Hello
I'm wanting to burn some episodes onto a disc using the Data disc method using ImgBurn. Ideally i would like episodes to run in order without having to burn them within folder to keep them in sequence.
I want to avoid something like below.
Episode 10
Episode 11
Episode 12
Episode 13
Episode 14
Episode 16
Episode 1
Episode 2
Episode 3
Episode 4
Episode 5
Episode 6
Episode 7
Episode 8
Episode 9
Another project
Basically the same as above. Combining series 1 and series 2 together, using the Data disc burn method using ImgBurn again. Making sure both series and episodes follow each other in a particular order..
Yes,001
002
002
004
etc
etc
I have made a disc already but when it's complete, the finished outcome is more or less the same way as i explained. When i play it on a DVD player and open menu, episodes don't run in order.Last edited by Teac23; 11th Nov 2013 at 08:09.
You mean it does not work if you burn a disc with the files renamed as:
001
002
002
004
etc
etc
Sorry hech54 for the late reply/thank you.
Yep, your advice worked a treat.
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 22:18 -
Burning Blu-ray Data Disc with ImgBurn.
By bbanderic in forum DVD & Blu-ray WritersReplies: 25Last Post: 11th Oct 2015, 12:21 -
long time to burn and extract dvd data disc
By gamemaniaco in forum DVD & Blu-ray WritersReplies: 10Last Post: 2nd Sep 2013, 08:32 -
Why I get a data disc every time when I burn BD-5 ?
By mahogany in forum Authoring (Blu-ray)Replies: 7Last Post: 6th Dec 2009, 03:10 -
Viewing ImgBurn .IBG graph data
By Seeker47 in forum Authoring (DVD)Replies: 9Last Post: 15th Jun 2009, 14:14
