I am using avisynth imagesource for my time lapses.
However I want to achieve the trailing stars effect
Similar to what you see after 22s in this video
Please help?
How to overlay last "x" frames on the current frame. So video frame rate and duration is same, but you get trailing
Results 1 to 28 of 28
As I am a newbie I think it got removed
Try this one
I used Temporalsoften but it does not work the way I had hoped it would!
http://www.youtube.com/watch?v=oLd1gpVa5TY -
Looks like they were shot using "bulb exposure" very long shutter speeds. I'm not sure you can create the effect as well in post using short shutter speeds............
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
You can see many videos on youtube where shutter speeds used are less than 30 seconds. Video continues normally and then starts trailing,
Here is an adobe after effects tutorial
http://www.youtube.com/watch?v=L9lbs6Pxy0o -
Merge(SelectEven(),SelectOdd()) several times in a row. If the stars move more than a pixel between frames you'll get a trail of dots, not a continuous trail. And you'll probably find the stars dim too much. The latter is easily fixed by adjusting the contrast after each Merge().
Another possibility is Overlay(SelectEven(),SelectOdd(), mode="add") several times in a row.
Maybe you should provide a hundred or so sample images.Last edited by jagabo; 8th Nov 2013 at 14:13.
I suppose you could overlay say 5 ~ 10 frames in photoshop or Paint.NET (free) and reduce the opacity of the upper layers to expose the stars, then flatten and export as a single frame. You can then duplicate as needed to keep up with the video.
Just an idea, as I have never done that before.........Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
There is a function called clipblend() by StainlessS that will do something similar to the post plugins in after effects. You an specify the # previous frames to blend
http://forum.doom9.org/showthread.php?t=168048
Depending on your shot composition you might have to mask out the foreground (in your example, the foreground wasn't blended in the same manner as the starrs) . You can do that with a static mask done in a photo editor (e.g. gimp, photoshop) and overlay() in avisynth . Obviously if your shot was only of the sky, then it wouldn't matter
eg.
Overlay(base, filtered_overlay, mask)
You might have to adjust the clip depending on the timing of your exposures (eg. if they are too close together, you won't get the intended effect), e.g you might have to use something like SelectEvery with some interval to pick every "nth" frame
If you post an unfiltered example , someone might give you some more concrete suggestions -
If you read his description it say's,
http://www.liquidinplastic.com/2008/06/startrails/Check out my site and instructions on how to make your own star trails photos: www.liquidinplastic.com (click how to for the guide) -
Nope, I do not want to shoot star trails. I shot <30s exposures to get stars moving. Now I want to use an effect similar to cc time blend plugin in after effects
I used the plugin ClipBlend
It gives a similar effect, but creates a "Blur".
I am looking to replicate CC Time blend in avisynth
http://www.youtube.com/watch?v=3efz1cZT4zI -
Then you do need to look at that guide because it is exactly what you are trying to do...................Nope, I do not want to shoot star trails. I shot <30s exposures to get stars moving. Now I want to use an effect similar to cc time blend plugin in after effects
Very similar to what I suggested but a lot more automated. I downloaded the program, maybe I'll try it out when I have some time to shoot stars.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Please read my post. I do not want to shoot star trails. I want to shoot normal <30s shots, and then start trailing in video. I see many videos where every frame "adds" to the previous. So it keeps filling up If you see these videos I have posted you will see even airplane trails are set.
This effect is CC time blend in adobe photo shop. I need CC time blend equivalent for avisynth -
One almost functional equivalent in avisynth to CC Time Blend FX in AE would be to use script clip from gavino
Since you didn't provide a sample, I chose a random video source example (I choose between ~ 00:50:00 - 00:60:00) . You might have to adjust the parameters slightly for your video
http://www.youtube.com/watch?v=opydr6RwaY4
Code:FFVideoSource("Timelapse movie The Alps -- part II (night) (HD).mp4") Trim(1280,1480) main=last b=blankclip(main) ScriptClip(""" b = b.Loop(2,0,0).Overlay(last, mode="lighten") return b """) -
i am using high ISO (3200) at F2.8 11mm with a D7000
Have done a few time lapses. I saw some videos where the trail effect was done using CC Time blend. So I am really curious if some similar effect exists in avisynth. From what I could gather, with the use of plugins and scripts you can match everything the sony vegas or Adobe after effects can do -
Perrrrrrrrrrrrrrfect!
Thanks!!!
Can you please explain what does blankclip do with (main) as argument?
Here is my script line to load all my images (1-129)
At 10fps its a 12.9 seconds long clip
S1=ImageSource("Filename-%d.jpg", 1, 129, 10).Lanczos4Resize(1920,1080) -
Should it be this?
Gives me syntax error
Code:S1=ImageSource("...converted\A-%d.jpg", 1, 129, 10).Lanczos4Resize(1920,1080).ConvertToRGB b=blankclip(S1) ScriptClip(""" b = b.Loop(2,0,0).Overlay(S1, mode="lighten") return b """) -
Format it the same way as above
You probably don't need ConvertToRGB, becuase ImageSource() will return RGB from a jpeg sequenceCode:ImageSource("...converted\A-%d.jpg", 1, 129, 10) Lanczos4Resize(1920,1080) #ConvertToRGB S1=last b=blankclip(s1) ScriptClip(""" b = b.Loop(2,0,0).Overlay(last, mode="lighten") return b """) -
Way to go Poisondeathray.............!
My test example produced interesting results, even the clouds have trails.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
@poisondeathray! Thanks a lot for this!
I went through the documentation of ScriptClip but could not figure out how the script works.
Can you explain how it works, and how to use it in different scenarios
For example my video script has
S1 = ....
S2 = ....
S3 =...
And so on
Then I create
Dissolve(S1,S2...) etc.,
What if I want to create a S1_trail copy in my mega script?
When I saw S1=avisource(...) what does "last" variable contain? -
Run the trail code on just s1, then Dissolve() or add (+) with the other clips.
Any time you don't explicitely name a clip the name "last" is implied. So a sequence like:Code:s1 = ... s2 = ... s3 = ... last=s1 b=blankclip(last) s1trails=ScriptClip(""" b = b.Loop(2,0,0).Overlay(last, mode="lighten") return b """) Dissolve(s1trails, s2, 15) return(last+s3)
is the equivalent ofCode:AviSource("filename.avi") Reverse()
Code:last = AviSource("filename.avi") last = Reverse(last)Last edited by jagabo; 10th Nov 2013 at 08:05.
Here's a variation on the trails method.
Code:function StarTrails(clip vid, int depth) { vid = Overlay(vid.SelectEven(), vid.SelectOdd(), mode="lighten") depth = depth - 1 depth > 0 ? StarTrails(vid, depth) : vid } ffVideoSource("Timelapse movie_ The Alps -- part II (night).mp4").Trim(620,1920) v1=last v2=Trim(last,6,0) v3=Trim(last,13,0) v4=Trim(last,19,0) v5=Trim(last,26,0) Interleave(StarTrails(v1,5),StarTrails(v2,5),StarTrails(v3,5),StarTrails(v4,5),StarTrails(v5,5)) AssumeFPS(25) -
time lapse
By Viacon in forum Newbie / General discussionsReplies: 26Last Post: 17th Nov 2013, 21:57 -
Time Lapse on a Bicycle
By Bluelemmy in forum Newbie / General discussionsReplies: 30Last Post: 7th Jun 2013, 13:55 -
Need help to determine the best way to make a time lapse video
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jun 2013, 11:22 -
Best method for time lapse video
By jairovital in forum EditingReplies: 38Last Post: 26th Apr 2012, 13:11 -
Time-lapse on HV40
By videobread in forum EditingReplies: 1Last Post: 25th Dec 2011, 16:26
