How do I convert 29.970 fps audio to 23.976 with MeGUI?
Audio doesn't really have an "FPS"
You're implying that you want a 0.8x slowdown. (That's huge). Are you sure you want to do that ?
Can you provide some background information? -
The audio doesn't need to be changed since it relies on the time length of the video since 23.976 and 29.97 play at the same time length.
Yes I want to convert it because I got it from a video. I'm trying to convert the audio to .ac3 and then the video to .m2v. I read somewhere you have to "use the script as recommended by MeGUI that uses TIVTC, or perhaps the Decomb IVTC (Telecide/Decimate)" but I don't know how to do that.
No you don't. You just think you do. Not if you're still talking about the audio. The video length after an IVTC (23.976fps) will be exactly the same length as it started (29.97fps).
In the filters tab of MeGUI should be the way to set up an IVTC. I don't use it so maybe someone else can give you more specific instructions. -
Yeah because I don't think DVD plays 29.97. O.o
Yes it does. 29.97 is standard FPS playback for DVD. DVD at 23.97 requires 3:2 pulldown or telecine to match 29.972 spec. https://www.videohelp.com/dvd#tech
Syncing NTSC 29.970 fps audio to PAL 50 fps video in MKV?
By Merazomo in forum Video ConversionReplies: 10Last Post: 22nd Oct 2013, 23:21 -
By Merazomo in forum AudioReplies: 0Last Post: 17th Oct 2013, 19:09 -
Any decent way to convert higher fps movies to a lower 29.97 fps ? (or othe
By Jonz in forum Video ConversionReplies: 1Last Post: 5th Nov 2012, 02:01 -
Handbrake Lowering FPS issue (29.970 to 23.976) - Should I be concerned?
By kingaddi in forum DVD RippingReplies: 20Last Post: 3rd Sep 2012, 00:16 -
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 12:01
