    May 2013
    EDM, USA
    I got some files and converted them to avi with Any Video Converter. Then I extracted both tracks and muxed them using ImagoMuxer so that I can end up with a .mpg with m2v(mpeg2) video and ac3 audio to then burn to DVD. I don't like how DVDStyler converts video because it's a huge quality lose so I like to do it myself but I ended up with choppy playback. I don't know why because when I put the files in MediaInfo it says 23.976 fps. The DVDStyler thing is too long to post so I'll have to put it in parts. :/
    DVDStyler v2.5.1
    Windows 7 (build 7601, Service Pack 1)
    FFmpeg: libavformat 55.12.102, libavcodec 55.18.102, libavutil 52.40.100
    Prepare
    Cleaning temporary directory
    Search for transcoded files in cache
    Generating menus
    Generating menu 1 of 3
    Create menu MPEG
    Multiplexing subpictures into mpeg
    Menu has 1 group(s) of changeable colours.
    Executing command: spumux -P -s 0 "C:\Users\User\AppData\Local\Temp\dvd-tmp\menu1-0.mpg_spumux.xml"
    DVDAuthor::spumux, version 0.7.1.
    Build options: gnugetopt iconv freetype fribidi fontconfig
    Send bug reports to <dvdauthor-users@lists.sourceforge.net>
    INFO: no default video format, must explicitly specify NTSC or PAL
    INFO: Converting filenames to cp1252
    INFO: PNG had 1 colors
    INFO: PNG had 4 colors
    INFO: Pickbuttongroups, success with 1 groups, useimg=1
    INFO: 0 bytes of data written
    INFO: 36864 bytes of data written
    INFO: 71680 bytes of data written
    INFO: 108544 bytes of data written
    INFO: 143360 bytes of data written
    INFO: Found EOF in .sub file.
    INFO: Max_sub_size=126
    INFO: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.50
    Executing command: spumux -P -s 1 "C:\Users\User\AppData\Local\Temp\dvd-tmp\menu1-0.mpg_spumux.xml"
    INFO: 73728 bytes of data written
    INFO: 110592 bytes of data written
    INFO: 147456 bytes of data written
    INFO: Max_sub_size=100
    INFO: 184320 bytes of data written
    INFO: found existing substream ID 0x20 (DVD-Video 0)
    INFO: 1 subtitles added, 0 subtitles skipped, stream: 33, offset: 0.50
    Generating menu 2 of 3
    Create menu MPEG
    Executing command: spumux -P -s 0 "C:\Users\User\AppData\Local\Temp\dvd-tmp\menu1-1.mpg_spumux.xml"
    INFO: 47104 bytes of data written
    INFO: 94208 bytes of data written
    INFO: 139264 bytes of data written
    INFO: 186368 bytes of data written
    INFO: Max_sub_size=5320
    Executing command: spumux -P -s 1 "C:\Users\User\AppData\Local\Temp\dvd-tmp\menu1-1.mpg_spumux.xml"
    INFO: 49152 bytes of data written
    INFO: 96256 bytes of data written
    INFO: 145408 bytes of data written
    INFO: 192512 bytes of data written
    INFO: Max_sub_size=4012
    INFO: 239616 bytes of data written
    Generating menu 3 of 3
    Create menu MPEG
    Executing command: spumux -P -s 0 "C:\Users\User\AppData\Local\Temp\dvd-tmp\menu1-2.mpg_spumux.xml"
    INFO: 45056 bytes of data written
    INFO: 88064 bytes of data written
    INFO: 131072 bytes of data written
    INFO: 174080 bytes of data written
    INFO: Max_sub_size=3076
    Executing command: spumux -P -s 1 "C:\Users\User\AppData\Local\Temp\dvd-tmp\menu1-2.mpg_spumux.xml"
    INFO: 90112 bytes of data written
    INFO: 135168 bytes of data written
    INFO: 180224 bytes of data written
    INFO: Max_sub_size=2324
    INFO: 225280 bytes of data written
    May 2013
    EDM, USA
    Generating DVD
    Executing command: dvdauthor -o  "C:\Users\User\AppData\Local\Temp\dvd-out" -x  "C:\Users\User\AppData\Local\Temp\dvd-tmp\dvdauthor.xml"
    DVDAuthor::dvdauthor, version 0.7.1.
    INFO: dvdauthor creating VTS
    STAT: Picking VTS 01
    STAT: Processing C:\Users\User\AppData\Local\Temp\dvd-tmp\menu1-0.mpg...
    INFO: Video pts = 0.500 .. 0.933
    INFO: Audio[0] pts = 0.500 .. 0.916
    INFO: Audio[32] pts = 0.500 .. 0.500
    INFO: Audio[33] pts = 0.500 .. 0.500
    STAT: Processing C:\Users\User\AppData\Local\Temp\dvd-tmp\menu1-1.mpg...
    STAT: Processing C:\Users\User\AppData\Local\Temp\dvd-tmp\menu1-2.mpg...
    STAT: VOBU 3 at 0MB, 3 PGCs
    CHAPTERS: VTS[1/1] 0.000
    CHAPTERS: VTS[2/1] 0.000
    CHAPTERS: VTS[3/1] 0.000
    INFO: Generating VTSM with the following video attributes:
    INFO: MPEG version: mpeg2
    INFO: TV standard: ntsc
    INFO: Aspect ratio: 16:9
    INFO: Resolution: 720x480
    INFO: Audio ch 0 format: ac3/2ch,  48khz drc, 'en'
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-1.mpg...
    WARN: not a valid DVD frame rate: 0x01
    WARN: attempt to update frame rate from 30000.0/1001.0 (NTSC VIDEO) to  24000.0/1001.0 (NTSC 3:2 pulldown converted FILM); skipping
    WARN: Unknown AC3 sample rate: 1
    WARN: Discontinuity of 509 in audio channel 0; please remultiplex input.
    WARN: Previous sector: 0.178 - 0.242
    WARN: Current sector: 0.247 - 0.279
    WARN: Discontinuity of 255 in audio channel 0; please remultiplex input.
    WARN: Previous sector: 0.247 - 0.279
    WARN: Current sector: 0.282 - 0.314
    WARN: Previous sector: 0.421 - 0.453
    WARN: Previous sector: 0.595 - 0.627
    WARN: Previous sector: 0.770 - 0.802
    WARN: Previous sector: 0.944 - 0.976
    STAT: VOBU 16 at 1MB, 57 PGCs
    WARN: Previous sector: 9.164 - 9.196
    STAT: VOBU 32 at 4MB, 57 PGCs
    WARN: Current sector: 18.185 - 18.217
    STAT: VOBU 48 at 7MB, 57 PGCs
    WARN: Previous sector: 27.171 - 27.203
    STAT: VOBU 64 at 11MB, 57 PGCs
    STAT: VOBU 80 at 15MB, 57 PGCs
    WARN: Previous sector: 45.178 - 45.242
    WARN: Current sector: 54.234 - 54.266
    STAT: VOBU 96 at 19MB, 57 PGCs
    STAT: VOBU 112 at 22MB, 57 PGCs
    STAT: VOBU 128 at 25MB, 57 PGCs
    WARN: Discontinuity of 254 in audio channel 0; please remultiplex input.
    STAT: VOBU 144 at 28MB, 57 PGCs
    WARN: Previous sector: 90.248 - 90.280
    STAT: VOBU 160 at 32MB, 57 PGCs
    STAT: VOBU 176 at 34MB, 57 PGCs
    STAT: VOBU 192 at 37MB, 57 PGCs
    INFO: Video pts = 0.186 .. 115.468
    INFO: Audio[0] pts = 0.178 .. 115.462
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday  Special\Cartoon Network Christmas\1 - Cow and Chicken Intro.mpg...
    STAT: VOBU 209 at 40MB, 57 PGCs
    STAT: VOBU 225 at 43MB, 57 PGCs
    STAT: VOBU 241 at 46MB, 57 PGCs
    INFO: Video pts = 0.186 .. 29.866
    INFO: Audio[0] pts = 0.178 .. 29.954
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday  Special\Cartoon Network Christmas\2 - Cow and Chicken - Cow's Dream  Catcher.mpg...
    STAT: VOBU 268 at 52MB, 57 PGCs
    STAT: VOBU 284 at 55MB, 57 PGCs
    STAT: VOBU 300 at 59MB, 57 PGCs
    WARN: Previous sector: 35.286 - 35.318
    STAT: VOBU 316 at 63MB, 57 PGCs
    STAT: VOBU 332 at 66MB, 57 PGCs
    STAT: VOBU 348 at 70MB, 57 PGCs
    STAT: VOBU 364 at 73MB, 57 PGCs
    STAT: VOBU 380 at 77MB, 57 PGCs
    STAT: VOBU 396 at 81MB, 57 PGCs
    STAT: VOBU 412 at 85MB, 57 PGCs
    STAT: VOBU 428 at 88MB, 57 PGCs
    STAT: VOBU 444 at 92MB, 57 PGCs
    WARN: Current sector: 125.356 - 125.388
    STAT: VOBU 460 at 96MB, 57 PGCs
    STAT: VOBU 476 at 99MB, 57 PGCs
    STAT: VOBU 492 at 103MB, 57 PGCs
    STAT: VOBU 508 at 107MB, 57 PGCs
    STAT: VOBU 524 at 110MB, 57 PGCs
    STAT: VOBU 540 at 114MB, 57 PGCs
    STAT: VOBU 556 at 117MB, 57 PGCs
    STAT: VOBU 572 at 121MB, 57 PGCs
    STAT: VOBU 588 at 125MB, 57 PGCs
    WARN: Previous sector: 215.427 - 215.459
    STAT: VOBU 604 at 128MB, 57 PGCs
    STAT: VOBU 620 at 132MB, 57 PGCs
    STAT: VOBU 636 at 136MB, 57 PGCs
    STAT: VOBU 652 at 139MB, 57 PGCs
    STAT: VOBU 668 at 143MB, 57 PGCs
    STAT: VOBU 684 at 147MB, 57 PGCs
    STAT: VOBU 700 at 150MB, 57 PGCs
    STAT: VOBU 716 at 153MB, 57 PGCs
    STAT: VOBU 732 at 157MB, 57 PGCs
    WARN: Previous sector: 305.497 - 305.529
    STAT: VOBU 748 at 161MB, 57 PGCs
    STAT: VOBU 764 at 164MB, 57 PGCs
    STAT: VOBU 780 at 168MB, 57 PGCs
    STAT: VOBU 796 at 171MB, 57 PGCs
    STAT: VOBU 812 at 175MB, 57 PGCs
    STAT: VOBU 828 at 179MB, 57 PGCs
    STAT: VOBU 844 at 182MB, 57 PGCs
    STAT: VOBU 860 at 186MB, 57 PGCs
    STAT: VOBU 876 at 189MB, 57 PGCs
    INFO: Video pts = 0.186 .. 393.095
    INFO: Audio[0] pts = 0.178 .. 393.161
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-2.mpg...
    WARN: Current sector: 2.720 - 2.752
    STAT: VOBU 904 at 195MB, 57 PGCs
    INFO: Video pts = 0.186 .. 16.444
    INFO: Audio[0] pts = 0.178 .. 16.577
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday  Special\Cartoon Network Christmas\3 - Cow and Chicken - Me An' My  Dog.mpg...
    STAT: VOBU 931 at 200MB, 57 PGCs
    STAT: VOBU 947 at 203MB, 57 PGCs
    STAT: VOBU 963 at 207MB, 57 PGCs
    STAT: VOBU 979 at 211MB, 57 PGCs
    STAT: VOBU 995 at 214MB, 57 PGCs
    STAT: VOBU 1011 at 218MB, 57 PGCs
    STAT: VOBU 1027 at 222MB, 57 PGCs
    WARN: Current sector: 76.490 - 76.522
    STAT: VOBU 1043 at 225MB, 57 PGCs
    STAT: VOBU 1059 at 229MB, 57 PGCs
    STAT: VOBU 1075 at 232MB, 57 PGCs
    STAT: VOBU 1091 at 236MB, 57 PGCs
    STAT: VOBU 1107 at 240MB, 57 PGCs
    STAT: VOBU 1123 at 243MB, 57 PGCs
    STAT: VOBU 1139 at 247MB, 57 PGCs
    STAT: VOBU 1155 at 251MB, 57 PGCs
    STAT: VOBU 1171 at 254MB, 57 PGCs
    WARN: Current sector: 166.560 - 166.592
    STAT: VOBU 1187 at 258MB, 57 PGCs
    STAT: VOBU 1203 at 261MB, 57 PGCs
    STAT: VOBU 1219 at 265MB, 57 PGCs
    STAT: VOBU 1235 at 269MB, 57 PGCs
    STAT: VOBU 1251 at 273MB, 57 PGCs
    STAT: VOBU 1267 at 276MB, 57 PGCs
    STAT: VOBU 1283 at 280MB, 57 PGCs
    STAT: VOBU 1299 at 283MB, 57 PGCs
    STAT: VOBU 1315 at 287MB, 57 PGCs
    WARN: Current sector: 256.630 - 256.662
    STAT: VOBU 1331 at 291MB, 57 PGCs
    STAT: VOBU 1347 at 294MB, 57 PGCs
    STAT: VOBU 1363 at 298MB, 57 PGCs
    STAT: VOBU 1379 at 302MB, 57 PGCs
    STAT: VOBU 1395 at 305MB, 57 PGCs
    STAT: VOBU 1411 at 309MB, 57 PGCs
    STAT: VOBU 1427 at 313MB, 57 PGCs
    STAT: VOBU 1443 at 316MB, 57 PGCs
    STAT: VOBU 1459 at 320MB, 57 PGCs
    STAT: VOBU 1475 at 324MB, 57 PGCs
    WARN: Previous sector: 346.701 - 346.733
    WARN: Current sector: 346.735 - 346.767
    STAT: VOBU 1491 at 327MB, 57 PGCs
    STAT: VOBU 1507 at 331MB, 57 PGCs
    STAT: VOBU 1523 at 335MB, 57 PGCs
    STAT: VOBU 1539 at 338MB, 57 PGCs
    INFO: Video pts = 0.186 .. 394.196
    INFO: Audio[0] pts = 0.178 .. 394.171
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-3.mpg...
    STAT: VOBU 1567 at 343MB, 57 PGCs
    INFO: Video pts = 0.186 .. 15.251
    INFO: Audio[0] pts = 0.178 .. 15.256
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-4.mpg...
    STAT: VOBU 1593 at 346MB, 57 PGCs
    INFO: Video pts = 0.186 .. 9.554
    INFO: Audio[0] pts = 0.178 .. 9.611
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday  Special\Cartoon Network Christmas\4 - Dexter's Lab - Star Spangled  Sidekicks.mpg...
    STAT: VOBU 1612 at 350MB, 57 PGCs
    STAT: VOBU 1628 at 353MB, 57 PGCs
    STAT: VOBU 1644 at 356MB, 57 PGCs
    STAT: VOBU 1660 at 359MB, 57 PGCs
    STAT: VOBU 1676 at 362MB, 57 PGCs
    STAT: VOBU 1692 at 366MB, 57 PGCs
    STAT: VOBU 1708 at 369MB, 57 PGCs
    STAT: VOBU 1724 at 372MB, 57 PGCs
    STAT: VOBU 1740 at 376MB, 57 PGCs
    STAT: VOBU 1756 at 379MB, 57 PGCs
    STAT: VOBU 1772 at 382MB, 57 PGCs
    STAT: VOBU 1788 at 384MB, 57 PGCs
    STAT: VOBU 1804 at 387MB, 57 PGCs
    STAT: VOBU 1820 at 391MB, 57 PGCs
    STAT: VOBU 1836 at 395MB, 57 PGCs
    STAT: VOBU 1852 at 400MB, 57 PGCs
    STAT: VOBU 1868 at 404MB, 57 PGCs
    STAT: VOBU 1884 at 408MB, 57 PGCs
    STAT: VOBU 1900 at 410MB, 57 PGCs
    STAT: VOBU 1916 at 414MB, 57 PGCs
    STAT: VOBU 1932 at 418MB, 57 PGCs
    STAT: VOBU 1948 at 421MB, 57 PGCs
    STAT: VOBU 1964 at 425MB, 57 PGCs
    STAT: VOBU 1980 at 429MB, 57 PGCs
    STAT: VOBU 1996 at 433MB, 57 PGCs
    STAT: VOBU 2012 at 437MB, 57 PGCs
    STAT: VOBU 2028 at 440MB, 57 PGCs
    STAT: VOBU 2044 at 444MB, 57 PGCs
    STAT: VOBU 2060 at 447MB, 57 PGCs
    STAT: VOBU 2076 at 450MB, 57 PGCs
    STAT: VOBU 2092 at 454MB, 57 PGCs
    STAT: VOBU 2108 at 458MB, 57 PGCs
    STAT: VOBU 2124 at 461MB, 57 PGCs
    STAT: VOBU 2140 at 465MB, 57 PGCs
    STAT: VOBU 2156 at 469MB, 57 PGCs
    STAT: VOBU 2172 at 472MB, 57 PGCs
    STAT: VOBU 2188 at 476MB, 57 PGCs
    STAT: VOBU 2204 at 480MB, 57 PGCs
    STAT: VOBU 2220 at 483MB, 57 PGCs
    STAT: VOBU 2236 at 487MB, 57 PGCs
    STAT: VOBU 2252 at 490MB, 57 PGCs
    STAT: VOBU 2268 at 494MB, 57 PGCs
    STAT: VOBU 2284 at 497MB, 57 PGCs
    STAT: VOBU 2300 at 501MB, 57 PGCs
    INFO: Video pts = 0.186 .. 427.237
    INFO: Audio[0] pts = 0.178 .. 427.155
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday  Special\Cartoon Network Christmas\5 - Dexter's Lab - TV Super  Pals.mpg...
    STAT: VOBU 2323 at 504MB, 57 PGCs
    STAT: VOBU 2339 at 507MB, 57 PGCs
    STAT: VOBU 2355 at 510MB, 57 PGCs
    STAT: VOBU 2371 at 513MB, 57 PGCs
    STAT: VOBU 2387 at 515MB, 57 PGCs
    STAT: VOBU 2403 at 519MB, 57 PGCs
    STAT: VOBU 2419 at 523MB, 57 PGCs
    STAT: VOBU 2435 at 527MB, 57 PGCs
    STAT: VOBU 2451 at 530MB, 57 PGCs
    STAT: VOBU 2467 at 534MB, 57 PGCs
    STAT: VOBU 2483 at 538MB, 57 PGCs
    STAT: VOBU 2499 at 541MB, 57 PGCs
    STAT: VOBU 2515 at 545MB, 57 PGCs
    STAT: VOBU 2531 at 549MB, 57 PGCs
    STAT: VOBU 2547 at 552MB, 57 PGCs
    STAT: VOBU 2563 at 556MB, 57 PGCs
    STAT: VOBU 2579 at 559MB, 57 PGCs
    STAT: VOBU 2595 at 563MB, 57 PGCs
    STAT: VOBU 2611 at 566MB, 57 PGCs
    STAT: VOBU 2627 at 570MB, 57 PGCs
    STAT: VOBU 2643 at 573MB, 57 PGCs
    STAT: VOBU 2659 at 577MB, 57 PGCs
    STAT: VOBU 2675 at 581MB, 57 PGCs
    STAT: VOBU 2691 at 584MB, 57 PGCs
    STAT: VOBU 2707 at 588MB, 57 PGCs
    STAT: VOBU 2723 at 592MB, 57 PGCs
    STAT: VOBU 2739 at 596MB, 57 PGCs
    STAT: VOBU 2755 at 598MB, 57 PGCs
    STAT: VOBU 2771 at 601MB, 57 PGCs
    STAT: VOBU 2787 at 605MB, 57 PGCs
    STAT: VOBU 2803 at 609MB, 57 PGCs
    STAT: VOBU 2819 at 613MB, 57 PGCs
    STAT: VOBU 2835 at 617MB, 57 PGCs
    STAT: VOBU 2851 at 620MB, 57 PGCs
    STAT: VOBU 2867 at 623MB, 57 PGCs
    STAT: VOBU 2883 at 626MB, 57 PGCs
    STAT: VOBU 2899 at 630MB, 57 PGCs
    STAT: VOBU 2915 at 634MB, 57 PGCs
    STAT: VOBU 2931 at 638MB, 57 PGCs
    STAT: VOBU 2947 at 641MB, 57 PGCs
    STAT: VOBU 2963 at 645MB, 57 PGCs
    STAT: VOBU 2979 at 648MB, 57 PGCs
    STAT: VOBU 2995 at 651MB, 57 PGCs
    STAT: VOBU 3011 at 655MB, 57 PGCs
    INFO: Video pts = 0.186 .. 425.219
    INFO: Audio[0] pts = 0.178 .. 425.170
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday  Special\Cartoon Network Christmas\6 - Dexter's Lab - Game Over.mpg...
    STAT: VOBU 3035 at 658MB, 57 PGCs
    STAT: VOBU 3051 at 662MB, 57 PGCs
    STAT: VOBU 3067 at 665MB, 57 PGCs
    STAT: VOBU 3083 at 669MB, 57 PGCs
    STAT: VOBU 3099 at 673MB, 57 PGCs
    STAT: VOBU 3115 at 676MB, 57 PGCs
    STAT: VOBU 3131 at 678MB, 57 PGCs
    STAT: VOBU 3147 at 681MB, 57 PGCs
    STAT: VOBU 3163 at 685MB, 57 PGCs
    STAT: VOBU 3179 at 689MB, 57 PGCs
    STAT: VOBU 3195 at 692MB, 57 PGCs
    STAT: VOBU 3211 at 695MB, 57 PGCs
    STAT: VOBU 3227 at 700MB, 57 PGCs
    STAT: VOBU 3243 at 704MB, 57 PGCs
    STAT: VOBU 3259 at 707MB, 57 PGCs
    STAT: VOBU 3275 at 711MB, 57 PGCs
    STAT: VOBU 3291 at 715MB, 57 PGCs
    STAT: VOBU 3307 at 720MB, 57 PGCs
    STAT: VOBU 3323 at 725MB, 57 PGCs
    STAT: VOBU 3339 at 727MB, 57 PGCs
    STAT: VOBU 3355 at 730MB, 57 PGCs
    STAT: VOBU 3371 at 733MB, 57 PGCs
    STAT: VOBU 3387 at 736MB, 57 PGCs
    STAT: VOBU 3403 at 739MB, 57 PGCs
    STAT: VOBU 3419 at 742MB, 57 PGCs
    STAT: VOBU 3435 at 746MB, 57 PGCs
    STAT: VOBU 3451 at 750MB, 57 PGCs
    STAT: VOBU 3467 at 753MB, 57 PGCs
    STAT: VOBU 3483 at 756MB, 57 PGCs
    STAT: VOBU 3499 at 759MB, 57 PGCs
    STAT: VOBU 3515 at 762MB, 57 PGCs
    STAT: VOBU 3531 at 765MB, 57 PGCs
    STAT: VOBU 3547 at 769MB, 57 PGCs
    STAT: VOBU 3563 at 772MB, 57 PGCs
    STAT: VOBU 3579 at 776MB, 57 PGCs
    STAT: VOBU 3595 at 779MB, 57 PGCs
    STAT: VOBU 3611 at 782MB, 57 PGCs
    STAT: VOBU 3627 at 784MB, 57 PGCs
    STAT: VOBU 3643 at 787MB, 57 PGCs
    STAT: VOBU 3659 at 791MB, 57 PGCs
    STAT: VOBU 3675 at 795MB, 57 PGCs
    STAT: VOBU 3691 at 800MB, 57 PGCs
    STAT: VOBU 3707 at 805MB, 57 PGCs
    STAT: VOBU 3723 at 808MB, 57 PGCs
    INFO: Video pts = 0.186 .. 431.133
    INFO: Audio[0] pts = 0.178 .. 431.056
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-5.mpg...
    STAT: VOBU 3742 at 813MB, 57 PGCs
    STAT: VOBU 3758 at 815MB, 57 PGCs
    STAT: VOBU 3774 at 818MB, 57 PGCs
    STAT: VOBU 3790 at 821MB, 57 PGCs
    INFO: Video pts = 0.186 .. 43.538
    INFO: Audio[0] pts = 0.178 .. 43.573
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday  Special\Cartoon Network Christmas\7 - Johnny Bravo Intro.mpg...
    STAT: VOBU 3816 at 828MB, 57 PGCs
    STAT: VOBU 3832 at 832MB, 57 PGCs
    INFO: Video pts = 0.186 .. 18.888
    INFO: Audio[0] pts = 0.178 .. 30.163
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday  Special\Cartoon Network Christmas\8 - Johnny Bravo - I Used to be  Funny.mpg...
    STAT: VOBU 3848 at 835MB, 57 PGCs
    STAT: VOBU 3864 at 837MB, 57 PGCs
    STAT: VOBU 3880 at 840MB, 57 PGCs
    STAT: VOBU 3896 at 844MB, 57 PGCs
    STAT: VOBU 3912 at 848MB, 57 PGCs
    STAT: VOBU 3928 at 850MB, 57 PGCs
    STAT: VOBU 3944 at 854MB, 57 PGCs
    STAT: VOBU 3960 at 858MB, 57 PGCs
    STAT: VOBU 3976 at 863MB, 57 PGCs
    STAT: VOBU 3992 at 867MB, 57 PGCs
    STAT: VOBU 4008 at 871MB, 57 PGCs
    STAT: VOBU 4024 at 875MB, 57 PGCs
    STAT: VOBU 4040 at 878MB, 57 PGCs
    STAT: VOBU 4056 at 882MB, 57 PGCs
    STAT: VOBU 4072 at 885MB, 57 PGCs
    STAT: VOBU 4088 at 888MB, 57 PGCs
    STAT: VOBU 4104 at 894MB, 57 PGCs
    STAT: VOBU 4120 at 898MB, 57 PGCs
    STAT: VOBU 4136 at 901MB, 57 PGCs
    STAT: VOBU 4152 at 905MB, 57 PGCs
    STAT: VOBU 4168 at 909MB, 57 PGCs
    STAT: VOBU 4184 at 912MB, 57 PGCs
    STAT: VOBU 4200 at 916MB, 57 PGCs
    STAT: VOBU 4216 at 919MB, 57 PGCs
    STAT: VOBU 4232 at 923MB, 57 PGCs
    STAT: VOBU 4248 at 927MB, 57 PGCs
    STAT: VOBU 4264 at 931MB, 57 PGCs
    STAT: VOBU 4280 at 934MB, 57 PGCs
    STAT: VOBU 4296 at 938MB, 57 PGCs
    STAT: VOBU 4312 at 941MB, 57 PGCs
    STAT: VOBU 4328 at 945MB, 57 PGCs
    STAT: VOBU 4344 at 948MB, 57 PGCs
    STAT: VOBU 4360 at 953MB, 57 PGCs
    STAT: VOBU 4376 at 956MB, 57 PGCs
    STAT: VOBU 4392 at 959MB, 57 PGCs
    STAT: VOBU 4408 at 962MB, 57 PGCs
    STAT: VOBU 4424 at 967MB, 57 PGCs
    STAT: VOBU 4440 at 971MB, 57 PGCs
    STAT: VOBU 4456 at 974MB, 57 PGCs
    INFO: Video pts = 0.186 .. 393.229
    INFO: Audio[0] pts = 0.178 .. 392.011
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-6.mpg...
    STAT: VOBU 4479 at 979MB, 57 PGCs
    INFO: Video pts = 0.186 .. 9.862
    INFO: Audio[0] pts = 0.178 .. 9.855
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday  Special\Cartoon Network Christmas\9 - Johnny Bravo - My Fair Dork.mpg...
    STAT: VOBU 4500 at 982MB, 57 PGCs
    STAT: VOBU 4516 at 986MB, 57 PGCs
    STAT: VOBU 4532 at 989MB, 57 PGCs
    STAT: VOBU 4548 at 992MB, 57 PGCs
    STAT: VOBU 4564 at 997MB, 57 PGCs
    STAT: VOBU 4580 at 1000MB, 57 PGCs
    STAT: VOBU 4596 at 1003MB, 57 PGCs
    STAT: VOBU 4612 at 1007MB, 57 PGCs
    STAT: VOBU 4628 at 1009MB, 57 PGCs
    STAT: VOBU 4644 at 1012MB, 57 PGCs
    STAT: VOBU 4660 at 1015MB, 57 PGCs
    STAT: VOBU 4676 at 1018MB, 57 PGCs
    STAT: VOBU 4692 at 1021MB, 57 PGCs
    STAT: VOBU 4708 at 1025MB, 57 PGCs
    STAT: VOBU 4724 at 1029MB, 57 PGCs
    STAT: VOBU 4740 at 1033MB, 57 PGCs
    STAT: VOBU 4756 at 1036MB, 57 PGCs
    STAT: VOBU 4772 at 1039MB, 57 PGCs
    STAT: VOBU 4788 at 1042MB, 57 PGCs
    STAT: VOBU 4804 at 1046MB, 57 PGCs
    STAT: VOBU 4820 at 1049MB, 57 PGCs
    STAT: VOBU 4836 at 1052MB, 57 PGCs
    STAT: VOBU 4852 at 1055MB, 57 PGCs
    STAT: VOBU 4868 at 1057MB, 57 PGCs
    STAT: VOBU 4884 at 1060MB, 57 PGCs
    STAT: VOBU 4900 at 1063MB, 57 PGCs
    STAT: VOBU 4916 at 1066MB, 57 PGCs
    STAT: VOBU 4932 at 1071MB, 57 PGCs
    STAT: VOBU 4948 at 1075MB, 57 PGCs
    STAT: VOBU 4964 at 1077MB, 57 PGCs
    STAT: VOBU 4980 at 1080MB, 57 PGCs
    STAT: VOBU 4996 at 1083MB, 57 PGCs
    STAT: VOBU 5012 at 1086MB, 57 PGCs
    STAT: VOBU 5028 at 1090MB, 57 PGCs
    STAT: VOBU 5044 at 1093MB, 57 PGCs
    STAT: VOBU 5060 at 1096MB, 57 PGCs
    STAT: VOBU 5076 at 1099MB, 57 PGCs
    STAT: VOBU 5092 at 1102MB, 57 PGCs
    STAT: VOBU 5108 at 1105MB, 57 PGCs
    INFO: Video pts = 0.186 .. 393.212
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-7.mpg...
    STAT: VOBU 5131 at 1110MB, 57 PGCs
    INFO: Video pts = 0.186 .. 9.595
    INFO: Audio[0] pts = 0.178 .. 9.579
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-8.mpg...
    INFO: Video pts = 0.186 .. 5.408
    INFO: Audio[0] pts = 0.178 .. 5.399
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday  Special\Cartoon Network Christmas\10 - Johnny Bravo - Twas the  Night.mpg...
    STAT: VOBU 5159 at 1114MB, 57 PGCs
    STAT: VOBU 5175 at 1118MB, 57 PGCs
    STAT: VOBU 5191 at 1122MB, 57 PGCs
    STAT: VOBU 5207 at 1124MB, 57 PGCs
    STAT: VOBU 5223 at 1127MB, 57 PGCs
    STAT: VOBU 5239 at 1130MB, 57 PGCs
    STAT: VOBU 5255 at 1133MB, 57 PGCs
    STAT: VOBU 5271 at 1137MB, 57 PGCs
    STAT: VOBU 5287 at 1141MB, 57 PGCs
    STAT: VOBU 5303 at 1144MB, 57 PGCs
    STAT: VOBU 5319 at 1147MB, 57 PGCs
    STAT: VOBU 5335 at 1150MB, 57 PGCs
    STAT: VOBU 5351 at 1155MB, 57 PGCs
    STAT: VOBU 5367 at 1161MB, 57 PGCs
    STAT: VOBU 5383 at 1165MB, 57 PGCs
    STAT: VOBU 5399 at 1170MB, 57 PGCs
    STAT: VOBU 5415 at 1173MB, 57 PGCs
    STAT: VOBU 5431 at 1177MB, 57 PGCs
    STAT: VOBU 5447 at 1180MB, 57 PGCs
    STAT: VOBU 5463 at 1183MB, 57 PGCs
    STAT: VOBU 5479 at 1187MB, 57 PGCs
    STAT: VOBU 5495 at 1190MB, 57 PGCs
    STAT: VOBU 5511 at 1194MB, 57 PGCs
    STAT: VOBU 5527 at 1198MB, 57 PGCs
    STAT: VOBU 5543 at 1202MB, 57 PGCs
    STAT: VOBU 5559 at 1205MB, 57 PGCs
    STAT: VOBU 5575 at 1208MB, 57 PGCs
    STAT: VOBU 5591 at 1212MB, 57 PGCs
    STAT: VOBU 5607 at 1216MB, 57 PGCs
    STAT: VOBU 5623 at 1220MB, 57 PGCs
    STAT: VOBU 5639 at 1224MB, 57 PGCs
    STAT: VOBU 5655 at 1228MB, 57 PGCs
    STAT: VOBU 5671 at 1232MB, 57 PGCs
    STAT: VOBU 5687 at 1235MB, 57 PGCs
    STAT: VOBU 5703 at 1239MB, 57 PGCs
    STAT: VOBU 5719 at 1243MB, 57 PGCs
    STAT: VOBU 5735 at 1245MB, 57 PGCs
    STAT: VOBU 5751 at 1248MB, 57 PGCs
    STAT: VOBU 5767 at 1252MB, 57 PGCs
    INFO: Video pts = 0.186 .. 392.111
    INFO: Audio[0] pts = 0.178 .. 392.186
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-9.mpg...
    STAT: VOBU 5788 at 1256MB, 57 PGCs
    STAT: VOBU 5804 at 1258MB, 57 PGCs
    STAT: VOBU 5820 at 1260MB, 57 PGCs
    STAT: VOBU 5836 at 1263MB, 57 PGCs
    STAT: VOBU 5852 at 1266MB, 57 PGCs
    STAT: VOBU 5868 at 1269MB, 57 PGCs
    INFO: Video pts = 0.186 .. 61.706
    INFO: Audio[0] pts = 0.178 .. 61.754
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday  Special\Cartoon Network Christmas\11 - Dexter's Lab - Dexter and  Computress Get Mandark!.mpg...
    STAT: VOBU 5892 at 1273MB, 57 PGCs
    WARN: Current sector: 12.333 - 12.365
    STAT: VOBU 5908 at 1276MB, 57 PGCs
    STAT: VOBU 5924 at 1279MB, 57 PGCs
    STAT: VOBU 5940 at 1282MB, 57 PGCs
    STAT: VOBU 5956 at 1286MB, 57 PGCs
    STAT: VOBU 5972 at 1289MB, 57 PGCs
    STAT: VOBU 5988 at 1293MB, 57 PGCs
    STAT: VOBU 6004 at 1297MB, 57 PGCs
    STAT: VOBU 6020 at 1300MB, 57 PGCs
    STAT: VOBU 6036 at 1304MB, 57 PGCs
    STAT: VOBU 6052 at 1307MB, 57 PGCs
    STAT: VOBU 6068 at 1311MB, 57 PGCs
    STAT: VOBU 6084 at 1315MB, 57 PGCs
    STAT: VOBU 6100 at 1318MB, 57 PGCs
    STAT: VOBU 6116 at 1322MB, 57 PGCs
    STAT: VOBU 6132 at 1326MB, 57 PGCs
    STAT: VOBU 6148 at 1329MB, 57 PGCs
    STAT: VOBU 6164 at 1333MB, 57 PGCs
    STAT: VOBU 6180 at 1337MB, 57 PGCs
    STAT: VOBU 6196 at 1340MB, 57 PGCs
    STAT: VOBU 6212 at 1344MB, 57 PGCs
    STAT: VOBU 6228 at 1348MB, 57 PGCs
    STAT: VOBU 6244 at 1351MB, 57 PGCs
    STAT: VOBU 6260 at 1355MB, 57 PGCs
    STAT: VOBU 6276 at 1358MB, 57 PGCs
    STAT: VOBU 6292 at 1362MB, 57 PGCs
    STAT: VOBU 6308 at 1366MB, 57 PGCs
    STAT: VOBU 6324 at 1369MB, 57 PGCs
    STAT: VOBU 6340 at 1372MB, 57 PGCs
    STAT: VOBU 6356 at 1376MB, 57 PGCs
    STAT: VOBU 6372 at 1379MB, 57 PGCs
    STAT: VOBU 6388 at 1383MB, 57 PGCs
    STAT: VOBU 6404 at 1387MB, 57 PGCs
    STAT: VOBU 6420 at 1390MB, 57 PGCs
    STAT: VOBU 6436 at 1394MB, 57 PGCs
    STAT: VOBU 6452 at 1398MB, 57 PGCs
    STAT: VOBU 6468 at 1401MB, 57 PGCs
    STAT: VOBU 6484 at 1405MB, 57 PGCs
    STAT: VOBU 6500 at 1407MB, 57 PGCs
    STAT: VOBU 6516 at 1411MB, 57 PGCs
    STAT: VOBU 6532 at 1415MB, 57 PGCs
    STAT: VOBU 6548 at 1417MB, 57 PGCs
    INFO: Video pts = 0.186 .. 403.022
    INFO: Audio[0] pts = 0.178 .. 403.679
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-10.mpg...
    STAT: VOBU 6564 at 1420MB, 57 PGCs
    INFO: Video pts = 0.186 .. 10.096
    INFO: Audio[0] pts = 0.178 .. 10.098
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday  Special\Cartoon Network Christmas\12 - Dexter's Lab - Pain in the  Mouth.mpg...
    STAT: VOBU 6583 at 1423MB, 57 PGCs
    STAT: VOBU 6599 at 1426MB, 57 PGCs
    STAT: VOBU 6615 at 1429MB, 57 PGCs
    STAT: VOBU 6631 at 1432MB, 57 PGCs
    STAT: VOBU 6647 at 1435MB, 57 PGCs
    STAT: VOBU 6663 at 1439MB, 57 PGCs
    STAT: VOBU 6679 at 1442MB, 57 PGCs
    STAT: VOBU 6695 at 1445MB, 57 PGCs
    STAT: VOBU 6711 at 1448MB, 57 PGCs
    STAT: VOBU 6727 at 1452MB, 57 PGCs
    STAT: VOBU 6743 at 1456MB, 57 PGCs
    STAT: VOBU 6759 at 1459MB, 57 PGCs
    STAT: VOBU 6775 at 1463MB, 57 PGCs
    STAT: VOBU 6791 at 1466MB, 57 PGCs
    STAT: VOBU 6807 at 1470MB, 57 PGCs
    STAT: VOBU 6823 at 1474MB, 57 PGCs
    STAT: VOBU 6839 at 1477MB, 57 PGCs
    STAT: VOBU 6855 at 1480MB, 57 PGCs
    STAT: VOBU 6871 at 1483MB, 57 PGCs
    STAT: VOBU 6887 at 1487MB, 57 PGCs
    STAT: VOBU 6903 at 1491MB, 57 PGCs
    STAT: VOBU 6919 at 1494MB, 57 PGCs
    STAT: VOBU 6935 at 1498MB, 57 PGCs
    STAT: VOBU 6951 at 1502MB, 57 PGCs
    STAT: VOBU 6967 at 1505MB, 57 PGCs
    STAT: VOBU 6983 at 1509MB, 57 PGCs
    STAT: VOBU 6999 at 1512MB, 57 PGCs
    STAT: VOBU 7015 at 1516MB, 57 PGCs
    STAT: VOBU 7031 at 1519MB, 57 PGCs
    STAT: VOBU 7047 at 1523MB, 57 PGCs
    STAT: VOBU 7063 at 1527MB, 57 PGCs
    STAT: VOBU 7079 at 1530MB, 57 PGCs
    STAT: VOBU 7095 at 1534MB, 57 PGCs
    STAT: VOBU 7111 at 1537MB, 57 PGCs
    STAT: VOBU 7127 at 1540MB, 57 PGCs
    STAT: VOBU 7143 at 1544MB, 57 PGCs
    STAT: VOBU 7159 at 1548MB, 57 PGCs
    STAT: VOBU 7175 at 1551MB, 57 PGCs
    STAT: VOBU 7191 at 1555MB, 57 PGCs
    STAT: VOBU 7207 at 1558MB, 57 PGCs
    STAT: VOBU 7223 at 1561MB, 57 PGCs
    STAT: VOBU 7239 at 1564MB, 57 PGCs
    STAT: VOBU 7255 at 1567MB, 57 PGCs
    STAT: VOBU 7271 at 1571MB, 57 PGCs
    STAT: VOBU 7287 at 1575MB, 57 PGCs
    STAT: VOBU 7303 at 1578MB, 57 PGCs
    STAT: VOBU 7319 at 1582MB, 57 PGCs
    STAT: VOBU 7335 at 1585MB, 57 PGCs
    INFO: Video pts = 0.186 .. 450.611
    INFO: Audio[0] pts = 0.178 .. 450.665
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-11.mpg...
    STAT: VOBU 7352 at 1588MB, 57 PGCs
    INFO: Video pts = 0.186 .. 9.412
    INFO: Audio[0] pts = 0.178 .. 9.405
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-12.mpg...
    INFO: Video pts = 0.186 .. 5.358
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday  Special\Cartoon Network Christmas\13 - Dexter's Lab - Dexter Vs. Santa's  Claws.mpg...
    STAT: VOBU 7379 at 1592MB, 57 PGCs
    STAT: VOBU 7395 at 1595MB, 57 PGCs
    STAT: VOBU 7411 at 1599MB, 57 PGCs
    WARN: Current sector: 35.147 - 35.179
    STAT: VOBU 7427 at 1602MB, 57 PGCs
    STAT: VOBU 7443 at 1606MB, 57 PGCs
    STAT: VOBU 7459 at 1610MB, 57 PGCs
    STAT: VOBU 7475 at 1613MB, 57 PGCs
    STAT: VOBU 7491 at 1617MB, 57 PGCs
    STAT: VOBU 7507 at 1621MB, 57 PGCs
    STAT: VOBU 7523 at 1624MB, 57 PGCs
    STAT: VOBU 7539 at 1627MB, 57 PGCs
    STAT: VOBU 7555 at 1631MB, 57 PGCs
    STAT: VOBU 7571 at 1635MB, 57 PGCs
    STAT: VOBU 7587 at 1638MB, 57 PGCs
    STAT: VOBU 7603 at 1642MB, 57 PGCs
    STAT: VOBU 7619 at 1645MB, 57 PGCs
    STAT: VOBU 7635 at 1649MB, 57 PGCs
    STAT: VOBU 7651 at 1653MB, 57 PGCs
    STAT: VOBU 7667 at 1656MB, 57 PGCs
    STAT: VOBU 7683 at 1660MB, 57 PGCs
    STAT: VOBU 7699 at 1663MB, 57 PGCs
    STAT: VOBU 7715 at 1667MB, 57 PGCs
    STAT: VOBU 7731 at 1670MB, 57 PGCs
    STAT: VOBU 7747 at 1674MB, 57 PGCs
    STAT: VOBU 7763 at 1677MB, 57 PGCs
    STAT: VOBU 7779 at 1681MB, 57 PGCs
    STAT: VOBU 7795 at 1684MB, 57 PGCs
    STAT: VOBU 7811 at 1688MB, 57 PGCs
    STAT: VOBU 7827 at 1691MB, 57 PGCs
    STAT: VOBU 7843 at 1695MB, 57 PGCs
    STAT: VOBU 7859 at 1698MB, 57 PGCs
    STAT: VOBU 7875 at 1702MB, 57 PGCs
    STAT: VOBU 7891 at 1705MB, 57 PGCs
    STAT: VOBU 7907 at 1708MB, 57 PGCs
    STAT: VOBU 7923 at 1711MB, 57 PGCs
    STAT: VOBU 7939 at 1715MB, 57 PGCs
    STAT: VOBU 7955 at 1718MB, 57 PGCs
    STAT: VOBU 7971 at 1722MB, 57 PGCs
    STAT: VOBU 7987 at 1726MB, 57 PGCs
    STAT: VOBU 8003 at 1729MB, 57 PGCs
    STAT: VOBU 8019 at 1733MB, 57 PGCs
    STAT: VOBU 8035 at 1736MB, 57 PGCs
    STAT: VOBU 8051 at 1740MB, 57 PGCs
    STAT: VOBU 8067 at 1744MB, 57 PGCs
    STAT: VOBU 8083 at 1748MB, 57 PGCs
    STAT: VOBU 8099 at 1751MB, 57 PGCs
    INFO: Video pts = 0.186 .. 448.542
    INFO: Audio[0] pts = 0.178 .. 448.645
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-13.mpg...
    STAT: VOBU 8126 at 1757MB, 57 PGCs
    STAT: VOBU 8142 at 1760MB, 57 PGCs
    STAT: VOBU 8158 at 1762MB, 57 PGCs
    STAT: VOBU 8174 at 1765MB, 57 PGCs
    INFO: Video pts = 0.186 .. 40.668
    INFO: Audio[0] pts = 0.178 .. 40.647
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday  Special\Cartoon Network Christmas\14 - The Powerpuff Girls Intro.mpg...
    STAT: VOBU 8196 at 1767MB, 57 PGCs
    STAT: VOBU 8212 at 1770MB, 57 PGCs
    STAT: VOBU 8228 at 1774MB, 57 PGCs
    STAT: VOBU 8244 at 1778MB, 57 PGCs
    STAT: VOBU 8260 at 1782MB, 57 PGCs
    STAT: VOBU 8276 at 1786MB, 57 PGCs
    STAT: VOBU 8292 at 1788MB, 57 PGCs
    INFO: Video pts = 0.186 .. 63.182
    INFO: Audio[0] pts = 0.178 .. 63.182
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday  Special\Cartoon Network Christmas\15 - Powerpuff Girls - Hot Air  Buffoon.mpg...
    STAT: VOBU 8308 at 1790MB, 57 PGCs
    STAT: VOBU 8324 at 1794MB, 57 PGCs
    STAT: VOBU 8340 at 1798MB, 57 PGCs
    STAT: VOBU 8356 at 1802MB, 57 PGCs
    STAT: VOBU 8372 at 1805MB, 57 PGCs
    STAT: VOBU 8388 at 1808MB, 57 PGCs
    STAT: VOBU 8404 at 1811MB, 57 PGCs
    STAT: VOBU 8420 at 1814MB, 57 PGCs
    STAT: VOBU 8436 at 1817MB, 57 PGCs
    STAT: VOBU 8452 at 1820MB, 57 PGCs
    STAT: VOBU 8468 at 1823MB, 57 PGCs
    STAT: VOBU 8484 at 1827MB, 57 PGCs
    STAT: VOBU 8500 at 1832MB, 57 PGCs
    STAT: VOBU 8516 at 1834MB, 57 PGCs
    STAT: VOBU 8532 at 1837MB, 57 PGCs
    STAT: VOBU 8548 at 1839MB, 57 PGCs
    STAT: VOBU 8564 at 1843MB, 57 PGCs
    STAT: VOBU 8580 at 1849MB, 57 PGCs
    STAT: VOBU 8596 at 1852MB, 57 PGCs
    STAT: VOBU 8612 at 1855MB, 57 PGCs
    STAT: VOBU 8628 at 1858MB, 57 PGCs
    STAT: VOBU 8644 at 1862MB, 57 PGCs
    STAT: VOBU 8660 at 1867MB, 57 PGCs
    STAT: VOBU 8676 at 1870MB, 57 PGCs
    STAT: VOBU 8692 at 1874MB, 57 PGCs
    STAT: VOBU 8708 at 1878MB, 57 PGCs
    STAT: VOBU 8724 at 1881MB, 57 PGCs
    STAT: VOBU 8740 at 1885MB, 57 PGCs
    STAT: VOBU 8756 at 1889MB, 57 PGCs
    STAT: VOBU 8772 at 1891MB, 57 PGCs
    STAT: VOBU 8788 at 1895MB, 57 PGCs
    STAT: VOBU 8804 at 1898MB, 57 PGCs
    STAT: VOBU 8820 at 1903MB, 57 PGCs
    STAT: VOBU 8836 at 1906MB, 57 PGCs
    STAT: VOBU 8852 at 1910MB, 57 PGCs
    STAT: VOBU 8868 at 1913MB, 57 PGCs
    STAT: VOBU 8884 at 1918MB, 57 PGCs
    STAT: VOBU 8900 at 1922MB, 57 PGCs
    WARN: Current sector: 384.352 - 384.384
    STAT: VOBU 8916 at 1925MB, 57 PGCs
    STAT: VOBU 8932 at 1928MB, 57 PGCs
    STAT: VOBU 8948 at 1932MB, 57 PGCs
    STAT: VOBU 8964 at 1937MB, 57 PGCs
    STAT: VOBU 8980 at 1942MB, 57 PGCs
    STAT: VOBU 8996 at 1947MB, 57 PGCs
    STAT: VOBU 9012 at 1952MB, 57 PGCs
    STAT: VOBU 9028 at 1955MB, 57 PGCs
    STAT: VOBU 9044 at 1959MB, 57 PGCs
    STAT: VOBU 9060 at 1962MB, 57 PGCs
    STAT: VOBU 9076 at 1966MB, 57 PGCs
    STAT: VOBU 9092 at 1969MB, 57 PGCs
    STAT: VOBU 9108 at 1972MB, 57 PGCs
    STAT: VOBU 9124 at 1976MB, 57 PGCs
    STAT: VOBU 9140 at 1979MB, 57 PGCs
    STAT: VOBU 9156 at 1984MB, 57 PGCs
    STAT: VOBU 9172 at 1988MB, 57 PGCs
    STAT: VOBU 9188 at 1991MB, 57 PGCs
    STAT: VOBU 9204 at 1994MB, 57 PGCs
    STAT: VOBU 9220 at 1999MB, 57 PGCs
    STAT: VOBU 9236 at 2003MB, 57 PGCs
    INFO: Video pts = 0.186 .. 588.215
    INFO: Audio[0] pts = 0.178 .. 588.174
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-14.mpg...
    STAT: VOBU 9255 at 2006MB, 57 PGCs
    INFO: Video pts = 0.186 .. 9.337
    INFO: Audio[0] pts = 0.178 .. 9.367
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-15.mpg...
    INFO: Video pts = 0.186 .. 5.474
    INFO: Audio[0] pts = 0.178 .. 5.504
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday  Special\Cartoon Network Christmas\16 - Powerpuff Girls - Ploys R'  Us.mpg...
    STAT: VOBU 9283 at 2010MB, 57 PGCs
    STAT: VOBU 9299 at 2013MB, 57 PGCs
    STAT: VOBU 9315 at 2016MB, 57 PGCs
    STAT: VOBU 9331 at 2019MB, 57 PGCs
    STAT: VOBU 9347 at 2025MB, 57 PGCs
    STAT: VOBU 9363 at 2030MB, 57 PGCs
    STAT: VOBU 9379 at 2033MB, 57 PGCs
    STAT: VOBU 9395 at 2037MB, 57 PGCs
    STAT: VOBU 9411 at 2041MB, 57 PGCs
    STAT: VOBU 9427 at 2044MB, 57 PGCs
    STAT: VOBU 9443 at 2048MB, 57 PGCs
    STAT: VOBU 9459 at 2052MB, 57 PGCs
    STAT: VOBU 9475 at 2055MB, 57 PGCs
    STAT: VOBU 9491 at 2058MB, 57 PGCs
    STAT: VOBU 9507 at 2061MB, 57 PGCs
    STAT: VOBU 9523 at 2064MB, 57 PGCs
    STAT: VOBU 9539 at 2068MB, 57 PGCs
    STAT: VOBU 9555 at 2073MB, 57 PGCs
    STAT: VOBU 9571 at 2076MB, 57 PGCs
    STAT: VOBU 9587 at 2080MB, 57 PGCs
    STAT: VOBU 9603 at 2083MB, 57 PGCs
    STAT: VOBU 9619 at 2087MB, 57 PGCs
    STAT: VOBU 9635 at 2090MB, 57 PGCs
    STAT: VOBU 9651 at 2092MB, 57 PGCs
    STAT: VOBU 9667 at 2095MB, 57 PGCs
    STAT: VOBU 9683 at 2098MB, 57 PGCs
    STAT: VOBU 9699 at 2101MB, 57 PGCs
    STAT: VOBU 9715 at 2104MB, 57 PGCs
    STAT: VOBU 9731 at 2108MB, 57 PGCs
    STAT: VOBU 9747 at 2110MB, 57 PGCs
    STAT: VOBU 9763 at 2114MB, 57 PGCs
    STAT: VOBU 9779 at 2118MB, 57 PGCs
    STAT: VOBU 9795 at 2122MB, 57 PGCs
    STAT: VOBU 9811 at 2126MB, 57 PGCs
    STAT: VOBU 9827 at 2130MB, 57 PGCs
    STAT: VOBU 9843 at 2134MB, 57 PGCs
    STAT: VOBU 9859 at 2137MB, 57 PGCs
    STAT: VOBU 9875 at 2142MB, 57 PGCs
    STAT: VOBU 9891 at 2146MB, 57 PGCs
    STAT: VOBU 9907 at 2149MB, 57 PGCs
    STAT: VOBU 9923 at 2153MB, 57 PGCs
    STAT: VOBU 9939 at 2157MB, 57 PGCs
    STAT: VOBU 9955 at 2161MB, 57 PGCs
    STAT: VOBU 9971 at 2164MB, 57 PGCs
    STAT: VOBU 9987 at 2167MB, 57 PGCs
    STAT: VOBU 10003 at 2171MB, 57 PGCs
    STAT: VOBU 10019 at 2175MB, 57 PGCs
    STAT: VOBU 10035 at 2179MB, 57 PGCs
    STAT: VOBU 10051 at 2182MB, 57 PGCs
    STAT: VOBU 10067 at 2186MB, 57 PGCs
    STAT: VOBU 10083 at 2188MB, 57 PGCs
    STAT: VOBU 10099 at 2190MB, 57 PGCs
    STAT: VOBU 10115 at 2192MB, 57 PGCs
    STAT: VOBU 10131 at 2195MB, 57 PGCs
    STAT: VOBU 10147 at 2200MB, 57 PGCs
    STAT: VOBU 10163 at 2203MB, 57 PGCs
    STAT: VOBU 10179 at 2206MB, 57 PGCs
    STAT: VOBU 10195 at 2208MB, 57 PGCs
    STAT: VOBU 10211 at 2215MB, 57 PGCs
    STAT: VOBU 10227 at 2218MB, 57 PGCs
    STAT: VOBU 10243 at 2222MB, 57 PGCs
    STAT: VOBU 10259 at 2225MB, 57 PGCs
    STAT: VOBU 10275 at 2228MB, 57 PGCs
    STAT: VOBU 10291 at 2233MB, 57 PGCs
    STAT: VOBU 10307 at 2236MB, 57 PGCs
    STAT: VOBU 10323 at 2241MB, 57 PGCs
    STAT: VOBU 10339 at 2244MB, 57 PGCs
    STAT: VOBU 10355 at 2248MB, 57 PGCs
    STAT: VOBU 10371 at 2254MB, 57 PGCs
    WARN: Current sector: 682.879 - 682.911
    INFO: Video pts = 0.186 .. 686.180
    INFO: Audio[0] pts = 0.178 .. 686.185
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-16.mpg...
    STAT: VOBU 10393 at 2258MB, 57 PGCs
    STAT: VOBU 10409 at 2261MB, 57 PGCs
    STAT: VOBU 10425 at 2265MB, 57 PGCs
    STAT: VOBU 10441 at 2268MB, 57 PGCs
    STAT: VOBU 10457 at 2273MB, 57 PGCs
    STAT: VOBU 10473 at 2276MB, 57 PGCs
    STAT: VOBU 10489 at 2279MB, 57 PGCs
    STAT: VOBU 10505 at 2283MB, 57 PGCs
    INFO: Video pts = 0.186 .. 81.617
    INFO: Audio[0] pts = 0.178 .. 81.607
    May 2013
    EDM, USA
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday   Special\Cartoon Network Christmas\17 - Ed, Edd n Eddy Intro.mpg...
    STAT: VOBU 10531 at 2289MB, 57 PGCs
    STAT: VOBU 10547 at 2292MB, 57 PGCs
    STAT: VOBU 10563 at 2296MB, 57 PGCs
    INFO: Video pts = 0.186 .. 30.124
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday   Special\Cartoon Network Christmas\18 - Ed, Edd n Eddy - In Like   Ed.mpg...
    STAT: VOBU 10581 at 2300MB, 57 PGCs
    STAT: VOBU 10597 at 2303MB, 57 PGCs
    STAT: VOBU 10613 at 2307MB, 57 PGCs
    STAT: VOBU 10629 at 2311MB, 57 PGCs
    STAT: VOBU 10645 at 2314MB, 57 PGCs
    STAT: VOBU 10661 at 2318MB, 57 PGCs
    STAT: VOBU 10677 at 2322MB, 57 PGCs
    STAT: VOBU 10693 at 2325MB, 57 PGCs
    STAT: VOBU 10709 at 2329MB, 57 PGCs
    STAT: VOBU 10725 at 2333MB, 57 PGCs
    STAT: VOBU 10741 at 2336MB, 57 PGCs
    STAT: VOBU 10757 at 2340MB, 57 PGCs
    STAT: VOBU 10773 at 2344MB, 57 PGCs
    STAT: VOBU 10789 at 2347MB, 57 PGCs
    STAT: VOBU 10805 at 2351MB, 57 PGCs
    STAT: VOBU 10821 at 2354MB, 57 PGCs
    STAT: VOBU 10837 at 2358MB, 57 PGCs
    STAT: VOBU 10853 at 2362MB, 57 PGCs
    STAT: VOBU 10869 at 2365MB, 57 PGCs
    STAT: VOBU 10885 at 2369MB, 57 PGCs
    STAT: VOBU 10901 at 2373MB, 57 PGCs
    STAT: VOBU 10917 at 2376MB, 57 PGCs
    STAT: VOBU 10933 at 2380MB, 57 PGCs
    STAT: VOBU 10949 at 2384MB, 57 PGCs
    STAT: VOBU 10965 at 2387MB, 57 PGCs
    STAT: VOBU 10981 at 2391MB, 57 PGCs
    STAT: VOBU 10997 at 2395MB, 57 PGCs
    STAT: VOBU 11013 at 2399MB, 57 PGCs
    STAT: VOBU 11029 at 2402MB, 57 PGCs
    STAT: VOBU 11045 at 2406MB, 57 PGCs
    STAT: VOBU 11061 at 2409MB, 57 PGCs
    STAT: VOBU 11077 at 2413MB, 57 PGCs
    STAT: VOBU 11093 at 2417MB, 57 PGCs
    STAT: VOBU 11109 at 2421MB, 57 PGCs
    STAT: VOBU 11125 at 2424MB, 57 PGCs
    STAT: VOBU 11141 at 2428MB, 57 PGCs
    STAT: VOBU 11157 at 2431MB, 57 PGCs
    STAT: VOBU 11173 at 2435MB, 57 PGCs
    STAT: VOBU 11189 at 2439MB, 57 PGCs
    STAT: VOBU 11205 at 2443MB, 57 PGCs
    STAT: VOBU 11221 at 2446MB, 57 PGCs
    STAT: VOBU 11237 at 2450MB, 57 PGCs
    STAT: VOBU 11253 at 2453MB, 57 PGCs
    STAT: VOBU 11269 at 2457MB, 57 PGCs
    STAT: VOBU 11285 at 2461MB, 57 PGCs
    STAT: VOBU 11301 at 2464MB, 57 PGCs
    STAT: VOBU 11317 at 2468MB, 57 PGCs
    STAT: VOBU 11333 at 2472MB, 57 PGCs
    STAT: VOBU 11349 at 2475MB, 57 PGCs
    STAT: VOBU 11365 at 2479MB, 57 PGCs
    STAT: VOBU 11381 at 2483MB, 57 PGCs
    STAT: VOBU 11397 at 2486MB, 57 PGCs
    STAT: VOBU 11413 at 2490MB, 57 PGCs
    STAT: VOBU 11429 at 2494MB, 57 PGCs
    STAT: VOBU 11445 at 2497MB, 57 PGCs
    STAT: VOBU 11461 at 2501MB, 57 PGCs
    STAT: VOBU 11477 at 2505MB, 57 PGCs
    STAT: VOBU 11493 at 2509MB, 57 PGCs
    STAT: VOBU 11509 at 2512MB, 57 PGCs
    STAT: VOBU 11525 at 2516MB, 57 PGCs
    STAT: VOBU 11541 at 2519MB, 57 PGCs
    STAT: VOBU 11557 at 2523MB, 57 PGCs
    STAT: VOBU 11573 at 2527MB, 57 PGCs
    STAT: VOBU 11589 at 2530MB, 57 PGCs
    STAT: VOBU 11605 at 2534MB, 57 PGCs
    INFO: Video pts = 0.186 .. 653.013
    INFO: Audio[0] pts = 0.178 .. 653.131
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-17.mpg...
    STAT: VOBU 11626 at 2538MB, 57 PGCs
    INFO: Video pts = 0.186 .. 9.387
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-18.mpg...
    INFO: Video pts = 0.186 .. 5.483
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday   Special\Cartoon Network Christmas\19 - Ed, Edd n Eddy - Who Let The   Ed.mpg...
    STAT: VOBU 11654 at 2543MB, 57 PGCs
    STAT: VOBU 11670 at 2547MB, 57 PGCs
    STAT: VOBU 11686 at 2550MB, 57 PGCs
    STAT: VOBU 11702 at 2554MB, 57 PGCs
    STAT: VOBU 11718 at 2558MB, 57 PGCs
    STAT: VOBU 11734 at 2561MB, 57 PGCs
    STAT: VOBU 11750 at 2565MB, 57 PGCs
    STAT: VOBU 11766 at 2569MB, 57 PGCs
    STAT: VOBU 11782 at 2572MB, 57 PGCs
    STAT: VOBU 11798 at 2576MB, 57 PGCs
    STAT: VOBU 11814 at 2579MB, 57 PGCs
    STAT: VOBU 11830 at 2583MB, 57 PGCs
    STAT: VOBU 11846 at 2587MB, 57 PGCs
    STAT: VOBU 11862 at 2590MB, 57 PGCs
    STAT: VOBU 11878 at 2594MB, 57 PGCs
    STAT: VOBU 11894 at 2598MB, 57 PGCs
    STAT: VOBU 11910 at 2602MB, 57 PGCs
    STAT: VOBU 11926 at 2605MB, 57 PGCs
    STAT: VOBU 11942 at 2609MB, 57 PGCs
    STAT: VOBU 11958 at 2613MB, 57 PGCs
    STAT: VOBU 11974 at 2616MB, 57 PGCs
    STAT: VOBU 11990 at 2620MB, 57 PGCs
    STAT: VOBU 12006 at 2623MB, 57 PGCs
    STAT: VOBU 12022 at 2627MB, 57 PGCs
    STAT: VOBU 12038 at 2631MB, 57 PGCs
    STAT: VOBU 12054 at 2634MB, 57 PGCs
    STAT: VOBU 12070 at 2638MB, 57 PGCs
    STAT: VOBU 12086 at 2642MB, 57 PGCs
    STAT: VOBU 12102 at 2645MB, 57 PGCs
    STAT: VOBU 12118 at 2649MB, 57 PGCs
    STAT: VOBU 12134 at 2653MB, 57 PGCs
    STAT: VOBU 12150 at 2656MB, 57 PGCs
    STAT: VOBU 12166 at 2660MB, 57 PGCs
    STAT: VOBU 12182 at 2664MB, 57 PGCs
    STAT: VOBU 12198 at 2667MB, 57 PGCs
    STAT: VOBU 12214 at 2671MB, 57 PGCs
    STAT: VOBU 12230 at 2675MB, 57 PGCs
    STAT: VOBU 12246 at 2678MB, 57 PGCs
    STAT: VOBU 12262 at 2682MB, 57 PGCs
    STAT: VOBU 12278 at 2686MB, 57 PGCs
    STAT: VOBU 12294 at 2689MB, 57 PGCs
    STAT: VOBU 12310 at 2693MB, 57 PGCs
    STAT: VOBU 12326 at 2697MB, 57 PGCs
    STAT: VOBU 12342 at 2700MB, 57 PGCs
    STAT: VOBU 12358 at 2704MB, 57 PGCs
    STAT: VOBU 12374 at 2708MB, 57 PGCs
    STAT: VOBU 12390 at 2711MB, 57 PGCs
    STAT: VOBU 12406 at 2715MB, 57 PGCs
    STAT: VOBU 12422 at 2719MB, 57 PGCs
    STAT: VOBU 12438 at 2722MB, 57 PGCs
    STAT: VOBU 12454 at 2726MB, 57 PGCs
    STAT: VOBU 12470 at 2730MB, 57 PGCs
    STAT: VOBU 12486 at 2733MB, 57 PGCs
    STAT: VOBU 12502 at 2737MB, 57 PGCs
    STAT: VOBU 12518 at 2741MB, 57 PGCs
    STAT: VOBU 12534 at 2744MB, 57 PGCs
    STAT: VOBU 12550 at 2748MB, 57 PGCs
    STAT: VOBU 12566 at 2752MB, 57 PGCs
    STAT: VOBU 12582 at 2755MB, 57 PGCs
    STAT: VOBU 12598 at 2759MB, 57 PGCs
    STAT: VOBU 12614 at 2763MB, 57 PGCs
    STAT: VOBU 12630 at 2766MB, 57 PGCs
    STAT: VOBU 12646 at 2770MB, 57 PGCs
    STAT: VOBU 12662 at 2774MB, 57 PGCs
    STAT: VOBU 12678 at 2777MB, 57 PGCs
    INFO: Video pts = 0.186 .. 649.109
    INFO: Audio[0] pts = 0.178 .. 649.161
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-19.mpg...
    STAT: VOBU 12702 at 2782MB, 57 PGCs
    STAT: VOBU 12718 at 2785MB, 57 PGCs
    STAT: VOBU 12734 at 2788MB, 57 PGCs
    INFO: Video pts = 0.186 .. 36.664
    INFO: Audio[0] pts = 0.178 .. 36.674
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday   Special\Cartoon Network Christmas\20 - Sheep in the Big City   Intro.mpg...
    STAT: VOBU 12765 at 2793MB, 57 PGCs
    STAT: VOBU 12781 at 2796MB, 57 PGCs
    INFO: Video pts = 0.186 .. 28.114
    INFO: Audio[0] pts = 0.178 .. 28.178
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday   Special\Cartoon Network Christmas\21 - Sheep in the Big City - The   Historical TV Station.mpg...
    STAT: VOBU 12810 at 2799MB, 57 PGCs
    STAT: VOBU 12826 at 2802MB, 57 PGCs
    STAT: VOBU 12842 at 2807MB, 57 PGCs
    STAT: VOBU 12858 at 2811MB, 57 PGCs
    STAT: VOBU 12874 at 2815MB, 57 PGCs
    STAT: VOBU 12890 at 2818MB, 57 PGCs
    STAT: VOBU 12906 at 2820MB, 57 PGCs
    STAT: VOBU 12922 at 2825MB, 57 PGCs
    STAT: VOBU 12938 at 2828MB, 57 PGCs
    STAT: VOBU 12954 at 2832MB, 57 PGCs
    STAT: VOBU 12970 at 2835MB, 57 PGCs
    STAT: VOBU 12986 at 2839MB, 57 PGCs
    STAT: VOBU 13002 at 2843MB, 57 PGCs
    STAT: VOBU 13018 at 2846MB, 57 PGCs
    STAT: VOBU 13034 at 2849MB, 57 PGCs
    STAT: VOBU 13050 at 2853MB, 57 PGCs
    STAT: VOBU 13066 at 2857MB, 57 PGCs
    STAT: VOBU 13082 at 2861MB, 57 PGCs
    STAT: VOBU 13098 at 2865MB, 57 PGCs
    STAT: VOBU 13114 at 2868MB, 57 PGCs
    STAT: VOBU 13130 at 2872MB, 57 PGCs
    STAT: VOBU 13146 at 2876MB, 57 PGCs
    STAT: VOBU 13162 at 2879MB, 57 PGCs
    STAT: VOBU 13178 at 2883MB, 57 PGCs
    STAT: VOBU 13194 at 2887MB, 57 PGCs
    STAT: VOBU 13210 at 2890MB, 57 PGCs
    STAT: VOBU 13226 at 2894MB, 57 PGCs
    STAT: VOBU 13242 at 2898MB, 57 PGCs
    STAT: VOBU 13258 at 2901MB, 57 PGCs
    STAT: VOBU 13274 at 2905MB, 57 PGCs
    STAT: VOBU 13290 at 2909MB, 57 PGCs
    STAT: VOBU 13306 at 2912MB, 57 PGCs
    STAT: VOBU 13322 at 2916MB, 57 PGCs
    STAT: VOBU 13338 at 2919MB, 57 PGCs
    STAT: VOBU 13354 at 2923MB, 57 PGCs
    STAT: VOBU 13370 at 2927MB, 57 PGCs
    STAT: VOBU 13386 at 2929MB, 57 PGCs
    STAT: VOBU 13402 at 2933MB, 57 PGCs
    STAT: VOBU 13418 at 2935MB, 57 PGCs
    STAT: VOBU 13434 at 2938MB, 57 PGCs
    STAT: VOBU 13450 at 2940MB, 57 PGCs
    INFO: Video pts = 0.186 .. 410.913
    INFO: Audio[0] pts = 0.178 .. 410.889
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday   Special\Cartoon Network Christmas\22 - Sheep in the Big City - The   History of Clearance Day.mpg...
    STAT: VOBU 13480 at 2946MB, 57 PGCs
    STAT: VOBU 13496 at 2952MB, 57 PGCs
    STAT: VOBU 13512 at 2958MB, 57 PGCs
    STAT: VOBU 13528 at 2962MB, 57 PGCs
    STAT: VOBU 13544 at 2966MB, 57 PGCs
    STAT: VOBU 13560 at 2970MB, 57 PGCs
    STAT: VOBU 13576 at 2973MB, 57 PGCs
    STAT: VOBU 13592 at 2977MB, 57 PGCs
    STAT: VOBU 13608 at 2981MB, 57 PGCs
    STAT: VOBU 13624 at 2984MB, 57 PGCs
    STAT: VOBU 13640 at 2988MB, 57 PGCs
    STAT: VOBU 13656 at 2991MB, 57 PGCs
    STAT: VOBU 13672 at 2995MB, 57 PGCs
    STAT: VOBU 13688 at 2999MB, 57 PGCs
    STAT: VOBU 13704 at 3003MB, 57 PGCs
    STAT: VOBU 13720 at 3006MB, 57 PGCs
    STAT: VOBU 13736 at 3010MB, 57 PGCs
    STAT: VOBU 13752 at 3012MB, 57 PGCs
    STAT: VOBU 13768 at 3015MB, 57 PGCs
    STAT: VOBU 13784 at 3017MB, 57 PGCs
    STAT: VOBU 13800 at 3023MB, 57 PGCs
    STAT: VOBU 13816 at 3025MB, 57 PGCs
    INFO: Video pts = 0.186 .. 217.561
    INFO: Audio[0] pts = 0.178 .. 217.583
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-20.mpg...
    STAT: VOBU 13839 at 3029MB, 57 PGCs
    INFO: Audio[0] pts = 0.178 .. 9.370
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-21.mpg...
    INFO: Video pts = 0.186 .. 5.441
    INFO: Audio[0] pts = 0.178 .. 5.434
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday   Special\Cartoon Network Christmas\23 - Sheep in the Big City - Home For   The Baa-lidays.mpg...
    STAT: VOBU 13869 at 3032MB, 57 PGCs
    STAT: VOBU 13885 at 3034MB, 57 PGCs
    STAT: VOBU 13901 at 3036MB, 57 PGCs
    STAT: VOBU 13917 at 3038MB, 57 PGCs
    STAT: VOBU 13933 at 3039MB, 57 PGCs
    STAT: VOBU 13949 at 3042MB, 57 PGCs
    STAT: VOBU 13965 at 3047MB, 57 PGCs
    STAT: VOBU 13981 at 3052MB, 57 PGCs
    STAT: VOBU 13997 at 3056MB, 57 PGCs
    STAT: VOBU 14013 at 3060MB, 57 PGCs
    STAT: VOBU 14029 at 3062MB, 57 PGCs
    STAT: VOBU 14045 at 3066MB, 57 PGCs
    STAT: VOBU 14061 at 3070MB, 57 PGCs
    STAT: VOBU 14077 at 3073MB, 57 PGCs
    STAT: VOBU 14093 at 3076MB, 57 PGCs
    STAT: VOBU 14109 at 3080MB, 57 PGCs
    STAT: VOBU 14125 at 3084MB, 57 PGCs
    STAT: VOBU 14141 at 3087MB, 57 PGCs
    STAT: VOBU 14157 at 3091MB, 57 PGCs
    STAT: VOBU 14173 at 3095MB, 57 PGCs
    STAT: VOBU 14189 at 3097MB, 57 PGCs
    STAT: VOBU 14205 at 3100MB, 57 PGCs
    STAT: VOBU 14221 at 3102MB, 57 PGCs
    STAT: VOBU 14237 at 3105MB, 57 PGCs
    STAT: VOBU 14253 at 3108MB, 57 PGCs
    STAT: VOBU 14269 at 3112MB, 57 PGCs
    STAT: VOBU 14285 at 3116MB, 57 PGCs
    STAT: VOBU 14301 at 3120MB, 57 PGCs
    STAT: VOBU 14317 at 3123MB, 57 PGCs
    STAT: VOBU 14333 at 3126MB, 57 PGCs
    STAT: VOBU 14349 at 3129MB, 57 PGCs
    STAT: VOBU 14365 at 3131MB, 57 PGCs
    STAT: VOBU 14381 at 3133MB, 57 PGCs
    STAT: VOBU 14397 at 3136MB, 57 PGCs
    STAT: VOBU 14413 at 3139MB, 57 PGCs
    INFO: Video pts = 0.186 .. 341.535
    INFO: Audio[0] pts = 0.178 .. 341.543
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday   Special\Cartoon Network Christmas\24 - Sheep in the Big City - Behave  Or  You Won't Get Mutton!.mpg...
    STAT: VOBU 14430 at 3142MB, 57 PGCs
    STAT: VOBU 14446 at 3146MB, 57 PGCs
    STAT: VOBU 14462 at 3150MB, 57 PGCs
    STAT: VOBU 14478 at 3153MB, 57 PGCs
    STAT: VOBU 14494 at 3156MB, 57 PGCs
    STAT: VOBU 14510 at 3160MB, 57 PGCs
    STAT: VOBU 14526 at 3163MB, 57 PGCs
    STAT: VOBU 14542 at 3167MB, 57 PGCs
    STAT: VOBU 14558 at 3171MB, 57 PGCs
    STAT: VOBU 14574 at 3174MB, 57 PGCs
    STAT: VOBU 14590 at 3178MB, 57 PGCs
    STAT: VOBU 14606 at 3182MB, 57 PGCs
    STAT: VOBU 14622 at 3185MB, 57 PGCs
    STAT: VOBU 14638 at 3189MB, 57 PGCs
    STAT: VOBU 14654 at 3192MB, 57 PGCs
    STAT: VOBU 14670 at 3197MB, 57 PGCs
    STAT: VOBU 14686 at 3201MB, 57 PGCs
    STAT: VOBU 14702 at 3203MB, 57 PGCs
    STAT: VOBU 14718 at 3205MB, 57 PGCs
    STAT: VOBU 14734 at 3208MB, 57 PGCs
    STAT: VOBU 14750 at 3211MB, 57 PGCs
    STAT: VOBU 14766 at 3215MB, 57 PGCs
    STAT: VOBU 14782 at 3218MB, 57 PGCs
    STAT: VOBU 14798 at 3220MB, 57 PGCs
    STAT: VOBU 14814 at 3221MB, 57 PGCs
    STAT: VOBU 14830 at 3223MB, 57 PGCs
    STAT: VOBU 14846 at 3227MB, 57 PGCs
    STAT: VOBU 14862 at 3231MB, 57 PGCs
    STAT: VOBU 14878 at 3235MB, 57 PGCs
    STAT: VOBU 14894 at 3237MB, 57 PGCs
    STAT: VOBU 14910 at 3240MB, 57 PGCs
    STAT: VOBU 14926 at 3244MB, 57 PGCs
    STAT: VOBU 14942 at 3249MB, 57 PGCs
    INFO: Video pts = 0.186 .. 330.032
    INFO: Audio[0] pts = 0.178 .. 330.014
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-22.mpg...
    STAT: VOBU 14967 at 3253MB, 57 PGCs
    STAT: VOBU 14983 at 3255MB, 57 PGCs
    STAT: VOBU 14999 at 3258MB, 57 PGCs
    INFO: Video pts = 0.186 .. 30.658
    INFO: Audio[0] pts = 0.178 .. 30.686
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday   Special\Cartoon Network Christmas\25 - Courage The Cowardly Dog - The   Snowman Cometh.mpg...
    STAT: VOBU 15023 at 3262MB, 57 PGCs
    STAT: VOBU 15039 at 3264MB, 57 PGCs
    STAT: VOBU 15055 at 3268MB, 57 PGCs
    STAT: VOBU 15071 at 3270MB, 57 PGCs
    STAT: VOBU 15087 at 3272MB, 57 PGCs
    STAT: VOBU 15103 at 3274MB, 57 PGCs
    STAT: VOBU 15119 at 3277MB, 57 PGCs
    STAT: VOBU 15135 at 3279MB, 57 PGCs
    STAT: VOBU 15151 at 3281MB, 57 PGCs
    STAT: VOBU 15167 at 3283MB, 57 PGCs
    STAT: VOBU 15183 at 3285MB, 57 PGCs
    STAT: VOBU 15199 at 3286MB, 57 PGCs
    STAT: VOBU 15215 at 3288MB, 57 PGCs
    STAT: VOBU 15231 at 3291MB, 57 PGCs
    STAT: VOBU 15247 at 3293MB, 57 PGCs
    STAT: VOBU 15263 at 3295MB, 57 PGCs
    STAT: VOBU 15279 at 3298MB, 57 PGCs
    STAT: VOBU 15295 at 3301MB, 57 PGCs
    STAT: VOBU 15311 at 3302MB, 57 PGCs
    STAT: VOBU 15327 at 3305MB, 57 PGCs
    STAT: VOBU 15343 at 3307MB, 57 PGCs
    STAT: VOBU 15359 at 3309MB, 57 PGCs
    STAT: VOBU 15375 at 3312MB, 57 PGCs
    STAT: VOBU 15391 at 3314MB, 57 PGCs
    STAT: VOBU 15407 at 3316MB, 57 PGCs
    STAT: VOBU 15423 at 3318MB, 57 PGCs
    STAT: VOBU 15439 at 3321MB, 57 PGCs
    STAT: VOBU 15455 at 3323MB, 57 PGCs
    STAT: VOBU 15471 at 3324MB, 57 PGCs
    STAT: VOBU 15487 at 3326MB, 57 PGCs
    STAT: VOBU 15503 at 3328MB, 57 PGCs
    STAT: VOBU 15519 at 3330MB, 57 PGCs
    STAT: VOBU 15535 at 3332MB, 57 PGCs
    STAT: VOBU 15551 at 3335MB, 57 PGCs
    STAT: VOBU 15567 at 3338MB, 57 PGCs
    STAT: VOBU 15583 at 3340MB, 57 PGCs
    STAT: VOBU 15599 at 3342MB, 57 PGCs
    STAT: VOBU 15615 at 3346MB, 57 PGCs
    STAT: VOBU 15631 at 3348MB, 57 PGCs
    STAT: VOBU 15647 at 3350MB, 57 PGCs
    STAT: VOBU 15663 at 3352MB, 57 PGCs
    STAT: VOBU 15679 at 3354MB, 57 PGCs
    STAT: VOBU 15695 at 3356MB, 57 PGCs
    STAT: VOBU 15711 at 3358MB, 57 PGCs
    STAT: VOBU 15727 at 3361MB, 57 PGCs
    STAT: VOBU 15743 at 3363MB, 57 PGCs
    STAT: VOBU 15759 at 3365MB, 57 PGCs
    STAT: VOBU 15775 at 3367MB, 57 PGCs
    STAT: VOBU 15791 at 3371MB, 57 PGCs
    STAT: VOBU 15807 at 3374MB, 57 PGCs
    STAT: VOBU 15823 at 3377MB, 57 PGCs
    STAT: VOBU 15839 at 3379MB, 57 PGCs
    STAT: VOBU 15855 at 3381MB, 57 PGCs
    STAT: VOBU 15871 at 3384MB, 57 PGCs
    STAT: VOBU 15887 at 3387MB, 57 PGCs
    STAT: VOBU 15903 at 3389MB, 57 PGCs
    STAT: VOBU 15919 at 3391MB, 57 PGCs
    STAT: VOBU 15935 at 3395MB, 57 PGCs
    STAT: VOBU 15951 at 3397MB, 57 PGCs
    STAT: VOBU 15967 at 3398MB, 57 PGCs
    STAT: VOBU 15983 at 3401MB, 57 PGCs
    STAT: VOBU 15999 at 3403MB, 57 PGCs
    STAT: VOBU 16015 at 3405MB, 57 PGCs
    STAT: VOBU 16031 at 3407MB, 57 PGCs
    STAT: VOBU 16047 at 3410MB, 57 PGCs
    STAT: VOBU 16063 at 3412MB, 57 PGCs
    INFO: Video pts = 0.186 .. 660.087
    INFO: Audio[0] pts = 0.178 .. 660.167
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-23.mpg...
    STAT: VOBU 16079 at 3415MB, 57 PGCs
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-24.mpg...
    INFO: Video pts = 0.186 .. 5.541
    INFO: Audio[0] pts = 0.178 .. 5.539
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday   Special\Cartoon Network Christmas\26 - Courage The Cowardly Dog - The   Precious, Wonderful, Adorable, Loveable Duckling.mpg...
    STAT: VOBU 16107 at 3421MB, 57 PGCs
    STAT: VOBU 16123 at 3424MB, 57 PGCs
    STAT: VOBU 16139 at 3428MB, 57 PGCs
    STAT: VOBU 16155 at 3432MB, 57 PGCs
    STAT: VOBU 16171 at 3435MB, 57 PGCs
    STAT: VOBU 16187 at 3439MB, 57 PGCs
    STAT: VOBU 16203 at 3443MB, 57 PGCs
    STAT: VOBU 16219 at 3447MB, 57 PGCs
    STAT: VOBU 16235 at 3450MB, 57 PGCs
    STAT: VOBU 16251 at 3454MB, 57 PGCs
    STAT: VOBU 16267 at 3458MB, 57 PGCs
    STAT: VOBU 16283 at 3461MB, 57 PGCs
    STAT: VOBU 16299 at 3465MB, 57 PGCs
    STAT: VOBU 16315 at 3469MB, 57 PGCs
    STAT: VOBU 16331 at 3472MB, 57 PGCs
    STAT: VOBU 16347 at 3476MB, 57 PGCs
    STAT: VOBU 16363 at 3479MB, 57 PGCs
    STAT: VOBU 16379 at 3483MB, 57 PGCs
    STAT: VOBU 16395 at 3487MB, 57 PGCs
    STAT: VOBU 16411 at 3491MB, 57 PGCs
    STAT: VOBU 16427 at 3494MB, 57 PGCs
    STAT: VOBU 16443 at 3498MB, 57 PGCs
    STAT: VOBU 16459 at 3501MB, 57 PGCs
    STAT: VOBU 16475 at 3505MB, 57 PGCs
    STAT: VOBU 16491 at 3509MB, 57 PGCs
    STAT: VOBU 16507 at 3512MB, 57 PGCs
    STAT: VOBU 16523 at 3516MB, 57 PGCs
    STAT: VOBU 16539 at 3520MB, 57 PGCs
    STAT: VOBU 16555 at 3523MB, 57 PGCs
    STAT: VOBU 16571 at 3527MB, 57 PGCs
    STAT: VOBU 16587 at 3531MB, 57 PGCs
    STAT: VOBU 16603 at 3534MB, 57 PGCs
    STAT: VOBU 16619 at 3538MB, 57 PGCs
    STAT: VOBU 16635 at 3541MB, 57 PGCs
    STAT: VOBU 16651 at 3545MB, 57 PGCs
    STAT: VOBU 16667 at 3549MB, 57 PGCs
    STAT: VOBU 16683 at 3552MB, 57 PGCs
    STAT: VOBU 16699 at 3556MB, 57 PGCs
    STAT: VOBU 16715 at 3560MB, 57 PGCs
    STAT: VOBU 16731 at 3563MB, 57 PGCs
    STAT: VOBU 16747 at 3567MB, 57 PGCs
    STAT: VOBU 16763 at 3571MB, 57 PGCs
    STAT: VOBU 16779 at 3574MB, 57 PGCs
    STAT: VOBU 16795 at 3578MB, 57 PGCs
    STAT: VOBU 16811 at 3582MB, 57 PGCs
    STAT: VOBU 16827 at 3585MB, 57 PGCs
    STAT: VOBU 16843 at 3589MB, 57 PGCs
    STAT: VOBU 16859 at 3593MB, 57 PGCs
    STAT: VOBU 16875 at 3596MB, 57 PGCs
    STAT: VOBU 16891 at 3600MB, 57 PGCs
    STAT: VOBU 16907 at 3604MB, 57 PGCs
    STAT: VOBU 16923 at 3607MB, 57 PGCs
    STAT: VOBU 16939 at 3611MB, 57 PGCs
    STAT: VOBU 16955 at 3615MB, 57 PGCs
    STAT: VOBU 16971 at 3618MB, 57 PGCs
    STAT: VOBU 16987 at 3622MB, 57 PGCs
    STAT: VOBU 17003 at 3626MB, 57 PGCs
    STAT: VOBU 17019 at 3629MB, 57 PGCs
    STAT: VOBU 17035 at 3633MB, 57 PGCs
    STAT: VOBU 17051 at 3637MB, 57 PGCs
    STAT: VOBU 17067 at 3640MB, 57 PGCs
    STAT: VOBU 17083 at 3644MB, 57 PGCs
    STAT: VOBU 17099 at 3647MB, 57 PGCs
    INFO: Video pts = 0.186 .. 632.109
    INFO: Audio[0] pts = 0.178 .. 632.164
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-25.mpg...
    STAT: VOBU 17120 at 3652MB, 57 PGCs
    STAT: VOBU 17136 at 3654MB, 57 PGCs
    STAT: VOBU 17152 at 3657MB, 57 PGCs
    STAT: VOBU 17168 at 3659MB, 57 PGCs
    STAT: VOBU 17184 at 3662MB, 57 PGCs
    INFO: Video pts = 0.186 .. 52.580
    INFO: Audio[0] pts = 0.178 .. 52.663
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday   Special\Cartoon Network Christmas\27 - Ed, Edd n Eddy Intro.mpg...
    STAT: VOBU 17209 at 3667MB, 57 PGCs
    STAT: VOBU 17225 at 3671MB, 57 PGCs
    STAT: VOBU 17241 at 3674MB, 57 PGCs
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday   Special\Cartoon Network Christmas\28 - Ed, Edd n Eddy - Fa-La-La-La   Ed.mpg...
    STAT: VOBU 17259 at 3678MB, 57 PGCs
    STAT: VOBU 17275 at 3682MB, 57 PGCs
    STAT: VOBU 17291 at 3685MB, 57 PGCs
    STAT: VOBU 17307 at 3689MB, 57 PGCs
    STAT: VOBU 17323 at 3692MB, 57 PGCs
    STAT: VOBU 17339 at 3696MB, 57 PGCs
    STAT: VOBU 17355 at 3700MB, 57 PGCs
    STAT: VOBU 17371 at 3704MB, 57 PGCs
    STAT: VOBU 17387 at 3707MB, 57 PGCs
    STAT: VOBU 17403 at 3711MB, 57 PGCs
    STAT: VOBU 17419 at 3715MB, 57 PGCs
    STAT: VOBU 17435 at 3718MB, 57 PGCs
    STAT: VOBU 17451 at 3722MB, 57 PGCs
    STAT: VOBU 17467 at 3725MB, 57 PGCs
    STAT: VOBU 17483 at 3729MB, 57 PGCs
    STAT: VOBU 17499 at 3733MB, 57 PGCs
    STAT: VOBU 17515 at 3736MB, 57 PGCs
    STAT: VOBU 17531 at 3740MB, 57 PGCs
    STAT: VOBU 17547 at 3744MB, 57 PGCs
    STAT: VOBU 17563 at 3747MB, 57 PGCs
    STAT: VOBU 17579 at 3751MB, 57 PGCs
    STAT: VOBU 17595 at 3755MB, 57 PGCs
    STAT: VOBU 17611 at 3758MB, 57 PGCs
    STAT: VOBU 17627 at 3762MB, 57 PGCs
    STAT: VOBU 17643 at 3766MB, 57 PGCs
    STAT: VOBU 17659 at 3770MB, 57 PGCs
    STAT: VOBU 17675 at 3773MB, 57 PGCs
    STAT: VOBU 17691 at 3777MB, 57 PGCs
    STAT: VOBU 17707 at 3781MB, 57 PGCs
    STAT: VOBU 17723 at 3784MB, 57 PGCs
    STAT: VOBU 17739 at 3788MB, 57 PGCs
    STAT: VOBU 17755 at 3791MB, 57 PGCs
    STAT: VOBU 17771 at 3795MB, 57 PGCs
    STAT: VOBU 17787 at 3799MB, 57 PGCs
    STAT: VOBU 17803 at 3802MB, 57 PGCs
    STAT: VOBU 17819 at 3806MB, 57 PGCs
    STAT: VOBU 17835 at 3810MB, 57 PGCs
    STAT: VOBU 17851 at 3813MB, 57 PGCs
    STAT: VOBU 17867 at 3817MB, 57 PGCs
    STAT: VOBU 17883 at 3821MB, 57 PGCs
    STAT: VOBU 17899 at 3824MB, 57 PGCs
    STAT: VOBU 17915 at 3828MB, 57 PGCs
    STAT: VOBU 17931 at 3832MB, 57 PGCs
    STAT: VOBU 17947 at 3835MB, 57 PGCs
    STAT: VOBU 17963 at 3839MB, 57 PGCs
    STAT: VOBU 17979 at 3843MB, 57 PGCs
    STAT: VOBU 17995 at 3846MB, 57 PGCs
    STAT: VOBU 18011 at 3850MB, 57 PGCs
    STAT: VOBU 18027 at 3854MB, 57 PGCs
    STAT: VOBU 18043 at 3857MB, 57 PGCs
    STAT: VOBU 18059 at 3861MB, 57 PGCs
    STAT: VOBU 18075 at 3865MB, 57 PGCs
    STAT: VOBU 18091 at 3868MB, 57 PGCs
    STAT: VOBU 18107 at 3872MB, 57 PGCs
    STAT: VOBU 18123 at 3876MB, 57 PGCs
    STAT: VOBU 18139 at 3879MB, 57 PGCs
    STAT: VOBU 18155 at 3883MB, 57 PGCs
    STAT: VOBU 18171 at 3887MB, 57 PGCs
    STAT: VOBU 18187 at 3890MB, 57 PGCs
    STAT: VOBU 18203 at 3894MB, 57 PGCs
    STAT: VOBU 18219 at 3898MB, 57 PGCs
    STAT: VOBU 18235 at 3901MB, 57 PGCs
    STAT: VOBU 18251 at 3905MB, 57 PGCs
    STAT: VOBU 18267 at 3909MB, 57 PGCs
    STAT: VOBU 18283 at 3912MB, 57 PGCs
    INFO: Video pts = 0.186 .. 654.164
    INFO: Audio[0] pts = 0.178 .. 654.141
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-26.mpg...
    STAT: VOBU 18307 at 3917MB, 57 PGCs
    INFO: Video pts = 0.186 .. 9.804
    INFO: Audio[0] pts = 0.178 .. 9.788
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-27.mpg...
    INFO: Video pts = 0.186 .. 5.658
    INFO: Audio[0] pts = 0.178 .. 5.713
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday   Special\Cartoon Network Christmas\29 - Ed, Edd n Eddy - Cry Ed.mpg...
    STAT: VOBU 18336 at 3922MB, 57 PGCs
    STAT: VOBU 18352 at 3925MB, 57 PGCs
    STAT: VOBU 18368 at 3928MB, 57 PGCs
    STAT: VOBU 18384 at 3932MB, 57 PGCs
    STAT: VOBU 18400 at 3936MB, 57 PGCs
    STAT: VOBU 18416 at 3939MB, 57 PGCs
    STAT: VOBU 18432 at 3943MB, 57 PGCs
    STAT: VOBU 18448 at 3946MB, 57 PGCs
    STAT: VOBU 18464 at 3950MB, 57 PGCs
    STAT: VOBU 18480 at 3954MB, 57 PGCs
    STAT: VOBU 18496 at 3958MB, 57 PGCs
    STAT: VOBU 18512 at 3961MB, 57 PGCs
    STAT: VOBU 18528 at 3965MB, 57 PGCs
    STAT: VOBU 18544 at 3969MB, 57 PGCs
    STAT: VOBU 18560 at 3972MB, 57 PGCs
    STAT: VOBU 18576 at 3976MB, 57 PGCs
    STAT: VOBU 18592 at 3980MB, 57 PGCs
    STAT: VOBU 18608 at 3983MB, 57 PGCs
    STAT: VOBU 18624 at 3987MB, 57 PGCs
    STAT: VOBU 18640 at 3991MB, 57 PGCs
    STAT: VOBU 18656 at 3994MB, 57 PGCs
    STAT: VOBU 18672 at 3998MB, 57 PGCs
    STAT: VOBU 18688 at 4002MB, 57 PGCs
    STAT: VOBU 18704 at 4005MB, 57 PGCs
    STAT: VOBU 18720 at 4009MB, 57 PGCs
    STAT: VOBU 18736 at 4012MB, 57 PGCs
    STAT: VOBU 18752 at 4016MB, 57 PGCs
    STAT: VOBU 18768 at 4020MB, 57 PGCs
    STAT: VOBU 18784 at 4024MB, 57 PGCs
    STAT: VOBU 18800 at 4027MB, 57 PGCs
    STAT: VOBU 18816 at 4031MB, 57 PGCs
    STAT: VOBU 18832 at 4035MB, 57 PGCs
    STAT: VOBU 18848 at 4038MB, 57 PGCs
    STAT: VOBU 18864 at 4042MB, 57 PGCs
    STAT: VOBU 18880 at 4045MB, 57 PGCs
    STAT: VOBU 18896 at 4049MB, 57 PGCs
    STAT: VOBU 18912 at 4053MB, 57 PGCs
    STAT: VOBU 18928 at 4056MB, 57 PGCs
    STAT: VOBU 18944 at 4060MB, 57 PGCs
    STAT: VOBU 18960 at 4064MB, 57 PGCs
    STAT: VOBU 18976 at 4067MB, 57 PGCs
    STAT: VOBU 18992 at 4071MB, 57 PGCs
    STAT: VOBU 19008 at 4075MB, 57 PGCs
    STAT: VOBU 19024 at 4079MB, 57 PGCs
    STAT: VOBU 19040 at 4082MB, 57 PGCs
    STAT: VOBU 19056 at 4086MB, 57 PGCs
    STAT: VOBU 19072 at 4090MB, 57 PGCs
    STAT: VOBU 19088 at 4093MB, 57 PGCs
    STAT: VOBU 19104 at 4097MB, 57 PGCs
    STAT: VOBU 19120 at 4100MB, 57 PGCs
    STAT: VOBU 19136 at 4104MB, 57 PGCs
    STAT: VOBU 19152 at 4108MB, 57 PGCs
    STAT: VOBU 19168 at 4111MB, 57 PGCs
    STAT: VOBU 19184 at 4115MB, 57 PGCs
    STAT: VOBU 19200 at 4119MB, 57 PGCs
    STAT: VOBU 19216 at 4122MB, 57 PGCs
    STAT: VOBU 19232 at 4126MB, 57 PGCs
    STAT: VOBU 19248 at 4130MB, 57 PGCs
    STAT: VOBU 19264 at 4133MB, 57 PGCs
    STAT: VOBU 19280 at 4137MB, 57 PGCs
    STAT: VOBU 19296 at 4141MB, 57 PGCs
    STAT: VOBU 19312 at 4144MB, 57 PGCs
    STAT: VOBU 19328 at 4148MB, 57 PGCs
    STAT: VOBU 19344 at 4152MB, 57 PGCs
    STAT: VOBU 19360 at 4155MB, 57 PGCs
    INFO: Video pts = 0.186 .. 656.058
    INFO: Audio[0] pts = 0.178 .. 656.162
    STAT: Processing C:\Users\User\Documents\uTorrent\A Very CCF Holiday Special\CCF-28.mpg...
    STAT: VOBU 19391 at 4162MB, 57 PGCs
    STAT: VOBU 19407 at 4164MB, 57 PGCs
    STAT: VOBU 19423 at 4167MB, 57 PGCs
    INFO: Video pts = 0.186 .. 31.617
    INFO: Audio[0] pts = 0.178 .. 31.626
    STAT: VOBU 19428 at 4168MB, 57 PGCs
    CHAPTERS: VTS[1/1] 115.115
    CHAPTERS: VTS[2/1] 29.279
    CHAPTERS: VTS[3/1] 392.475
    CHAPTERS: VTS[4/1] 0.000
    CHAPTERS: VTS[4/1] 15.890
    CHAPTERS: VTS[5/1] 0.000
    CHAPTERS: VTS[5/1] 393.643
    CHAPTERS: VTS[6/1] 0.000
    CHAPTERS: VTS[6/1] 14.931
    CHAPTERS: VTS[7/1] 0.000
    CHAPTERS: VTS[7/1] 9.300
    CHAPTERS: VTS[8/1] 0.000
    CHAPTERS: VTS[8/1] 29.988
    CHAPTERS: VTS[8/1] 426.551
    CHAPTERS: VTS[9/1] 0.000
    CHAPTERS: VTS[9/1] 424.966
    CHAPTERS: VTS[10/1] 0.000
    CHAPTERS: VTS[10/1] 430.680
    CHAPTERS: VTS[11/1] 0.000
    CHAPTERS: VTS[11/1] 43.084
    CHAPTERS: VTS[12/1] 0.000
    CHAPTERS: VTS[12/1] 18.435
    CHAPTERS: VTS[13/1] 0.000
    CHAPTERS: VTS[13/1] 392.975
    CHAPTERS: VTS[14/1] 0.000
    CHAPTERS: VTS[14/1] 9.509
    CHAPTERS: VTS[15/1] 0.000
    CHAPTERS: VTS[15/1] 392.892
    CHAPTERS: VTS[16/1] 0.000
    CHAPTERS: VTS[16/1] 9.342
    CHAPTERS: VTS[17/1] 0.000
    CHAPTERS: VTS[17/1] 5.088
    CHAPTERS: VTS[18/1] 0.000
    CHAPTERS: VTS[18/1] 391.391
    CHAPTERS: VTS[19/1] 0.000
    CHAPTERS: VTS[19/1] 61.186
    CHAPTERS: VTS[20/1] 0.000
    CHAPTERS: VTS[20/1] 30.071
    CHAPTERS: VTS[20/1] 402.402
    CHAPTERS: VTS[21/1] 0.000
    CHAPTERS: VTS[21/1] 9.843
    CHAPTERS: VTS[22/1] 0.000
    CHAPTERS: VTS[22/1] 449.991
    CHAPTERS: VTS[23/1] 0.000
    CHAPTERS: VTS[23/1] 9.092
    CHAPTERS: VTS[24/1] 0.000
    CHAPTERS: VTS[24/1] 5.005
    CHAPTERS: VTS[25/1] 0.000
    CHAPTERS: VTS[25/1] 447.822
    CHAPTERS: VTS[26/1] 0.000
    CHAPTERS: VTS[26/1] 40.415
    CHAPTERS: VTS[27/1] 0.000
    CHAPTERS: VTS[27/1] 62.896
    CHAPTERS: VTS[28/1] 0.000
    CHAPTERS: VTS[28/1] 587.962
    CHAPTERS: VTS[29/1] 0.000
    CHAPTERS: VTS[29/1] 9.050
    CHAPTERS: VTS[30/1] 0.000
    CHAPTERS: VTS[30/1] 5.088
    CHAPTERS: VTS[31/1] 0.000
    CHAPTERS: VTS[31/1] 600.016
    CHAPTERS: VTS[32/1] 0.000
    CHAPTERS: VTS[32/1] 81.331
    CHAPTERS: VTS[33/1] 0.000
    CHAPTERS: VTS[33/1] 29.571
    CHAPTERS: VTS[34/1] 0.000
    CHAPTERS: VTS[34/1] 599.807
    CHAPTERS: VTS[35/1] 0.000
    CHAPTERS: VTS[35/1] 9.134
    CHAPTERS: VTS[36/1] 0.000
    CHAPTERS: VTS[36/1] 5.130
    CHAPTERS: VTS[37/1] 0.000
    CHAPTERS: VTS[37/1] 599.890
    CHAPTERS: VTS[38/1] 0.000
    CHAPTERS: VTS[38/1] 36.244
    CHAPTERS: VTS[39/1] 0.000
    CHAPTERS: VTS[39/1] 27.527
    CHAPTERS: VTS[40/1] 0.000
    CHAPTERS: VTS[40/1] 410.660
    CHAPTERS: VTS[41/1] 0.000
    CHAPTERS: VTS[41/1] 217.175
    CHAPTERS: VTS[42/1] 0.000
    CHAPTERS: VTS[42/1] 9.134
    CHAPTERS: VTS[43/1] 0.000
    CHAPTERS: VTS[43/1] 5.088
    CHAPTERS: VTS[44/1] 0.000
    CHAPTERS: VTS[44/1] 341.215
    CHAPTERS: VTS[45/1] 0.000
    CHAPTERS: VTS[45/1] 329.746
    CHAPTERS: VTS[46/1] 0.000
    CHAPTERS: VTS[46/1] 30.405
    CHAPTERS: VTS[47/1] 0.000
    CHAPTERS: VTS[47/1] 30.155
    CHAPTERS: VTS[47/1] 659.533
    CHAPTERS: VTS[48/1] 0.000
    CHAPTERS: VTS[48/1] 9.134
    CHAPTERS: VTS[49/1] 0.000
    CHAPTERS: VTS[49/1] 5.255
    CHAPTERS: VTS[50/1] 0.000
    CHAPTERS: VTS[50/1] 631.422
    CHAPTERS: VTS[51/1] 0.000
    CHAPTERS: VTS[51/1] 52.093
    CHAPTERS: VTS[52/1] 0.000
    CHAPTERS: VTS[52/1] 29.571
    CHAPTERS: VTS[53/1] 0.000
    CHAPTERS: VTS[53/1] 653.778
    CHAPTERS: VTS[54/1] 0.000
    CHAPTERS: VTS[54/1] 9.551
    CHAPTERS: VTS[55/1] 0.000
    CHAPTERS: VTS[55/1] 5.171
    CHAPTERS: VTS[56/1] 0.000
    CHAPTERS: VTS[56/1] 655.571
    CHAPTERS: VTS[57/1] 0.000
    CHAPTERS: VTS[57/1] 31.364
    INFO: Generating VTS with the following video attributes:
    INFO: Aspect ratio: 4:3
    STAT: fixed 3 VOBUs
    STAT: fixing VOBU at 1MB (17/19428, 0%)
    STAT: fixing VOBU at 210MB (977/19428, 5%)
    STAT: fixing VOBU at 422MB (1953/19428, 10%)
    STAT: fixing VOBU at 637MB (2929/19428, 15%)
    STAT: fixing VOBU at 842MB (3889/19428, 20%)
    STAT: fixing VOBU at 1057MB (4865/19428, 25%)
    STAT: fixing VOBU at 1264MB (5841/19428, 30%)
    STAT: fixing VOBU at 1468MB (6801/19428, 35%)
    STAT: fixing VOBU at 1680MB (7777/19428, 40%)
    STAT: fixing VOBU at 1888MB (8753/19428, 45%)
    STAT: fixing VOBU at 2107MB (9729/19428, 50%)
    STAT: fixing VOBU at 2324MB (10689/19428, 55%)
    STAT: fixing VOBU at 2545MB (11665/19428, 60%)
    STAT: fixing VOBU at 2769MB (12641/19428, 65%)
    STAT: fixing VOBU at 2979MB (13601/19428, 70%)
    STAT: fixing VOBU at 3174MB (14577/19428, 75%)
    STAT: fixing VOBU at 3335MB (15553/19428, 80%)
    STAT: fixing VOBU at 3517MB (16529/19428, 85%)
    STAT: fixing VOBU at 3730MB (17489/19428, 90%)
    STAT: fixing VOBU at 3950MB (18465/19428, 95%)
    STAT: fixed 19428 VOBUs
    INFO: dvdauthor creating table of contents
    INFO: Scanning C:\Users\User\AppData\Local\Temp\dvd-out/VIDEO_TS/VTS_01_0.IFO
    INFO: Creating menu for TOC
    STAT: Processing C:\Program Files\DVDStyler\data\empty_ntsc_ac3.mpg...
    WARN: attempt to update aspect ratio from 16:9 to 4:3; skipping
    INFO: Video pts = 0.178 .. 6.417
    INFO: Audio[0] pts = 0.178 .. 6.194
    STAT: VOBU 11 at 0MB, 1 PGCs
    INFO: Generating VMGM with the following video attributes:
    STAT: fixed 11 VOBUs
    Start preview
    Aborted
  4. do the intermediate mpg's play back smoothly? Which player are you previewing the files and DVD in?
    I see this in your logs:
    Maybe your muxer choked? Give MuxMan a try. I've made a few good DVDs with HCenc, MuxMan and DVDStyler.
  5. I have seen several post in the DVDStyler forum from people having choppy video due to using MPEG2 file being not so DVD compliant as thought so I would suggest you try letting DVDStyler encode your original files just to see if they appear choppy.
