For some time, I've had audio sync issue on my edited videos and I believe that I have found the cause. I'm looking for a better alternative.
Generally, I record video from my satellite feed using my Hauppauge HD PVR and ArcSoft TotalMedia Extreme 2. Then I edit out the unwanted parts using Video Redo Suite 4.20.7.629.
The audio on my original recordings are synced well but usually there is a variable level of audio that is not in sync. I have attempted to adjust the sync using VLC but this hasn't been satisfactory because the audio sync varied within the video file. (i.e. I can sync one part but not the whole video).
I believe that the issue is caused by Video Redo.
Therefore 2 questions:
1. In Video Redo Options/Stream Paramaters, the "Detect/resync missing frames" is set to "Resync - Remove Audio Frames". I've tried "Insert extra video frames" -(doesn't help) and "Ignore" (video won't play). Is this the best setting or could something else be causing my problem?
2. Assuming that I can't adjust Video Redo to fix the problem, are there other programs that will edit out unwanted parts without recoding? (I really like the VideoReDo interface). I am usually editing MP4, TS, M2TS, MKV or MPG.
				Results 1 to 14 of 14
	one "smart rendering" alternative you can try is solveigmm video splitter
	I don't think so, having also in mind what you wrote about Solveigmm splitter. The stream must have errors which cannot be corrected otherwise than removing bad audio or video frames.
 I use VRD over 3 years and I had never any sync issue with a clean stream (satellite, DSLR camera).
	Need to know what channels you are trying to cap from and what settings in Arcsoft. I just finished a cap with that software and everything is in perfect sync. 11 Mbps, VBR, HDMI video and audio, 5.1 AC-3, TS format. Editing with VRD results in an in sync file without re-encoding.
	Sorry for the delay in responding. I've been away.
 It seems that you are assuming that my problem is ArcSoft. I don't claim to have the answer but I believe that the issue is Video ReDo. The files captured by ArcSoft have always been in sync. It's only after they are edited in VRD that most (but not all) are out of sync.
 Nonetheless, here is the info that you requested:
 -capturing from the PVR of a BellTV 9242 satelitte receiver
 -ArcSoft settings:
 - Video input - YPdRr
 - Audio input - S/PDIF
 - PC Audio Mode - 5.1 ch
 - Video Decoder - Video Standard - NTSC_M (This seemed odd. There is no alt for ATSC and I tried other settings
 but they didn't help.)
 - resolution - 1920x1080 30 fps
 - 7 Mbps
 - TS format (have also tried M2TS)
 -VRD Setting:
 - Stream Parameters - Detect/resync missing frames - set to - Resync - Remove Audio Frames
 (also tried - Resync - Insert Extra Video Frames - didn't help,
 also tried - Ignore - didn't help)
 There are many other VRD setting but none seemed to impact audio sync.
 Does any of this provide a clue?
	Other than Solveigmm splitter, TS-Doctor is the only other alternative to VideoReDo TV Suite H.264 that I have read about which claims to edit recordings from the Hauppauge HD-PVR, but it only works for .TS files. I don't know if it does smart encoding like VideoReDo.
	I'm sorry, but you're a bit of a dolt! Most of the VRD betas work absolutely fine, and if you do have any problems just post on the forum and most of the time you'll usually get a prompt response and often a fix from the authors. If you're concerned about installing betas then just install them in a different location and you can run them separately.
	I would suggest going to the VideoReDo forums and posting this there. They have always been responsive in the past. Forums http://www.videoredo.net/msgBoard/forum.php?
 http://www.videoredo.net/msgBoard/forumdisplay.php?39-VideoReDo-TVSuiteV4-w-H-264
 is the forum for the VideoReDo TVSuiteV4 w/H.264
 Good Luck
 TBoneitIf I'd known I was going to live this long, I'd have taken better care of myself.
	Did you buy your HD-PVR second-hand? I have probably looked at Hauppauge's HD-PVR webpage two dozen times since 2008 and can't recall ever seeing VideoReDo TV Suite H.264 bundled with it, only WinTV, Arcsoft TotalMedia Theatre, Arcsoft Media Converter and Arcsoft TotalMedia Extreme.
  Question about Video RedoBy snafubaby in forum EditingReplies: 6Last Post: 26th Feb 2012, 05:01
  Video Redo problemsBy Phaneendra Rao in forum Authoring (DVD)Replies: 6Last Post: 25th Feb 2012, 03:32
  Video playback problems after installing video editing suite - Please help!By abeelandig in forum Software PlayingReplies: 2Last Post: 5th Aug 2010, 22:54
  Online video lecture: best tool/suite?By zeteste in forum Newbie / General discussionsReplies: 0Last Post: 18th Dec 2008, 00:11
  AGK and Video-redo not recognizing my HDTV files...?By OrangeTTT in forum Video ConversionReplies: 17Last Post: 10th Dec 2008, 02:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
