I currently have been using TDA 1.6 for years, but never liked that after editing a dvd the subtitles where no longer forced onto the tv screen, which is a huge pain because no i the movie has subtitles, you have to manually set in from the dvd remote, and most times I forget that only a few scenes a particular movie have subtitles then have to back the dvd up to where the character is speaking another language and set the subtitles to display.
So I am looking for a dvd authoring program that is as simple as TDA to use (do any later versions of TDA force subtitles like unedited movie?)
Results 1 to 9 of 9
What We Do In Life, Echoes In Eternity....
You can use multiavchd which will allow forced subtitles.
I thought multiavchd wasn't updated anymore?
I suppose when dealing with dvds that shouldn't be a factor but if you are converting from high def that might be a problem somewhere along the conversion path.
Edit - just to be clear you can use "abandonware" it's just that if you run into problems you probably won't get any updates unless the designer really wants to go back into the program.
Does avstodvd offer this option? It offers so much but I don't know if this is one of them.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Not sure why you said that you thought multiavchd wasn't updated anymore when i said it can output dvd-video with forced subs,it still does a good job authoring.
Does it still (like versions 2-4 of TDA/TAW) use a built-in mpeg-2 encoder, which is on by default for re-encoding keyframes on chapter points and re-encoding the very last GOP (without ability to turn it off), and encoding LPCM to ac3 (also on by default for any new project)? These 'features' make me still use TDA1.6 (or muxman in case of multiple audio or subs) in combination with TAW4 for menus only (that's where I find newer versions to be good and convenient).
DVD players can still give discs the finger. It won't be forced.
I have several players that disobey instruction all the time. I can do what I want.
If you wanted "forced" subtitles, then simply embed them in the video.
Problem solved.Want my help? Ask here! (not via PM!)
Forced Subtitles --> In Between Bit <-- Full Subtitles
By OzDrDj in forum SubtitleReplies: 0Last Post: 1st Jun 2012, 02:11 -
forced subtitles
By bogey219 in forum SubtitleReplies: 4Last Post: 6th Nov 2011, 21:00 -
Forced Subtitles
By sxj1704 in forum Blu-ray RippingReplies: 4Last Post: 29th Jan 2011, 08:17 -
MKV TO BD-R with forced subtitles
By wthldh in forum Video ConversionReplies: 6Last Post: 21st May 2010, 10:19 -
Forced Subtitles Only In First Stream
By sambat in forum SubtitleReplies: 3Last Post: 28th Apr 2009, 22:05
