I hooked-up a Philips DVP5982 DVD player to an HDMI switch with an LG BR player. When it switched to the DVP5982 I saw a very brief message,which I think said Not HDCP compliant. The picture from the 5982 switches on and off. I'm using the switch passively,no power supply. The 5982 works normally when I hook to my JVC HDTV directly via HDMI cable.
Maybe the Philips DVD player doesn't supply enough current to power the switch. Did you try connecting it with the power supply plugged in? A link to the switch would be helpful.
Likely the cheap HDMI switch thinks your Philips player is not HDCP compliant. That's possible. But perhaps you can tell us how a non-electronic non-powered switch box gets the power to display a message on your TV. I'd say the message is from your TV, not from the box.
It is a cheap generic $20.00 5-1 switch. It happens to be a "Cables Unlimited" brand. You can see many like it on newegg. I don't believe I said the switch caused the message,clearly the HDTV generated the message.
I have a couple of five and four input HDMI switches and they work OK. They are both powered. Also a powered HDMI splitter. No problems.
HDMI can be a bit of a PITA at times. It can take a second or so for the handshake to work. I would first try different cables. If that fails, maybe replace the switch. I've never had much luck with passive HDMI switches.
Both of my switches are from Monoprice. -
I'm thinking along the same lines as Redwudz. You would be better off with a switch that has its own power supply rather than one that only receives power via its HDMI connections. It could be the cable isn't making good contact, or it could be the DVD player isn't supplying enough power.
I hooked up my Philips 5990 and it works normally thru the switch. It would appear the 5982 was the cause. As one poster suggested it probably doesn't output enough current.
So i want to record from my neotv max-will a hdmi switch or splitter work?
By Milardo in forum Capturing and VCRReplies: 14Last Post: 9th Aug 2013, 01:18 -
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 16:20 -
xbox 360 hdmi problem (hdmi works on other hdtvs but not mine
By dmiklo in forum Capturing and VCRReplies: 0Last Post: 23rd Sep 2009, 16:51 -
No joy from Joytech! HDMI Selctor Switch problem.
By Sproggins in forum DVD & Blu-ray PlayersReplies: 0Last Post: 28th Aug 2009, 06:02 -
multimedia player connection via hdmi but monitor doesnt have hdmi slot
By ozy666 in forum DVB / IPTVReplies: 1Last Post: 25th Apr 2009, 09:40
