Hi All,
I am into releasing TV stuff and after getting help from this forum I have started downloading TV shows from a website colors.in.com/in/24/ using AdobeHDS.php technique. Initially downloading was easy as the show was posted in a single link. But since last 5-6 episodes these people have started posting episodes in 10 parts. Now using the same AdobeHDS technique I still downloaded those 10 parts and started joining them using append option of mkvmerge/mkvtoolnix. All was fine till 8th episode and these people (people who are behind uploading these videos) went to another extent and now the downloaded parts cannot be joined without re-encoding them. Out of the 10 parts these people upload, 1 or 2 parts cannot be joined with rest of the parts due to some info not matching with respect to video track.
The parts I download using AdobeHDs gets downloaded into flv format. And when I try to join these 10 parts, I get error as follows :
"The track number 0 from the file 'Part 5.flv' can probably not be appended correctly to the track number 0 from the file 'Part 4.flv': The codec's private data does not match (lengths: 39 and 41). Please make sure that the resulting file plays correctly the whole time. The author of this program will probably not give support for playback issues with the resulting file."
I have tried joining/appending part 4 and part 5. Because I know that the problem is with Part 5. Now below are the mediainfo details of both the parts.
Part 4 MediaInfo :
Code:General Complete name : C:Part 4.flv Format : Flash Video File size : 20.2 MiB Duration : 4mn 55s Overall bit rate : 573 Kbps Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : 7 Duration : 4mn 55s Bit rate : 568 Kbps Width : 640 pixels Height : 360 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.082 Stream size : 20.0 MiB (99%) Audio Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 10 Duration : 4mn 55s Bit rate : 29.5 Kbps Channel(s) : 1 channel Channel positions : Front: C Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 1.04 MiB (5%)
Part 5 MediaInfo :
Code:General Complete name : Part 5.flv Format : Flash Video File size : 21.1 MiB Duration : 4mn 57s Overall bit rate : 594 Kbps Video Format : AVC Format/Info : Advanced Video Codec Format profile : Baseline@L3.0 Format settings, CABAC : No Format settings, ReFrames : 1 frame Codec ID : 7 Duration : 4mn 57s Bit rate : 581 Kbps Width : 640 pixels Height : 360 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.084 Stream size : 20.6 MiB (98%) Audio Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 10 Duration : 4mn 57s Bit rate : 32.1 Kbps Channel(s) : 1 channel Channel positions : Front: C Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 1.14 MiB (5%)
As you can see from the above Media Info, under Video part details such as Format profile, Format settings CABAC and Format settings ReFrames have different values for both the files. Apart from Part 5.flv, all other 9 files have the same values for Format profile, CABAC and Reframes. And only part 5 has different values. I tried downloading this part 5 three times and always get with the same settings.
This example is with respect to one episode. In the past I used to get 2-3 parts with the settings of Part 5 given above wherein CABAC value would be No, Reframes would be 1 and Format Profile would be Baseline @L3.0
Hence what I really want to know is, is there any procedure to make part 5 correct/fixed so that it gets value of CABAC as Yes, Reframes would be 4 and Format Profile would be HIGH @L3.0
If I am successful in getting this part 5 correct then I can append all other 9 parts with this. Else I have to re-encode each part again and then join/append them together.
In the future also, it would help me as files like part 5 are 2-3 , and I would be happy fixing these 2-3 files rather than re-encoding all.
Appreciate any help I get in this situation.
If anyone need all 10 files mediainfo, I can provide the same. Also if somebody needs the 2 files of which I gave an example above, I can provide those 2 also.
Try join FLV files with Andy's FLV Joiner
Bro its not just about joining. Please go through the whole thread once before responding. Joining similar flv files isnt the issues. But joining non-similar flv fles is the problem. I used the above suggested FLV joiner. The tool joins the files, but when I play the final file, the video turns plain green color screen for the same duration of the Part 5, I am complaining about.
My real concern isnt joinining. My concern is how to make Part 5's settings same as other parts have it. -
First of all, you will have to resample and reencode the audio part
Secondly, and PERHAPS even this suggestion might not work,
extract all the video elementary streams,
join them through "copy /b part01.264 + part 02.264 + .... + part10.264 fullvideo.264",
and only then, use MKVtoolnix, or MP4Box, or whatever. -
I think you mean to say re-encode the video part?? Because the fault is with the video part not the audio part. When I join the parts the errors what I get is ""The track number 0 from the file 'Part 5.flv' can probably not be appended correctly to the track number 0 from the file 'Part 4.flv'". By this i means the problem is with video track not audio track.
Trouble with opening flv files in Virtual Dub.
By drumwork83 in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2012, 22:53 -
Joining video files in mkvmerge
By Zee530 in forum Newbie / General discussionsReplies: 0Last Post: 13th Oct 2011, 15:29 -
Annoying 'gap sound' when joining flv files
By KeyMs92 in forum EditingReplies: 2Last Post: 17th Sep 2011, 20:31 -
Problem joining 2 MKV into 1 with MKVMerge.
By LiBiDoXP in forum Video ConversionReplies: 4Last Post: 29th Dec 2010, 02:07 -
Joining multiple FLV files into one?
By Super Warrior in forum EditingReplies: 2Last Post: 30th Jan 2009, 23:42
