Hello one and all.
I have a question:
Is there a software I can get for free or for pay that does this:
Reads a standard DVD disk,
and converts it,
and burns it,
to a Blu-Ray disk
Thank you.
Andy
TMPGenc Video Mastering Works 5, among others.
I assume you realize that you don't "convert" DVD to BluRay. You re-encode from DVD to BluRay. I assume you also realize that you can't make SD DVD look like HD by clicking a few icons. The DVD will still look like DVD, although at least slightly worse from re-encoding. If the DVD is commercial (copy protected), you'll have more work to do.
MultiAVCHD is another app. Several others are available.Last edited by sanlyn; 20th Mar 2014 at 05:39.
Assuming you are willing to accept movie only, there are tools to rewrap the dvd file to a blu-ray compliant file without encoding.
Such as DVDtoBD Express 2.0 Freeware.
Also it needs to be understood that keeping the dvd menu material isn't easy to do when transferring to blu-ray. -
BDRebuilder can also to dvd(s) to blu-ray.
But no software lets you keep the original menus. -
Free or pay software that will play blu-ray disk?
By mlong30 in forum Software PlayingReplies: 6Last Post: 2nd Dec 2011, 09:59 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
genuine blu-ray disk
By alintatoc in forum Off topicReplies: 3Last Post: 12th Jan 2010, 19:11 -
how can i convert file mpeg4 in blu ray disk
By gofresh in forum Authoring (Blu-ray)Replies: 4Last Post: 1st Mar 2009, 19:52 -
Will a blu ray disk play on regular dvd player in 480 lines of resolution?
By donfm in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2009, 06:00
