Hi!
I've more or less one year of excellent usage of MKVTOMP4 and my Apple TV 3. I've used h264 1080p(and subtitles) and the result has been great.
However, with my latest remuxes I experience freeze seconds at my Apple TV3. Almost all 1080p footage freezes nowadays, and I'm using a wired network so the bandwidht cannot be the issue. I think I've messed up the settings...
Exactly what settings do you guys use? I don't want to go down to 3.1 settings - especially when 4.1 has worked before.
Yes, that's the thing! The remuxes have - for example - an average bitrate of 10-15mb/s (where as the ATV has a max of 25mb/s). But - there's these max/tops of 30-40mb's bitrates which makes the viewing glitch.
It's my understanding that I had the settings before that kept the bitrate high but under the maximum allowed by ATV3. So, to go back to my first question - what settings do you guys use with the same gear? (ATV3 + wired network + 1080p h264 film at the size of ~8gb).
My dilemma is to use the preset of ATV3. Then the quality goes down to 3mb/s and the quality ratio to 3.1. I can't really understand why the bar is set so low - since the machine is able to playback 25mb/s and 4.0 in quality scale. What is that I'm missing here? (I mean that sentence in a serious way - not in a mocking way). -
Try ask in
https://forum.videohelp.com/threads/340675-Mkv%D0%A2%D0%BEMp4-v0-222-rapid-tool-for-repack-Mkv-to-Mp4
You could also try convert with something else and see how it works like vidcoder.
Or try stream/transcode the files directly with plex to the appletv3. But you maybe have tried that already.
Best options for re-encoding anime with MkvToMp4
By Blackblades in forum Video ConversionReplies: 3Last Post: 12th Oct 2013, 15:52 -
mkvtomp4 error
By eatatwhiteys in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2013, 11:36 -
x264 command line for max quality within Bluray spec?
By Asterra in forum Video ConversionReplies: 5Last Post: 5th Apr 2012, 16:22 -
MkvToMp4 vs YAMB
By jandor2009 in forum Video ConversionReplies: 0Last Post: 4th Jan 2012, 06:52 -
ATV-8710 TBC Info
By wahsac in forum RestorationReplies: 1Last Post: 29th Jul 2009, 00:50
