc.,
    I was wondering, what if I want a title credit sequence where it appears character by character, as if somebody is typing the credits?
    Can you point me to some examples of funky title credits in this way using just
    SubTitle, Blankclip and Animate command?
    Thank you
  2. Of course there's after effects , but are you looking for avisynth only ?
    Another approach would be to use aegisub / ass subs to hardcode fancy fonts and animated text effects . There are many tutorials on various websites and youtube
    eg
    http://www.youtube.com/watch?v=lT-Q-pL8dU8
    Nov 2013
    India
    Yes poisondeathray you are right. Its avisynth I am looking at. I will check out aegisub. Seems promising!
  4. Member ricardouk's Avatar
    Mar 2005
    Portugal
    you can do it with subtitle workshop by using "type effect" and add it into the avs script
    or
    create your srt sub with subtitle workshop, rename it with same name as your video, enable subtitles in ffdshow, "feed" the video through avisynth, this way you have more control on how your subs/credits will look (colour, position, opacity etc) you can try this options "on the fly" while playing the avs script with MPC-HC for example
    I love it when a plan comes together!
    Nov 2013
    India
    I see both aegisub and subtitle workshop are open source software. My main interest is titles and end credits. What do you recommend.
    Here is what I will do
    Encode a blank or image background video for title
    Encode a blank of image background video for end credits
    And then while processing my video in AVISYNTH, add these videos
    Alternatively, I can have a single script which creates
    50 title frame video
    50-100 end frame video
    And then dissolve all.
  6. We can't really recommend anything unless you're more specific about what you want
    You can overlay (hardcode) subs with avisynth using TextSub() . If you just want a blank background , use BlankClip() ; for an image background use ImageSource() . It doesn't have to be encoded beforehand. You know that already from your other thread
    Have you seen any anime fan sub / karaoke work? For a "simple" text/sub editor, you can do pretty fancy things with aegisub.
    eg
    http://www.youtube.com/watch?v=W0h_WB2fwdU
    http://www.youtube.com/watch?v=KG7UpqlNzd8
    http://www.youtube.com/watch?v=chVKB2zA8b8
    http://www.youtube.com/watch?v=v3LHD9ORGs0
    playlist of a few aegisub karaoke effects
    http://www.youtube.com/playlist?list=PL1572C5EDBB541D15
    There are hundreds more, just search youtube
    Many people provide templates and .ass files in a download link that you might customize for your own purposes. Check out the comments sections on the various videos
    While avisynth is a great tool, you'd be hard pressed to do some of those effects in avisynth alone
    It's very easy to go "overboard". Personally, I would use something appropriate or related to the content. So for your timelapse you might combine some variation the trails effects with the credits and titles
    Nov 2013
    India
    Thanks poison death raw. My time lapse is one star trails sequence, and rest Aurora.
    So I was looking at a title where each character comes on as if typed live on screen. I want to keep it simple so not going overboard definitely. I will check out the stuff on youtube.
    Thanks once again!
    Nov 2013
    India
    Went through the videos. And frankly, they are all overboard. Will go through aegisub tutorials to make my own simple affect of text coming as if being typed by typewriter. Want to K.I.S.S.
  9. ricardouk's idea using subtitle workshop is very easy to do, probably even easier than aegisub
    I guess I was led astray by your comment about "funky title credits"
    Nov 2013
    India
    I guess I meant just a little bit funky. Letters appearing as if they are being typed is quite funky to me who is used to the simple fade and scroll effects of windows live movie maker!!
    Subtitle workshop is simpler, but aegisub has a lot more tutorials and stuff. Will learn both and create something simple.
