Hello, people! I have a problem, and I'd like some help. I have downloaded the Doctor Who 2005 S1E01 in HD and I want to add the spanish audio, but there's a problem - FPS. How can I sync the audio perfectly?
Here I give you the Media Info of them both archives:
General
Complete name : E:\download\doctor.who.2005.s01e01.1080p.bluray.x2 64-shortbrehd.mkv
Format : Matroska
Format version : Version 2
File size : 3.28 GiB
Duration : 46mn 20s
Overall bit rate : 10.1 Mbps
Writing application : mkvmerge v4.1.1 ('Bouncin' Back') built on Jul 3 2010 22:54:08
Writing library : libebml v1.0.0 + libmatroska v1.0
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 46mn 20s
Bit rate : 8 610 Kbps
Width : 1 872 pixels
Height : 1 080 pixels
Display aspect ratio : 1.733
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.178
Stream size : 2.72 GiB (83%)
Writing library : x264 core 138 r2358 9e941d1
Encoding settings : cabac=1 / ref=4 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=8610 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 46mn 20s
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 500 MiB (15%)
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:05:42.342 : en:00:05:42.342
00:08:15.328 : en:00:08:15.328
00:09:51.049 : en:00:09:51.049
00:15:30.513 : en:00:15:30.513
00:19:15.237 : en:00:19:15.237
00:25:04.378 : en:00:25:04.378
00:28:17.821 : en:00:28:17.821
00:33:10.155 : en:00:33:10.155
00:36:57.173 : en:00:36:57.173
00:41:50.883 : en:00:41:50.883
00:44:39.552 : en:00:44:39.552
00:45:20.509 : en:00:45:20.509
eneral
Unique ID : 236087570133926748063133805474204958512 (0xB19CCFE498B168CEA69245A4C2193F30)
Complete name : E:\download\Doctor.Who1x01micro480_buhillo29.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 511 MiB
Duration : 44mn 15s
Overall bit rate : 1 614 Kbps
Encoded date : UTC 2010-02-22 21:41:31
Writing application : mkvmerge v5.9.0 ('On The Loose') built on Dec 9 2012 15:37:01
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Video
Format : AVC
Format profile : High@L3.1
Format settings, ReFrames : 8 frames
Muxing mode : Header stripping
Duration : 44mn 15s
Bit rate : 1 454 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Original display aspect ratio : 16:9
Frame rate : 29.970 fps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.140
Stream size : 460 MiB (90%)
Writing library : x264 core 120
Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=100 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 44mn 15s
Bit rate : 128 Kbps
Channel(s) : 2 channels
Bit depth : 16 bits
Delay relative to video : 1s 0ms
Stream size : 40.5 MiB (8%)
Default : Yes
Forced : No
Assuming the frame count of the two sources is the same (which is a big assumption), stretch the Spanish audio to be the same length as the video to which you want to add it. You may be able to use a PAL to NTSC setting in an audio program, or maybe not.
Are you sure you're not discussing illegally downloaded warez? Which can't be done here. -
The same? There's a big diference, like 23 and 29.. and I don't know what you mean with that, how I do that?
I use MKVMergue to add the audios. -
Make up your mind.
The DVDs use a PAL source and are at PAL speed. There's only a 2 minute difference between the two. If it were really 23.976fps .vs 29.97fps, the difference would be much greater.There's a big diference, like 23 and 29.
If you don't know how to stretch audio and then remux it with a different video, you shouldn't be attempting a project this difficult. Walk before you run.I don't know what you mean with that, how I do that? -
Never too late to learn, can I at least know what software to use? I know to remux, aka add the audio with mkvtoolnix. I only don't know how to stretch the audio to fit.. mostly I just want to sync it.
Syncing NTSC 29.970 fps audio to PAL 50 fps video in MKV?
By Merazomo in forum Video ConversionReplies: 10Last Post: 23rd Oct 2013, 00:21 -
By Merazomo in forum AudioReplies: 0Last Post: 17th Oct 2013, 20:09 -
Audio syncing problem...
By Huntr777 in forum MacReplies: 3Last Post: 1st Aug 2011, 17:30 -
How to change MKV from 50 fps to 25 fps skipping every second frame?
By andreyyshore in forum EditingReplies: 11Last Post: 5th Feb 2011, 15:09 -
syncing an audio channel into a MKV
By Benygh in forum Video Streaming DownloadingReplies: 0Last Post: 1st Jan 2010, 16:05
