Hi there,
I need to convert some large .mp4 files, encoded in h264, into uncompressed .avi.
The reason is that I have an old version of Premiere and can't afford a new one at the moment. I believe the new CC one supports clips in h264 for import but I have an older one.
I am used to video editing but know little about converting file types
I have tried:
- Virtualdub, but it cannot open the source file. After reading up, I found that I do not have H264 listed in the decoder window of ffdshow video converter. I vaguely understand this to be part of the problem but don't know how to change that.
- I tried OJOsoft Video Converter but it couldn't give me a raw .avi and the mpeg4 option gave some errors.
Is there a simpler way of doing this?
Any help would be much appreciated![]()
http://codecpack.co/download/FFInputDriver.html
Add the driver, then run VirtualDub.
Click 'File' > 'Open video file', highlight the input file but before clicking 'Open', use the drop down menu on the 'Files of type' box and select 'FFMpeg supported files' then click 'Open'. -
THANK YOU VERY MUCH!!!! You saved me! Me and my adobe after effect future!
I have cs4, and encoded mp4 footages are choppy after rendering..... and I downloaded virtual dub and plugins, and converted to AVI and now it works like magic! Thank you!!
How to Convert h264.MP4 to avi?
By skorpinok in forum Video ConversionReplies: 20Last Post: 22nd Oct 2015, 08:31 -
Uncompressed AVI to Quicktime H264
By Simmons in forum Video ConversionReplies: 7Last Post: 3rd Aug 2011, 20:15 -
need help converting .asf to h264 .mp4
By hydra3333 in forum Video ConversionReplies: 3Last Post: 12th Sep 2010, 08:53 -
Hardcoding subs into H264 video and converting to MP4
By muhali5 in forum Video ConversionReplies: 4Last Post: 28th Aug 2009, 11:57 -
Converting to H264 [.MP4] (mencoder) results in video playing too fast
By ChrisMtl in forum ffmpegX general discussionReplies: 4Last Post: 12th Nov 2008, 17:02
