Page 8 of 27
FirstFirst ... 6 7 8 9 10 18 ... LastLast
Results 211 to 240 of 782
    Aug 2013
    Central Germany
    None of them will have insisted in keeping Windows XP supported...
  2. DECEASED
    Jun 2009
    Heaven
    Just to make things as clear as possible --- as I said before,
    x265 can go and should have gone 64-bit only.
    So it would never ever have gotten in the way of the 32-bit builds of ffmpeg
  3. Member vhelp's Avatar
    Mar 2001
    New York
    i did not see any notable speed improvement since, using build 0.9+31 is my last bv since download sites (ie, mefiafire) are blocked on my pc's.
    for 720x480 content via avisynth script and --preset ultrafast:
    my netbook (atom cpu) gives me <1fps using ultrafast, while my desktop home pc gives me betwen 2.5fps and 6fps depending on picture complexities--ie, on mostly dark or solid areas (the more the greater or lessor the encoding speed) than on areas or all frames with various kinds of motion complexities, thus explaining the speed variance in those lessor detailed frames. i think that everybody knows this fact by now.
    and i agree that ultrafast may not be very usefull in some pc setups and videos, but on very slow computers like mine, its better than nothing and testing is still worthwhile. i just wish that the team could resolve the cpu or instruction incompatabilities that cause my netbook intel atom and two intel core i3 and intel core i7 computers to fail on the latest x265.exe encoders.
  4. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Lets be realistic, it will be years (at least) before hevc overtakes avs as the standard platform. The cpu horsepower required to decode hevc is rediculous to say the least even @ 1080p. It's fun to experiment with these new codecs, but I don't plan to use them anytime soon.
    No disrespect to the developers, keep them comming.............
  5. Member vhelp's Avatar
    Mar 2001
    New York
    my realistic threashold is for 720x480 since my desktop pc can easily handle it with the current flavors of h265 codecs floating around. even though we've been in the 1080p era for a while i'm still using SD content since that is my main source for the time being. others with better systems may use 720p and 1080p as their primary test bed. all are good, and should be tested, imo. but we need to get organized, create several groups to test this and that, and so on, but in this early stage, that is not the case. anyway. for the analitical work, i use avisynth + l-smash to decode and review frames up close. my goal(s) in part of this is to find out what params serve for "grain retension" and then fine tune it, etc., plus making sure that such params primary function remain consistant through the builds. there are no "template" foundations to work from. we have to create them, make them standards, and use them as part in all these tests.
  6. Member vhelp's Avatar
    Mar 2001
    New York
    i was searching for the listing of the all the parameters for the --preset but can't find it.
    i am looking for the latest changes to these presets, for current 09+31 and later builds.
    http://x265.readthedocs.org/en/default/
    --preset, -p <integer|string>
    Sets parameters to preselected values, trading off compression efficiency against encoding
    speed. These parameters are applied before all other input parameters are applied, and so
    you can override any parameters that these values control.
    0. ultrafast   -
    1. superfast   -
    2. veryfast    -
    3. faster      -
    4. fast        -
    5. medium(def) -
    6. slow        -
    7. slower      -
    8. veryslow    -
    9. placebo     -
  7. look into: /source/common/param.cpp
    extern "C"
    int x265_param_default_preset(x265_param *param, const char *preset, const char *tune)
        x265_param_default(param);
        if (preset)
            char *end;
            int i = strtol(preset, &end, 10);
            if (*end == 0 && i >= 0 && i < (int)(sizeof(x265_preset_names) / sizeof(*x265_preset_names) - 1))
                preset = x265_preset_names[i];
            if (!strcmp(preset, "ultrafast"))
                param->lookaheadDepth = 10;
                param->scenecutThreshold = 0; // disable lookahead
                param->maxCUSize = 32;
                param->searchRange = 25;
                param->bFrameAdaptive = 0;
                param->subpelRefine = 0;
                param->searchMethod = X265_DIA_SEARCH;
                param->bEnableRectInter = 0;
                param->bEnableAMP = 0;
                param->bEnableEarlySkip = 1;
                param->bEnableCbfFastMode = 1;
                param->bEnableSAO = 0;
                param->bEnableSignHiding = 0;
                param->bEnableWeightedPred = 0;
                param->maxNumReferences = 1;
                param->rc.aqStrength = 0.0;
                param->rc.aqMode = X265_AQ_NONE;
                param->rc.cuTree = 0;
            else if (!strcmp(preset, "superfast"))
                param->searchRange = 44;
                param->subpelRefine = 1;
            else if (!strcmp(preset, "veryfast"))
                param->lookaheadDepth = 15;
            else if (!strcmp(preset, "faster"))
            else if (!strcmp(preset, "fast"))
            else if (!strcmp(preset, "medium"))
                /* defaults */
            else if (!strcmp(preset, "slow"))
                param->lookaheadDepth = 25;
                param->rdLevel = 4;
                param->subpelRefine = 3;
                param->maxNumMergeCand = 3;
                param->searchMethod = X265_STAR_SEARCH;
            else if (!strcmp(preset, "slower"))
                param->lookaheadDepth = 30;
                param->bframes = 8;
                param->tuQTMaxInterDepth = 2;
                param->tuQTMaxIntraDepth = 2;
                param->rdLevel = 6;
            else if (!strcmp(preset, "veryslow"))
                param->lookaheadDepth = 40;
                param->bframes = 8;
                param->tuQTMaxInterDepth = 3;
                param->tuQTMaxIntraDepth = 3;
                param->rdLevel = 6;
                param->subpelRefine = 4;
                param->maxNumMergeCand = 4;
                param->maxNumReferences = 5;
            else if (!strcmp(preset, "placebo"))
                param->lookaheadDepth = 60;
                param->searchRange = 92;
                param->bframes = 8;
                param->tuQTMaxInterDepth = 4;
                param->tuQTMaxIntraDepth = 4;
                param->rdLevel = 6;
                param->subpelRefine = 5;
                param->maxNumMergeCand = 5;
                param->bEnableTransformSkip = 1;
                // TODO: optimized esa
            else
                return -1;
        if (tune)
            if (!strcmp(tune, "psnr"))
            else if (!strcmp(tune, "ssim"))
                param->rc.aqMode = X265_AQ_AUTO_VARIANCE;
            else if (!strcmp(tune, "fastdecode") ||
                     !strcmp(tune, "fast-decode"))
                param->bEnableLoopFilter = 0;
                param->bEnableWeightedBiPred = 0;
            else if (!strcmp(tune, "zerolatency") ||
                     !strcmp(tune, "zero-latency"))
                param->bframes = 0;
                param->lookaheadDepth = 0;
            else
                return -1;
        return 0;
    and since the defauls are the base for the profiles:
    extern "C"
    void x265_param_default(x265_param *param)
        memset(param, 0, sizeof(x265_param));
        /* Applying non-zero default values to all elements in the param structure */
        param->cpuid = x265::cpu_detect();
        param->logLevel = X265_LOG_INFO;
        param->bEnableWavefront = 1;
        param->frameNumThreads = 0;
        param->poolNumThreads = 0;
        param->csvfn = NULL;
        /* Source specifications */
        param->internalBitDepth = x265_max_bit_depth;
        param->internalCsp = X265_CSP_I420;
        /* CU definitions */
        param->maxCUSize = 64;
        param->tuQTMaxInterDepth = 1;
        param->tuQTMaxIntraDepth = 1;
        /* Coding Structure */
        param->keyframeMin = 0;
        param->keyframeMax = 250;
        param->bOpenGOP = 1;
        param->bframes = 4;
        param->lookaheadDepth = 20;
        param->bFrameAdaptive = X265_B_ADAPT_TRELLIS;
        param->bBPyramid = 1;
        param->scenecutThreshold = 40; /* Magic number pulled in from x264 */
        /* Intra Coding Tools */
        param->bEnableConstrainedIntra = 0;
        param->bEnableStrongIntraSmoothing = 1;
        /* Inter Coding tools */
        param->searchMethod = X265_HEX_SEARCH;
        param->subpelRefine = 2;
        param->searchRange = 57;
        param->maxNumMergeCand = 2;
        param->bEnableWeightedPred = 1;
        param->bEnableEarlySkip = 0;
        param->bEnableCbfFastMode = 0;
        param->bEnableAMP = 1;
        param->bEnableRectInter = 1;
        param->rdLevel = 3;
        param->bEnableSignHiding = 1;
        param->bEnableTransformSkip = 0;
        param->bEnableTSkipFast = 0;
        param->maxNumReferences = 3;
        /* Loop Filter */
        param->bEnableLoopFilter = 1;
        /* SAO Loop Filter */
        param->bEnableSAO = 1;
        param->saoLcuBoundary = 0;
        param->saoLcuBasedOptimization = 1;
        /* Coding Quality */
        param->cbQpOffset = 0;
        param->crQpOffset = 0;
        param->rdPenalty = 0;
        /* Rate control options */
        param->rc.vbvMaxBitrate = 0;
        param->rc.vbvBufferSize = 0;
        param->rc.vbvBufferInit = 0.9;
        param->rc.rfConstant = 28;
        param->rc.bitrate = 0;
        param->rc.rateTolerance = 1.0;
        param->rc.qCompress = 0.6;
        param->rc.ipFactor = 1.4f;
        param->rc.pbFactor = 1.3f;
        param->rc.qpStep = 4;
        param->rc.rateControlMode = X265_RC_CRF;
        param->rc.qp = 32;
        param->rc.aqMode = X265_AQ_VARIANCE;
        param->rc.aqStrength = 1.0;
        param->rc.cuTree = 1;
        /* Quality Measurement Metrics */
        param->bEnablePsnr = 0;
        param->bEnableSsim = 0;
        /* Video Usability Information (VUI) */
        param->vui.aspectRatioIdc = 0;
        param->vui.sarWidth = 0;
        param->vui.sarHeight = 0;
        param->vui.bEnableOverscanAppropriateFlag = 0;
        param->vui.bEnableVideoSignalTypePresentFlag = 0;
        param->vui.videoFormat = 5;
        param->vui.bEnableVideoFullRangeFlag = 0;
        param->vui.bEnableColorDescriptionPresentFlag = 0;
        param->vui.colorPrimaries = 2;
        param->vui.transferCharacteristics = 2;
        param->vui.matrixCoeffs = 2;
        param->vui.bEnableChromaLocInfoPresentFlag = 0;
        param->vui.chromaSampleLocTypeTopField = 0;
        param->vui.chromaSampleLocTypeBottomField = 0;
        param->vui.bEnableDefaultDisplayWindowFlag = 0;
        param->vui.defDispWinLeftOffset = 0;
        param->vui.defDispWinRightOffset = 0;
        param->vui.defDispWinTopOffset = 0;
        param->vui.defDispWinBottomOffset = 0;
    extern "C"
    int x265_param_apply_profile(x265_param *param, const char *profile)
        if (!profile)
            return 0;
        if (!strcmp(profile, "main"))
        else if (!strcmp(profile, "main10"))
    #if HIGH_BIT_DEPTH
            param->internalBitDepth = 10;
    #else
            x265_log(param, X265_LOG_WARNING, "Main10 not supported, not compiled for 16bpp.\n");
            return -1;
    #endif
        else if (!strcmp(profile, "mainstillpicture"))
            /* technically the stream should only have one picture, but we do not
             * enforce this */
            param->bRepeatHeaders = 1;
            param->keyframeMax = 1;
            param->bOpenGOP = 0;
        else
            x265_log(param, X265_LOG_ERROR, "unknown profile <%s>\n", profile);
            return -1;
        return 0;
    -> have fun
    if you want you can read up on the strange doc site they use and write a patch to the documentation
  8. Member vhelp's Avatar
    Mar 2001
    New York
    i will try and work this out in excel somehow, thank you.
  9. Member vhelp's Avatar
    Mar 2001
    New York
    lookaheadDepth       10           ultrafast
    scenecutThreshold     0 // disable lookahead
    maxCUSize            32
    searchRange          25
    bFrameAdaptive        0
    subpelRefine          0
    searchMethod          X265_DIA_SEARCH
    bEnableRectInter      0
    bEnableAMP            0
    bEnableEarlySkip      1
    bEnableCbfFastMode    1
    bEnableSAO            0
    bEnableSignHiding     0
    bEnableWeightedPred   0
    maxNumReferences      1
    rc.aqStrength         0.0
    rc.aqMode             X265_AQ_NONE
    rc.cuTree             0
    lookaheadDepth       10           superfast
    maxCUSize            32
    searchRange          44
    bFrameAdaptive        0
    subpelRefine          1
    bEnableRectInter      0
    bEnableAMP            0
    bEnableEarlySkip      1
    maxNumReferences      1
    rc.aqStrength       0.0
    rc.cuTree             0
    lookaheadDepth       15           veryfast
    maxCUSize            32
    bFrameAdaptive        0
    subpelRefine          1
    bEnableRectInter      0
    bEnableAMP            0
    bEnableEarlySkip      1
    maxNumReferences      1
    rc.cuTree             0
    lookaheadDepth       15           faster
    bFrameAdaptive        0
    bEnableRectInter      0
    bEnableAMP            0
    bEnableEarlySkip      1
    maxNumReferences      1
    rc.cuTree             0
    bEnableRectInter      0
    bEnableAMP            0
    lookaheadDepth       25           slower
    rdLevel               4
    subpelRefine          3
    maxNumMergeCand       3
    searchMethod          X265_STAR_SEARCH
    lookaheadDepth       30           slower
    bframes               8
    tuQTMaxInterDepth     2
    tuQTMaxIntraDepth     2
    rdLevel               6
    subpelRefine          3
    maxNumMergeCand       3
    lookaheadDepth       40           veryslow
    bframes               8
    tuQTMaxInterDepth     3
    tuQTMaxIntraDepth     3
    rdLevel               6
    subpelRefine          4
    maxNumMergeCand       4
    maxNumReferences      5           placebo
    lookaheadDepth       60
    searchRange          92
    bframes               8
    tuQTMaxInterDepth     4
    tuQTMaxIntraDepth     4
    rdLevel               6
    subpelRefine          5
    maxNumMergeCand       5
    bEnableTransformSkip  1
    maxNumReferences      5
  10. x265 - Grupo VideoLAN - Updated: 20 Apr 2014
    x265 is a free software library and application for encoding video streams into the H.265/MPEG-H HEVC compression format, and is released under the terms of the GNU GPL.
    Font: http://www.videolan.org/developers/x265.html
    Features Overview
    Provides next-generation compression and codec.
    Fast and excellent quality.
    Completly free and libre software, ensuring freedom for everyone.
    The APIs are similar to x264 APIs
    Getting x265
    Source
    The latest x265 source code can always be found by anonymous hg repository:
    # hg clone http://hg.videolan.org/x265
    You can browse the source on-line.
    Encoder features
    Full prediction and transform quad-tree recursion supported
    Adaptive B-frame placement
    B-frames as references / arbitrary frame order
    CABAC entropy coding
    Intra: all block types (32x32, 16x16, 8x8, 4x4, and PCM with all predictions)
    Inter P: all partitions (from 64x64 down to 8x4)
    Inter B: partitions from 64x64 down to 8x4 (including all merge modes
    and biprediction)
    Weighted prediction for P slices
    Multiple reference frames
    Ratecontrol: constant quantizer, constant quality, single pass ABR, optional VBV
    Scenecut detection
    Parallel encoding on multiple CPUs, both frame-level and wavefront parallelism
    view source/x265.h @ 6728:2fc309678785
    Merge with stable
    author 	Steve Borho <steve@borho.org>
    date 	Wed, 16 Apr 2014 21:17:54 -0500 (4 days ago)
    parents 	c1300ae4e7ba
    children
    line source
    1 /*****************************************************************************
    2 * Copyright (C) 2013 x265 project
    3 *
    4 * Authors: Steve Borho <steve@borho.org>
    5 *
    6 * This program is free software; you can redistribute it and/or modify
    7 * it under the terms of the GNU General Public License as published by
    8 * the Free Software Foundation; either version 2 of the License, or
    9 * (at your option) any later version.
    10 *
    11 * This program is distributed in the hope that it will be useful,
    12 * but WITHOUT ANY WARRANTY; without even the implied warranty of
    13 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
    14 * GNU General Public License for more details.
    15 *
    16 * You should have received a copy of the GNU General Public License
    17 * along with this program; if not, write to the Free Software
    18 * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02111, USA.
    19 *
    20 * This program is also available under a commercial proprietary license.
    21 * For more information, contact us at licensing@multicorewareinc.com.
    22 *****************************************************************************/
    23
    24 #ifndef X265_H
    25 #define X265_H
    26
    27 #include <stdint.h>
    28 #include "x265_config.h"
    29
    30 #ifdef __cplusplus
    31 extern "C" {
    32 #endif
    33
    34 /* x265_encoder:
    35 * opaque handler for encoder */
    36 typedef struct x265_encoder x265_encoder;
    37
    38 /* Application developers planning to link against a shared library version of
    39 * libx265 from a Microsoft Visual Studio or similar development environment
    40 * will need to define X265_API_IMPORTS before including this header.
    41 * This clause does not apply to MinGW, similar development environments, or non
    42 * Windows platforms. */
    43 #ifdef X265_API_IMPORTS
    44 #define X265_API __declspec(dllimport)
    45 #else
    46 #define X265_API
    47 #endif
    48
    49 typedef enum
    50 {
    51 NAL_UNIT_CODED_SLICE_TRAIL_N = 0,
    52 NAL_UNIT_CODED_SLICE_TRAIL_R,
    53 NAL_UNIT_CODED_SLICE_TSA_N,
    54 NAL_UNIT_CODED_SLICE_TLA_R,
    55 NAL_UNIT_CODED_SLICE_STSA_N,
    56 NAL_UNIT_CODED_SLICE_STSA_R,
    57 NAL_UNIT_CODED_SLICE_RADL_N,
    58 NAL_UNIT_CODED_SLICE_RADL_R,
    59 NAL_UNIT_CODED_SLICE_RASL_N,
    60 NAL_UNIT_CODED_SLICE_RASL_R,
    61 NAL_UNIT_CODED_SLICE_BLA_W_LP = 16,
    62 NAL_UNIT_CODED_SLICE_BLA_W_RADL,
    63 NAL_UNIT_CODED_SLICE_BLA_N_LP,
    64 NAL_UNIT_CODED_SLICE_IDR_W_RADL,
    65 NAL_UNIT_CODED_SLICE_IDR_N_LP,
    66 NAL_UNIT_CODED_SLICE_CRA,
    67 NAL_UNIT_VPS = 32,
    68 NAL_UNIT_SPS,
    69 NAL_UNIT_PPS,
    70 NAL_UNIT_ACCESS_UNIT_DELIMITER,
    71 NAL_UNIT_EOS,
    72 NAL_UNIT_EOB,
    73 NAL_UNIT_FILLER_DATA,
    74 NAL_UNIT_PREFIX_SEI,
    75 NAL_UNIT_SUFFIX_SEI,
    76 NAL_UNIT_INVALID = 64,
    77 } NalUnitType;
    78
    79 /* The data within the payload is already NAL-encapsulated; the type is merely
    80 * in the struct for easy access by the calling application. All data returned
    81 * in an x265_nal, including the data in payload, is no longer valid after the
    82 * next call to x265_encoder_encode. Thus it must be used or copied before
    83 * calling x265_encoder_encode again. */
    84 typedef struct x265_nal
    85 {
    86 uint32_t type; /* NalUnitType */
    87 uint32_t sizeBytes; /* size in bytes */
    88 uint8_t* payload;
    89 } x265_nal;
    90
    91 /* Used to pass pictures into the encoder, and to get picture data back out of
    92 * the encoder. The input and output semantics are different */
    93 typedef struct x265_picture
    94 {
    95 /* Must be specified on input pictures, the number of planes is determined
    96 * by the colorSpace value */
    97 void* planes[3];
    98
    99 /* Stride is the number of bytes between row starts */
    100 int stride[3];
    101
    102 /* Must be specified on input pictures. x265_picture_init() will set it to
    103 * the encoder's internal bit depth, but this field must describe the depth
    104 * of the input pictures. Must be between 8 and 16. Values larger than 8
    105 * imply 16bits per input sample. If input bit depth is larger than the
    106 * internal bit depth, the encoder will down-shift pixels. Input samples
    107 * larger than 8bits will be masked to internal bit depth. On output the
    108 * bitDepth will be the internal encoder bit depth */
    109 int bitDepth;
    110
    111 /* Must be specified on input pictures: X265_TYPE_AUTO or other.
    112 * x265_picture_init() sets this to auto, returned on output */
    113 int sliceType;
    114
    115 /* Ignored on input, set to picture count, returned on output */
    116 int poc;
    117
    118 /* Must be specified on input pictures: X265_CSP_I420 or other. It must
    119 * match the internal color space of the encoder. x265_picture_init() will
    120 * initialize this value to the internal color space */
    121 int colorSpace;
    122
    123 /* presentation time stamp: user-specified, returned on output */
    124 int64_t pts;
    125
    126 /* display time stamp: ignored on input, copied from reordered pts. Returned
    127 * on output */
    128 int64_t dts;
    129
    130 /* The value provided on input is returned with the same picture (POC) on
    131 * output */
    132 void* userData;
    133
    134 /* new data members to this structure must be added to the end so that
    135 * users of x265_picture_alloc/free() can be assured of future safety */
    136 } x265_picture;
    137
    138 typedef enum
    139 {
    140 X265_DIA_SEARCH,
    141 X265_HEX_SEARCH,
    142 X265_UMH_SEARCH,
    143 X265_STAR_SEARCH,
    144 X265_FULL_SEARCH
    145 } X265_ME_METHODS;
    146
    147 /* CPU flags */
    148
    149 /* x86 */
    150 #define X265_CPU_CMOV 0x0000001
    151 #define X265_CPU_MMX 0x0000002
    152 #define X265_CPU_MMX2 0x0000004 /* MMX2 aka MMXEXT aka ISSE */
    153 #define X265_CPU_MMXEXT X265_CPU_MMX2
    154 #define X265_CPU_SSE 0x0000008
    155 #define X265_CPU_SSE2 0x0000010
    156 #define X265_CPU_SSE3 0x0000020
    157 #define X265_CPU_SSSE3 0x0000040
    158 #define X265_CPU_SSE4 0x0000080 /* SSE4.1 */
    159 #define X265_CPU_SSE42 0x0000100 /* SSE4.2 */
    160 #define X265_CPU_LZCNT 0x0000200 /* Phenom support for "leading zero count" instruction. */
    161 #define X265_CPU_AVX 0x0000400 /* AVX support: requires OS support even if YMM registers aren't used. */
    162 #define X265_CPU_XOP 0x0000800 /* AMD XOP */
    163 #define X265_CPU_FMA4 0x0001000 /* AMD FMA4 */
    164 #define X265_CPU_AVX2 0x0002000 /* AVX2 */
    165 #define X265_CPU_FMA3 0x0004000 /* Intel FMA3 */
    166 #define X265_CPU_BMI1 0x0008000 /* BMI1 */
    167 #define X265_CPU_BMI2 0x0010000 /* BMI2 */
    168 /* x86 modifiers */
    169 #define X265_CPU_CACHELINE_32 0x0020000 /* avoid memory loads that span the border between two cachelines */
    170 #define X265_CPU_CACHELINE_64 0x0040000 /* 32/64 is the size of a cacheline in bytes */
    171 #define X265_CPU_SSE2_IS_SLOW 0x0080000 /* avoid most SSE2 functions on Athlon64 */
    172 #define X265_CPU_SSE2_IS_FAST 0x0100000 /* a few functions are only faster on Core2 and Phenom */
    173 #define X265_CPU_SLOW_SHUFFLE 0x0200000 /* The Conroe has a slow shuffle unit (relative to overall SSE performance) */
    174 #define X265_CPU_STACK_MOD4 0x0400000 /* if stack is only mod4 and not mod16 */
    175 #define X265_CPU_SLOW_CTZ 0x0800000 /* BSR/BSF x86 instructions are really slow on some CPUs */
    176 #define X265_CPU_SLOW_ATOM 0x1000000 /* The Atom is terrible: slow SSE unaligned loads, slow
    177 * SIMD multiplies, slow SIMD variable shifts, slow pshufb,
    178 * cacheline split penalties -- gather everything here that
    179 * isn't shared by other CPUs to avoid making half a dozen
    180 * new SLOW flags. */
    181 #define X265_CPU_SLOW_PSHUFB 0x2000000 /* such as on the Intel Atom */
    182 #define X265_CPU_SLOW_PALIGNR 0x4000000 /* such as on the AMD Bobcat */
    183
    184 /* ARM */
    185 #define X265_CPU_ARMV6 0x0000001
    186 #define X265_CPU_NEON 0x0000002 /* ARM NEON */
    187 #define X265_CPU_FAST_NEON_MRC 0x0000004 /* Transfer from NEON to ARM register is fast (Cortex-A9) */
    188
    189 #define X265_MAX_SUBPEL_LEVEL 7
    190
    191 /* Log level */
    192 #define X265_LOG_NONE (-1)
    193 #define X265_LOG_ERROR 0
    194 #define X265_LOG_WARNING 1
    195 #define X265_LOG_INFO 2
    196 #define X265_LOG_DEBUG 3
    197 #define X265_LOG_FULL 4
    198
    199 #define X265_B_ADAPT_NONE 0
    200 #define X265_B_ADAPT_FAST 1
    201 #define X265_B_ADAPT_TRELLIS 2
    202
    203 #define X265_BFRAME_MAX 16
    204
    205 #define X265_TYPE_AUTO 0x0000 /* Let x265 choose the right type */
    206 #define X265_TYPE_IDR 0x0001
    207 #define X265_TYPE_I 0x0002
    208 #define X265_TYPE_P 0x0003
    209 #define X265_TYPE_BREF 0x0004 /* Non-disposable B-frame */
    210 #define X265_TYPE_B 0x0005
    211
    212 #define X265_AQ_NONE 0
    213 #define X265_AQ_VARIANCE 1
    214 #define X265_AQ_AUTO_VARIANCE 2
    215 #define IS_X265_TYPE_I(x) ((x) == X265_TYPE_I || (x) == X265_TYPE_IDR)
    216 #define IS_X265_TYPE_B(x) ((x) == X265_TYPE_B || (x) == X265_TYPE_BREF)
    217
    218 /* NOTE! For this release only X265_CSP_I420 and X265_CSP_I444 are supported */
    219
    220 /* Supported internal color space types (according to semantics of chroma_format_idc) */
    221 #define X265_CSP_I400 0 /* yuv 4:0:0 planar */
    222 #define X265_CSP_I420 1 /* yuv 4:2:0 planar */
    223 #define X265_CSP_I422 2 /* yuv 4:2:2 planar */
    224 #define X265_CSP_I444 3 /* yuv 4:4:4 planar */
    225 #define X265_CSP_COUNT 4 /* Number of supported internal color spaces */
    226
    227 /* These color spaces will eventually be supported as input pictures. The pictures will
    228 * be converted to the appropriate planar color spaces at ingest */
    229 #define X265_CSP_NV12 4 /* yuv 4:2:0, with one y plane and one packed u+v */
    230 #define X265_CSP_NV16 5 /* yuv 4:2:2, with one y plane and one packed u+v */
    231
    232 /* Interleaved color-spaces may eventually be supported as input pictures */
    233 #define X265_CSP_BGR 6 /* packed bgr 24bits */
    234 #define X265_CSP_BGRA 7 /* packed bgr 32bits */
    235 #define X265_CSP_RGB 8 /* packed rgb 24bits */
    236 #define X265_CSP_MAX 9 /* end of list */
    237
    238 #define X265_EXTENDED_SAR 255 /* aspect ratio explicitly specified as width:height */
    239
    240 typedef struct
    241 {
    242 int planes;
    243 int width[3];
    244 int height[3];
    245 } x265_cli_csp;
    246
    247 static const x265_cli_csp x265_cli_csps[] =
    248 {
    249 { 1, { 0, 0, 0 }, { 0, 0, 0 } }, /* i400 */
    250 { 3, { 0, 1, 1 }, { 0, 1, 1 } }, /* i420 */
    251 { 3, { 0, 1, 1 }, { 0, 0, 0 } }, /* i422 */
    252 { 3, { 0, 0, 0 }, { 0, 0, 0 } }, /* i444 */
    253 { 2, { 0, 0 }, { 0, 1 } }, /* nv12 */
    254 { 2, { 0, 0 }, { 0, 0 } }, /* nv16 */
    255 };
    256
    257 /* rate tolerance method */
    258 typedef enum
    259 {
    260 X265_RC_ABR,
    261 X265_RC_CQP,
    262 X265_RC_CRF
    263 } X265_RC_METHODS;
    264
    265 /* Output statistics from encoder */
    266 typedef struct x265_stats
    267 {
    268 double globalPsnrY;
    269 double globalPsnrU;
    270 double globalPsnrV;
    271 double globalPsnr;
    272 double globalSsim;
    273 double elapsedEncodeTime; /* wall time since encoder was opened */
    274 double elapsedVideoTime; /* encoded picture count / frame rate */
    275 double bitrate; /* accBits / elapsed video time */
    276 uint32_t encodedPictureCount; /* number of output pictures thus far */
    277 uint32_t totalWPFrames; /* number of uni-directional weighted frames used */
    278 uint64_t accBits; /* total bits output thus far */
    279
    280 /* new statistic member variables must be added below this line */
    281 } x265_stats;
    282
    283 /* String values accepted by x265_param_parse() (and CLI) for various parameters */
    284 static const char * const x265_motion_est_names[] = { "dia", "hex", "umh", "star", "full", 0 };
    285 static const char * const x265_source_csp_names[] = { "i400", "i420", "i422", "i444", "nv12", "nv16", 0 };
    286 static const char * const x265_video_format_names[] = { "component", "pal", "ntsc", "secam", "mac", "undef", 0 };
    287 static const char * const x265_fullrange_names[] = { "limited", "full", 0 };
    288 static const char * const x265_colorprim_names[] = { "", "bt709", "undef", "", "bt470m", "bt470bg", "smpte170m", "smpte240m", "film", "bt2020", 0 };
    289 static const char * const x265_transfer_names[] = { "", "bt709", "undef", "", "bt470m", "bt470bg", "smpte170m", "smpte240m", "linear", "log100",
    290 "log316", "iec61966-2-4", "bt1361e", "iec61966-2-1", "bt2020-10", "bt2020-12", 0 };
    291 static const char * const x265_colmatrix_names[] = { "GBR", "bt709", "undef", "", "fcc", "bt470bg", "smpte170m", "smpte240m",
    292 "YCgCo", "bt2020nc", "bt2020c", 0 };
    293 static const char * const x265_sar_names[] = { "undef", "1:1", "12:11", "10:11", "16:11", "40:33", "24:11", "20:11",
    294 "32:11", "80:33", "18:11", "15:11", "64:33", "160:99", "4:3", "3:2", "2:1", 0 };
    295 static const char * const x265_interlace_names[] = { "prog", "tff", "bff", 0 };
    296
    297 /* x265 input parameters
    298 *
    299 * For version safety you may use x265_param_alloc/free() to manage the
    300 * allocation of x265_param instances, and x265_param_parse() to assign values
    301 * by name. By never dereferencing param fields in your own code you can treat
    302 * x265_param as an opaque data structure */
    303 typedef struct x265_param
    304 {
    305 /*== Encoder Environment ==*/
    306
    307 /* x265_param_default() will auto-detect this cpu capability bitmap. it is
    308 * recommended to not change this value unless you know the cpu detection is
    309 * somehow flawed on your target hardware. The asm function tables are
    310 * process global, the first encoder configures them for all encoders */
    311 int cpuid;
    312
    313 /* Enable wavefront parallel processing, greatly increases parallelism for
    314 * less than 1% compression efficiency loss */
    315 int bEnableWavefront;
    316
    317 /* Number of threads to allocate for the process global thread pool, if no
    318 * thread pool has yet been created. 0 implies auto-detection. By default
    319 * x265 will try to allocate one worker thread per CPU core */
    320 int poolNumThreads;
    321
    322 /* Number of concurrently encoded frames, 0 implies auto-detection. By
    323 * default x265 will use a number of frame threads emperically determined to
    324 * be optimal for your CPU core count, between 2 and 6. Using more than one
    325 * frame thread causes motion search in the down direction to be clamped but
    326 * otherwise encode behavior is unaffected. With CQP rate control the output
    327 * bitstream is deterministic for all values of frameNumThreads greater than
    328 * 1. All other forms of rate-control can be negatively impacted by
    329 * increases to the number of frame threads because the extra concurrency
    330 * adds uncertainty to the bitrate estimations. There is no limit to the
    331 * number of frame threads you use for each encoder, but frame parallelism
    332 * is generally limited by the the number of CU rows */
    333 int frameNumThreads;
    334
    335 /* The level of logging detail emitted by the encoder. X265_LOG_NONE to
    336 * X265_LOG_FULL, default is X265_LOG_INFO */
    337 int logLevel;
    338
    339 /* Enable the measurement and reporting of PSNR. Default is enabled */
    340 int bEnablePsnr;
    341
    342 /* Enable the measurement and reporting of SSIM. Default is disabled */
    343 int bEnableSsim;
    344
    345 /* filename of CSV log. If logLevel is X265_LOG_DEBUG, the encoder will emit
    346 * per-slice statistics to this log file in encode order. Otherwise the
    347 * encoder will emit per-stream statistics into the log file when
    348 * x265_encoder_log is called (presumably at the end of the encode) */
    349 const char *csvfn;
    350
    351 /* Enable the generation of SEI messages for each encoded frame containing
    352 * the hashes of the three reconstructed picture planes. Most decoders will
    353 * validate those hashes against the reconstructed images it generates and
    354 * report any mismatches. This is essentially a debugging feature. Hash
    355 * types are MD5(1), CRC(2), Checksum(3). Default is 0, none */
    356 int decodedPictureHashSEI;
    357
    358 /*== Internal Picture Specification ==*/
    359
    360 /* Internal encoder bit depth. If x265 was compiled to use 8bit pixels
    361 * (HIGH_BIT_DEPTH=0), this field must be 8, else this field must be 10.
    362 * Future builds may support 12bit pixels. */
    363 int internalBitDepth;
    364
    365 /* Color space of internal pictures. Only X265_CSP_I420 and X265_CSP_I444
    366 * are supported. Eventually, i422 will also be supported as an internal
    367 * color space and other packed formats will be supported in
    368 * x265_picture.colorSpace */
    369 int internalCsp;
    370
    371 /* Numerator and denominator of frame rate */
    372 uint32_t fpsNum;
    373 uint32_t fpsDenom;
    374
    375 /* Width (in pixels) of the source pictures. If this width is not an even
    376 * multiple of 4, the encoder will pad the pictures internally to meet this
    377 * minimum requirement. All valid HEVC widths are supported */
    378 int sourceWidth;
    379
    380 /* Height (in pixels) of the source pictures. If this height is not an even
    381 * multiple of 4, the encoder will pad the pictures internally to meet this
    382 * minimum requirement. All valid HEVC heights are supported */
    383 int sourceHeight;
    384
    385 /* Interlace type of source pictures. 0 - progressive pictures (default).
    386 * 1 - top field first, 2 - bottom field first. HEVC encodes interlaced
    387 * content as fields, they must be provided to the encoder in the correct
    388 * temporal order. EXPERIMENTAL */
    389 int interlaceMode;
    390
    391 /* Flag indicating whether VPS, SPS and PPS headers should be output with
    392 * each keyframe. Default false */
    393 int bRepeatHeaders;
    394
    395 /* Flag indicating whether the encoder should emit an Access Unit Delimiter
    396 * NAL at the start of every access unit. Default false */
    397 int bEnableAccessUnitDelimiters;
    398
    399 /*== Coding Unit (CU) definitions ==*/
    400
    401 /* Maxiumum CU width and height in pixels. The size must be 64, 32, or 16.
    402 * The higher the size, the more efficiently x265 can encode areas of low
    403 * complexity, greatly improving compression efficiency at large
    404 * resolutions. The smaller the size, the more effective wavefront and
    405 * frame parallelism will become because of the increase in rows. default 64 */
    406 uint32_t maxCUSize;
    407
    408 /* The additional depth the residual quadtree is allowed to recurse beyond
    409 * the coding quadtree, for inter coded blocks. This must be between 1 and
    410 * 3. The higher the value the more efficiently the residual can be
    411 * compressed by the DCT transforms, at the expense of much more compute */
    412 uint32_t tuQTMaxInterDepth;
    413
    414 /* The additional depth the residual quadtree is allowed to recurse beyond
    415 * the coding quadtree, for intra coded blocks. This must be between 1 and
    416 * 3. The higher the value the more efficiently the residual can be
    417 * compressed by the DCT transforms, at the expense of much more compute */
    418 uint32_t tuQTMaxIntraDepth;
    419
    420 /*== GOP Structure and Lokoahead ==*/
    421
    422 /* Enable open GOP - meaning I slices are not necessariy IDR and thus frames
    423 * encoded after an I slice may reference frames encoded prior to the I
    424 * frame which have remained in the decoded picture buffer. Open GOP
    425 * generally has better compression efficiency and negligable encoder
    426 * performance impact, but the use case may preclude it. Default true */
    427 int bOpenGOP;
    428
    429 /* Scenecuts closer together than this are coded as I, not IDR. */
    430 int keyframeMin;
    431
    432 /* Maximum keyframe distance or intra period in number of frames. If 0 or 1,
    433 * all frames are I frames. A negative value is casted to MAX_INT internally
    434 * which effectively makes frame 0 the only I frame. Default is 250 */
    435 int keyframeMax;
    436
    437 /* The maximum number of L0 references a P or B slice may use. This
    438 * influences the size of the decoded picture buffer. The higher this
    439 * number, the more reference frames there will be available for motion
    440 * search, improving compression efficiency of most video at a cost of
    441 * performance. Value must be between 1 and 16, default is 3 */
    442 int maxNumReferences;
    443
    444 /* Sets the operating mode of the lookahead. With b-adapt 0, the GOP
    445 * structure is fixed based on the values of keyframeMax and bframes.
    446 * With b-adapt 1 a light lookahead is used to chose B frame placement.
    447 * With b-adapt 2 (trellis) a viterbi B path selection is performed */
    448 int bFrameAdaptive;
    449
    450 /* Maximum consecutive B frames that can be emitted by the lookehead. When
    451 * b-adapt is 0 and keyframMax is greater than bframes, the lookahead emits
    452 * a fixed pattern of `bframes` B frames between each P. With b-adapt 1 the
    453 * lookahead ignores the value of bframes for the most part. With b-adapt 2
    454 * the value of bframes determines the search (POC) distance performeed in
    455 * both directions, quadradically increasing the compute load of the
    456 * lookahead. The higher the value, the more B frames the lookahead may
    457 * possibly use consecutively, usually improving compression. Default is 3,
    458 * maximum is 16 */
    459 int bframes;
    460
    461 /* When enabled, the encoder will use the B frame in the middle of each
    462 * mini-GOP larger than 2 B frames as a motion reference for the surrounding
    463 * B frames. This improves compression efficiency for a small performance
    464 * penalty. Referenced B frames are treated somewhere between a B and a P
    465 * frame by rate control. Default is enabled. */
    466 int bBPyramid;
    467
    468 /* The number of frames that must be queued in the lookahead before it may
    469 * make slice decisions. Increasing this value directly increases the encode
    470 * latency. The longer the queue the more optimally the lookahead may make
    471 * slice decisions, particularly with b-adapt 2. When mb-tree is enabled,
    472 * the length of the queue linearly increases the effectiveness of the
    473 * mb-tree analysis. Default is 40 frames, maximum is 250 */
    474 int lookaheadDepth;
    475
    476 /* A value which is added to the cost estimate of B frames in the lookahead.
    477 * It may be a positive value (making B frames appear more expensive, which
    478 * causes the lookahead to chose more P frames) or negative, which makes the
    479 * lookahead chose more B frames. Default is 0, there are no limits */
    480 int bFrameBias;
    481
    482 /* An arbitrary threshold which determines how agressively the lookahead
    483 * should detect scene cuts. The default (40) is recommended. */
    484 int scenecutThreshold;
    485
    486 /*== Intra Coding Tools ==*/
    487
    488 /* Enable constrained intra prediction. This causes intra prediction to
    489 * input samples that were inter predicted. For some use cases this is
    490 * believed to me more robust to stream errors, but it has a compression
    491 * penalty on P and (particularly) B slices. Defaults to diabled */
    492 int bEnableConstrainedIntra;
    493
    494 /* Enable strong intra smoothing for 32x32 blocks where the reference
    495 * samples are flat. It may or may not improve compression efficiency,
    496 * depending on your source material. Defaults to disabled */
    497 int bEnableStrongIntraSmoothing;
    498
    499 /*== Inter Coding Tools ==*/
    500
    501 /* ME search method (DIA, HEX, UMH, STAR, FULL). The search patterns
    502 * (methods) are sorted in increasing complexity, with diamond being the
    503 * simplest and fastest and full being the slowest. DIA, HEX, and UMH were
    504 * adapted from x264 directly. STAR is an adaption of the HEVC reference
    505 * encoder's three step search, while full is a naive exhaustive search. The
    506 * default is the star search, it has a good balance of performance and
    507 * compression efficiecy */
    508 int searchMethod;
    509
    510 /* A value between 0 and X265_MAX_SUBPEL_LEVEL which adjusts the amount of
    511 * effort performed during subpel refine. Default is 5 */
    512 int subpelRefine;
    513
    514 /* The maximum distance from the motion prediction that the full pel motion
    515 * search is allowed to progress before terminating. This value can have an
    516 * effect on frame parallelism, as referenced frames must be at least this
    517 * many rows of reconstructed pixels ahead of the referencee at all times.
    518 * (When considering reference lag, the motion prediction must be ignored
    519 * because it cannot be known ahead of time). Default is 60, which is the
    520 * default max CU size (64) minus the luma HPEL half-filter length (4). If a
    521 * smaller CU size is used, the search range should be similarly reduced */
    522 int searchRange;
    523
    524 /* The maximum number of merge candidates that are considered during inter
    525 * analysis. This number (between 1 and 5) is signaled in the stream
    526 * headers and determines the number of bits required to signal a merge so
    527 * it can have significant trade-offs. The smaller this number the higher
    528 * the performance but the less compression efficiency. Default is 3 */
    529 uint32_t maxNumMergeCand;
    530
    531 /* Enable weighted prediction in P slices. This enables weighting analysis
    532 * in the lookahead, which influences slice decisions, and enables weighting
    533 * analysis in the main encoder which allows P reference samples to have a
    534 * weight function applied to them prior to using them for motion
    535 * compensation. In video which has lighting changes, it can give a large
    536 * improvement in compression efficiency. Default is enabled */
    537 int bEnableWeightedPred;
    538
    539 /* Enable weighted prediction in B slices. Default is disabled */
    540 int bEnableWeightedBiPred;
    541
    542 /*== Analysis tools ==*/
    543
    544 /* Enable asymmetrical motion predictions. At CU depths 64, 32, and 16, it
    545 * is possible to use 25%/75% split partitions in the up, down, right, left
    546 * directions. For some material this can improve compression efficiency at
    547 * the cost of extra analysis. bEnableRectInter must be enabled for this
    548 * feature to be used. Default enabled */
    549 int bEnableAMP;
    550
    551 /* Enable rectangular motion prediction partitions (vertical and
    552 * horizontal), available at all CU depths from 64x64 to 8x8. Default is
    553 * enabled */
    554 int bEnableRectInter;
    555
    556 /* Enable the use of `coded block flags` (flags set to true when a residual
    557 * has been coded for a given block) to avoid intra analysis in likely skip
    558 * blocks. Default is disabled */
    559 int bEnableCbfFastMode;
    560
    561 /* Enable early skip decisions to avoid intra and inter analysis in likely
    562 * skip blocks. Default is disabled */
    563 int bEnableEarlySkip;
    564
    565 /* Apply an optional penalty to the estimated cost of 32x32 intra blocks in
    566 * non-intra slices. 0 is disabled, 1 enables a small penalty, and 2 enables
    567 * a full penalty. This favors inter-coding and its low bitrate over
    568 * potential increases in distortion, but usually improves performance.
    569 * Default is 0 */
    570 int rdPenalty;
    571
    572 /* A value betwen X265_NO_RDO_NO_RDOQ and X265_RDO_LEVEL which determines
    573 * the level of rate distortion optimizations to perform during mode
    574 * decisions and quantization. The more RDO the better the compression
    575 * efficiency at a major cost of performance. Default is no RDO (0) */
    576 int rdLevel;
    577
    578 /*== Coding tools ==*/
    579
    580 /* Enable the implicit signaling of the sign bit of the last coefficient of
    581 * each transform unit. This saves one bit per TU at the expense of figuring
    582 * out which coefficient can be toggled with the least distortion.
    583 * Default is enabled */
    584 int bEnableSignHiding;
    585
    586 /* Allow intra coded blocks to be encoded directly as residual without the
    587 * DCT transform, when this improves efficiency. Checking whether the block
    588 * will benefit from this option incurs a performance penalty. Default is
    589 * enabled */
    590 int bEnableTransformSkip;
    591
    592 /* Enable a faster determination of whether skippig the DCT transform will
    593 * be beneficial. Slight performance gain for some compression loss. Default
    594 * is enabled */
    595 int bEnableTSkipFast;
    596
    597 /* Enable the deblocking loop filter, which improves visual quality by
    598 * reducing blocking effects at block edges, particularly at lower bitrates
    599 * or higher QP. When enabled it adds another CU row of reference lag,
    600 * reducing frame parallelism effectiveness. Default is enabled */
    601 int bEnableLoopFilter;
    602
    603 /* Enable the Sample Adaptive Offset loop filter, which reduces distortion
    604 * effects by adjusting reconstructed sample values based on histogram
    605 * analysis to better approximate the original samples. When enabled it adds
    606 * a CU row of reference lag, reducing frame parallelism effectiveness.
    607 * Default is enabled */
    608 int bEnableSAO;
    609
    610 /* Note: when deblocking and SAO are both enabled, the loop filter CU lag is
    611 * only one row, as they operate in series o the same row. */
    612
    613 /* Select the method in which SAO deals with deblocking boundary pixels. If
    614 * 0 the right and bottom boundary areas are skipped. If 1, non-deblocked
    615 * pixels are used entirely. Default is 0 */
    616 int saoLcuBoundary;
    617
    618 /* Select the scope of the SAO optimization. If 0 SAO is performed over the
    619 * entire output picture at once, this can severly restrict frame
    620 * parallelism so it is not recommended for many-core machines. If 1 SAO is
    621 * performed on LCUs in series. Default is 1 */
    622 int saoLcuBasedOptimization;
    623
    624 /* Generally a small signed integer which offsets the QP used to quantize
    625 * the Cb chroma residual (delta from luma QP specified by rate-control).
    626 * Default is 0, which is recommended */
    627 int cbQpOffset;
    628
    629 /* Generally a small signed integer which offsets the QP used to quantize
    630 * the Cr chroma residual (delta from luma QP specified by rate-control).
    631 * Default is 0, which is recommended */
    632 int crQpOffset;
    633
    634 /*== Rate Control ==*/
    635
    636 struct
    637 {
    638 /* Explicit mode of rate-control, necessary for API users. It must
    639 * be one of the X265_RC_METHODS enum values. */
    640 int rateControlMode;
    641
    642 /* Base QP to use for Constant QP rate control. Adaptive QP may alter
    643 * the QP used for each block. If a QP is specified on the command line
    644 * CQP rate control is implied. Default: 32 */
    645 int qp;
    646
    647 /* target bitrate for Average BitRate (ABR) rate control. If a non- zero
    648 * bitrate is specified on the command line, ABR is implied. Default 0 */
    649 int bitrate;
    650
    651 /* The degree of rate fluctuation that x265 tolerates. Rate tolerance is used
    652 * alongwith overflow (difference between actual and target bitrate), to adjust
    653 qp. Default is 1.0 */
    654 double rateTolerance;
    655
    656 /* qComp sets the quantizer curve compression factor. It weights the frame
    657 * quantizer based on the complexity of residual (measured by lookahead).
    658 * Default value is 0.6. Increasing it to 1 will effectively generate CQP */
    659 double qCompress;
    660
    661 /* QP offset between I/P and P/B frames. Default ipfactor: 1.4
    662 * Default pbFactor: 1.3 */
    663 double ipFactor;
    664 double pbFactor;
    665
    666 /* Max QP difference between frames. Default: 4 */
    667 int qpStep;
    668
    669 /* Ratefactor constant: targets a certain constant "quality".
    670 * Acceptable values between 0 and 51. Default value: 28 */
    671 double rfConstant;
    672
    673 /* Enable adaptive quantization. This mode distributes available bits between all
    674 * macroblocks of a frame, assigning more bits to low complexity areas. Turning
    675 * this ON will usually affect PSNR negatively, however SSIM and visual quality
    676 * generally improves. Default: X265_AQ_VARIANCE */
    677 int aqMode;
    678
    679 /* Sets the strength of AQ bias towards low detail macroblocks. Valid only if
    680 * AQ is enabled. Default value: 1.0. Acceptable values between 0.0 and 3.0 */
    681 double aqStrength;
    682
    683 /* Sets the maximum rate the VBV buffer should be assumed to refill at
    684 * Default is zero */
    685 int vbvMaxBitrate;
    686
    687 /* Sets the size of the VBV buffer in kilobits. Default is zero */
    688 int vbvBufferSize;
    689
    690 /* Sets how full the VBV buffer must be before playback starts. If it is less than
    691 * 1, then the initial fill is vbv-init * vbvBufferSize. Otherwise, it is
    692 * interpreted as the initial fill in kbits. Default is 0.9 */
    693 double vbvBufferInit;
    694
    695 /* Enable CUTree ratecontrol. This keeps track of the CUs that propagate temporally
    696 * across frames and assigns more bits to these CUs. Improves encode efficiency.
    697 * Default: enabled */
    698 int cuTree;
    699
    700 /* In CRF mode, maximum CRF as caused by VBV. 0 implies no limit */
    701 double rfConstantMax;
    702 } rc;
    703
    704 /*== Video Usability Information ==*/
    705 struct
    706 {
    707 /* Aspect ratio idc to be added to the VUI. The default is 0 indicating
    708 * the apsect ratio is unspecified. If set to X265_EXTENDED_SAR then
    709 * sarWidth and sarHeight must also be set */
    710 int aspectRatioIdc;
    711
    712 /* Sample Aspect Ratio width in arbitrary units to be added to the VUI
    713 * only if aspectRatioIdc is set to X265_EXTENDED_SAR. This is the width
    714 * of an individual pixel. If this is set then sarHeight must also be set */
    715 int sarWidth;
    716
    717 /* Sample Aspect Ratio height in arbitrary units to be added to the VUI.
    718 * only if aspectRatioIdc is set to X265_EXTENDED_SAR. This is the width
    719 * of an individual pixel. If this is set then sarWidth must also be set */
    720 int sarHeight;
    721
    722 /* Enable overscan info present flag in the VUI. If this is set then
    723 * bEnabledOverscanAppropriateFlag will be added to the VUI. The default
    724 * is false */
    725 int bEnableOverscanInfoPresentFlag;
    726
    727 /* Enable overscan appropriate flag. The status of this flag is added
    728 * to the VUI only if bEnableOverscanInfoPresentFlag is set. If this
    729 * flag is set then cropped decoded pictures may be output for display.
    730 * The default is false */
    731 int bEnableOverscanAppropriateFlag;
    732
    733 /* Video signal type present flag of the VUI. If this is set then
    734 * videoFormat, bEnableVideoFullRangeFlag and
    735 * bEnableColorDescriptionPresentFlag will be added to the VUI. The
    736 * default is false */
    737 int bEnableVideoSignalTypePresentFlag;
    738
    739 /* Video format of the source video. 0 = component, 1 = PAL, 2 = NTSC,
    740 * 3 = SECAM, 4 = MAC, 5 = unspecified video format is the default */
    741 int videoFormat;
    742
    743 /* Video full range flag indicates the black level and range of the luma
    744 * and chroma signals as derived from E′Y, E′PB, and E′PR or E′R, E′G,
    745 * and E′B real-valued component signals. The default is false */
    746 int bEnableVideoFullRangeFlag;
    747
    748 /* Color description present flag in the VUI. If this is set then
    749 * color_primaries, transfer_characteristics and matrix_coeffs are to be
    750 * added to the VUI. The default is false */
    751 int bEnableColorDescriptionPresentFlag;
    752
    753 /* Color primaries holds the chromacity coordinates of the source
    754 * primaries. The default is 2 */
    755 int colorPrimaries;
    756
    757 /* Transfer characteristics indicates the opto-electronic transfer
    758 * characteristic of the source picture. The default is 2 */
    759 int transferCharacteristics;
    760
    761 /* Matrix coefficients used to derive the luma and chroma signals from
    762 * the red, blue and green primaries. The default is 2 */
    763 int matrixCoeffs;
    764
    765 /* Chroma location info present flag adds chroma_sample_loc_type_top_field and
    766 * chroma_sample_loc_type_bottom_field to the VUI. The default is false */
    767 int bEnableChromaLocInfoPresentFlag;
    768
    769 /* Chroma sample location type top field holds the chroma location in
    770 * the top field. The default is 0 */
    771 int chromaSampleLocTypeTopField;
    772
    773 /* Chroma sample location type bottom field holds the chroma location in
    774 * the bottom field. The default is 0 */
    775 int chromaSampleLocTypeBottomField;
    776
    777 /* Default display window flag adds def_disp_win_left_offset,
    778 * def_disp_win_right_offset, def_disp_win_top_offset and
    779 * def_disp_win_bottom_offset to the VUI. The default is false */
    780 int bEnableDefaultDisplayWindowFlag;
    781
    782 /* Default display window left offset holds the left offset with the
    783 * conformance cropping window to further crop the displayed window */
    784 int defDispWinLeftOffset;
    785
    786 /* Default display window right offset holds the right offset with the
    787 * conformance cropping window to further crop the displayed window */
    788 int defDispWinRightOffset;
    789
    790 /* Default display window top offset holds the top offset with the
    791 * conformance cropping window to further crop the displayed window */
    792 int defDispWinTopOffset;
    793
    794 /* Default display window bottom offset holds the bottom offset with the
    795 * conformance cropping window to further crop the displayed window */
    796 int defDispWinBottomOffset;
    797 } vui;
    798
    799 } x265_param;
    800
    801 /***
    802 * If not called, first encoder allocated will auto-detect the CPU and
    803 * initialize performance primitives, which are process global.
    804 * DEPRECATED: use x265_param.cpuid to specify CPU */
    805 void x265_setup_primitives(x265_param *param, int cpu);
    806
    807 /* x265_param_alloc:
    808 * Allocates an x265_param instance. The returned param structure is not
    809 * special in any way, but using this method together with x265_param_free()
    810 * and x265_param_parse() to set values by name allows the application to treat
    811 * x265_param as an opaque data struct for version safety */
    812 x265_param *x265_param_alloc();
    813
    814 /* x265_param_free:
    815 * Use x265_param_free() to release storage for an x265_param instance
    816 * allocated by x26_param_alloc() */
    817 void x265_param_free(x265_param *);
    818
    819 /***
    820 * Initialize an x265_param_t structure to default values
    821 */
    822 void x265_param_default(x265_param *param);
    823
    824 /* x265_param_parse:
    825 * set one parameter by name.
    826 * returns 0 on success, or returns one of the following errors.
    827 * note: BAD_VALUE occurs only if it can't even parse the value,
    828 * numerical range is not checked until x265_encoder_open() or
    829 * x265_encoder_reconfig().
    830 * value=NULL means "true" for boolean options, but is a BAD_VALUE for non-booleans. */
    831 #define X265_PARAM_BAD_NAME (-1)
    832 #define X265_PARAM_BAD_VALUE (-2)
    833 int x265_param_parse(x265_param *p, const char *name, const char *value);
    834
    835 /* x265_param_apply_profile:
    836 * Applies the restrictions of the given profile. (one of below) */
    837 static const char * const x265_profile_names[] = { "main", "main10", "mainstillpicture", 0 };
    838
    839 /* (can be NULL, in which case the function will do nothing)
    840 * returns 0 on success, negative on failure (e.g. invalid profile name). */
    841 int x265_param_apply_profile(x265_param *, const char *profile);
    842
    843 /* x265_param_default_preset:
    844 * The same as x265_param_default, but also use the passed preset and tune
    845 * to modify the default settings.
    846 * (either can be NULL, which implies no preset or no tune, respectively)
    847 *
    848 * Currently available presets are, ordered from fastest to slowest: */
    849 static const char * const x265_preset_names[] = { "ultrafast", "superfast", "veryfast", "faster", "fast", "medium", "slow", "slower", "veryslow", "placebo", 0 };
    850
    851 /* The presets can also be indexed numerically, as in:
    852 * x265_param_default_preset( &param, "3", ... )
    853 * with ultrafast mapping to "0" and placebo mapping to "9". This mapping may
    854 * of course change if new presets are added in between, but will always be
    855 * ordered from fastest to slowest.
    856 *
    857 * Warning: the speed of these presets scales dramatically. Ultrafast is a full
    858 * 100 times faster than placebo!
    859 *
    860 * Currently available tunings are: */
    861 static const char * const x265_tune_names[] = { "psnr", "ssim", "zerolatency", "fastdecode", 0 };
    862
    863 /* returns 0 on success, negative on failure (e.g. invalid preset/tune name). */
    864 int x265_param_default_preset(x265_param *, const char *preset, const char *tune);
    865
    866 /* x265_picture_alloc:
    867 * Allocates an x265_picture instance. The returned picture structure is not
    868 * special in any way, but using this method together with x265_picture_free()
    869 * and x265_picture_init() allows some version safety. New picture fields will
    870 * always be added to the end of x265_picture */
    871 x265_picture *x265_picture_alloc();
    872
    873 /* x265_picture_free:
    874 * Use x265_picture_free() to release storage for an x265_picture instance
    875 * allocated by x26_picture_alloc() */
    876 void x265_picture_free(x265_picture *);
    877
    878 /***
    879 * Initialize an x265_picture structure to default values. It sets the pixel
    880 * depth and color space to the encoder's internal values and sets the slice
    881 * type to auto - so the lookahead will determine slice type.
    882 */
    883 void x265_picture_init(x265_param *param, x265_picture *pic);
    884
    885 /* x265_max_bit_depth:
    886 * Specifies the maximum number of bits per pixel that x265 can input. This
    887 * is also the max bit depth that x265 encodes in. When x265_max_bit_depth
    888 * is 8, the internal and input bit depths must be 8. When
    889 * x265_max_bit_depth is 12, the internal and input bit depths can be
    890 * either 8, 10, or 12. Note that the internal bit depth must be the same
    891 * for all encoders allocated in the same process. */
    892 X265_API extern const int x265_max_bit_depth;
    893
    894 /* x265_version_str:
    895 * A static string containing the version of this compiled x265 library */
    896 X265_API extern const char *x265_version_str;
    897
    898 /* x265_build_info:
    899 * A static string describing the compiler and target architecture */
    900 X265_API extern const char *x265_build_info_str;
    901
    902 /* Force a link error in the case of linking against an incompatible API version.
    903 * Glue #defines exist to force correct macro expansion; the final output of the macro
    904 * is x265_encoder_open_##X264_BUILD (for purposes of dlopen). */
    905 #define x265_encoder_glue1(x, y) x ## y
    906 #define x265_encoder_glue2(x, y) x265_encoder_glue1(x, y)
    907 #define x265_encoder_open x265_encoder_glue2(x265_encoder_open_, X265_BUILD)
    908
    909 /* x265_encoder_open:
    910 * create a new encoder handler, all parameters from x265_param_t are copied */
    911 x265_encoder* x265_encoder_open(x265_param *);
    912
    913 /* x265_encoder_headers:
    914 * return the SPS and PPS that will be used for the whole stream.
    915 * *pi_nal is the number of NAL units outputted in pp_nal.
    916 * returns negative on error, total byte size of payload data on success
    917 * the payloads of all output NALs are guaranteed to be sequential in memory. */
    918 int x265_encoder_headers(x265_encoder *, x265_nal **pp_nal, uint32_t *pi_nal);
    919
    920 /* x265_encoder_encode:
    921 * encode one picture.
    922 * *pi_nal is the number of NAL units outputted in pp_nal.
    923 * returns negative on error, zero if no NAL units returned.
    924 * the payloads of all output NALs are guaranteed to be sequential in memory. */
    925 int x265_encoder_encode(x265_encoder *encoder, x265_nal **pp_nal, uint32_t *pi_nal, x265_picture *pic_in, x265_picture *pic_out);
    926
    927 /* x265_encoder_get_stats:
    928 * returns encoder statistics */
    929 void x265_encoder_get_stats(x265_encoder *encoder, x265_stats *, uint32_t statsSizeBytes);
    930
    931 /* x265_encoder_log:
    932 * write a line to the configured CSV file. If a CSV filename was not
    933 * configured, or file open failed, or the log level indicated frame level
    934 * logging, this function will perform no write. */
    935 void x265_encoder_log(x265_encoder *encoder, int argc, char **argv);
    936
    937 /* x265_encoder_close:
    938 * close an encoder handler */
    939 void x265_encoder_close(x265_encoder *);
    940
    941 /***
    942 * Release library static allocations
    943 */
    944 void x265_cleanup(void);
    945
    946 #ifdef __cplusplus
    947 }
    948 #endif
    949
    950 #endif // X265_H
  11. Is this only a mirror of the bitbucket repository or will this be a different branch?
    Will this replace the bitbucket repository?
    Anyone know something more?
  12. I'm a MEGA Super Moderator Baldrick's Avatar
    Any good mirror download site with latest x265 executables?
  13. Originally Posted by Baldrick View Post
    There are some listed in this post:
    https://forum.videohelp.com/threads/357754-%5BHEVC%5D-x265-EXE-mingw-builds?p=2257098#post2257098
    I'm using LigH's ones because:
    He provides both x86 and x64 builds
    His builds are XP compatible
    They don't need fancy runtimes like MSVC2012.
    Aug 2013
    Central Germany
    But I don't build and upload daily — only when I notice very important changes or when there is a merge between "stable" and "default" branch.
    Jan 2014
    Kazakhstan
    Hi all,
    check with your system
    Hybrid_2014.04.04.1 ; parameters used: --preset veryslow --bitrate 1200 (x265 encoder version 0.9+68-8bit)
    It turns crumbly - I want to understand what a miss (converter/settings, encoder, decoder, evil eye)
    samply for analysis
  16. Banned
    Feb 2013
    Check the test encodes I did above
    Bit rate of 1184 for UHD content? A little low maybe?
    Jan 2014
    Kazakhstan
    DivX shows that not a little
  18. Banned
    Feb 2013
    I'll run a test encode in a second
    Jan 2014
    Kazakhstan
    If you normally get, then informed about your system and what encoder assembly used
    Та!
  20. Banned
    Feb 2013
    Done and it looks fine
    Hybrid: homepage
    Forum: public forum
    Regarding problems please read: needed infos
    Donate: via PayPal
    Added new job with id 17_00_00_6610
    Added new job with id 17_06_50_4110
     ->disabling qaac support since 'Apple Application Support' is not installed,...
    Finished initialization, finished after 1.12s
    Filtering input files,..
    Analysing 1 input files,...
    analyzing: TimeScapes-satellite dish (orig).mkv
     checking a/v ids in ffmpeg,...
      analyzing TimeScapes-satellite dish (orig).mkv
     grabbing audio ids for: I:\TimeScapes-satellite dish (orig).mkv
     -> audio ids found: 0
     analyzing audio streams...
      analyzing audio stream: 0
       analyzing audio stream with mplayer
       grabbing audio data and delay infos with MediaInfo for I:\TimeScapes-satellite dish (orig).mkv
     grabbing video ids for: TimeScapes-satellite dish (orig).mkv
      -> video ids found: 0
     analyzing video streams...
      analyzing video stream: 0
    starting auto routines for source number: 1
     -> finished auto routines for source number 1.
    Input is completely analysed,...
    Extracting attachments from I:\TimeScapes-satellite dish (orig).mkv to C:\Users\LUIS\AppData\Roaming\hybrid\fonts
    Creating jobs for 1 sources,...
     -> Creating jobs for source 1,...
     -> Generating calls for: W:\OUTPUT\TimeScapes-satellite dish (orig).mkv
    adding x265 calls for source: 1
    createJobs for W:\OUTPUT\TimeScapes-satellite dish (orig).mkv
     optimizing the subJobs
    Added new job with id 16_09_19_3410
    Created jobs for:
    Starting Main@16:09:24.915:
    "C:\PROGRA~1\Hybrid\x265.exe" --preset veryslow --input - --input-res 2560x1440 --fps 23.976 --frames 242 --bitrate 1200 --output "W:\TEMP\TimeScapes-satellite dish (orig)_16_09_19_3410_01.265"
    x265 [info]: HEVC encoder version 0.9+9-8273932bc5b7
    x265 [info]: build info [Windows][GCC 4.8.2][64 bit] 8bpp
    x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
    x265 [info]: Main profile, Level-5 (Main tier)
    x265 [info]: WPP streams / pool / frames         : 23 / 12 / 3
    x265 [info]: CU size                             : 64
    x265 [info]: Max RQT depth inter / intra         : 3 / 3
    x265 [info]: ME / range / subpel / merge         : star / 57 / 4 / 4
    x265 [info]: Keyframe min / max / scenecut       : 23 / 250 / 40
    x265 [info]: Lookahead / bframes / badapt        : 40 / 8 / 2
    x265 [info]: b-pyramid / weightp / weightb / refs: 1 / 1 / 0 / 5
    x265 [info]: Rate Control / AQ-Strength / CUTree : ABR-1200 kbps / 1.0 / 1
    x265 [info]: tools: rect amp rd=6 lft sao-lcu sign-hide
    encoded 240 frames in 292.36s (0.82 fps), 1196.71 kb/s
    x265 [info]: frame I: 1      Avg QP:34.25  kb/s: 13242.04
    x265 [info]: frame P: 62     Avg QP:34.05  kb/s: 2559.71
    x265 [info]: frame B: 177    Avg QP:36.45  kb/s: 651.22
    x265 [info]: global : 240    Avg QP:35.82  kb/s: 1196.71
    x265 [info]: Weighted P-Frames: Y:8.1% UV:8.1%
    x265 [info]: consecutive B-frames: 3.2% 11.1% 31.7% 25.4% 14.3% 12.7% 1.6% 0.0% 0.0%
    finished after 00:04:52.939
    Created W:\TEMP\TimeScapes-satellite dish (orig)_16_09_19_3410_01.265 (1.429 MB)
    Starting Main@16:14:17.870:
    "C:\PROGRA~1\Hybrid\mkvmerge.exe" --ui-language en -o "W:\OUTPUT\TimeScapes-satellite dish (orig).mkv" --engage no_cue_duration --engage no_cue_relative_position --global-tags "W:\TEMP\TimeScapes-satellite dish (orig)_16_09_19_3410__02.xml" -d 0 --default-track 0:yes --default-duration 0:24000/1001fps --aspect-ratio-factor 0:1/1 --no-chapters --compression -1:none --forced-track 0:yes --no-audio --no-subtitles "W:\TEMP\TimeScapes-satellite dish (orig)_16_09_19_3410_01.265"
    finished after 00:00:00.117
    Created W:\OUTPUT\TimeScapes-satellite dish (orig).mkv (1.43594 MB)
    finishedJob: 16_09_19_3410
    Job 16_09_19_3410 finished!
  21. Banned
    Feb 2013
    Та!
    I just had a look at your x265 encode and it appears to be fine
  22. Member
    Jan 2014
    Kazakhstan
    And now this version
  23. Member
    Jan 2014
    Kazakhstan
    What the result is a file from the build x265-09.68 (version of Hybrid do you use?)
  24. Banned
    Feb 2013
    The x265 you rar'd gives lousy results at 1200
    I use the latest hybrid with the x265 that comes with it, 0.9+9-8277xxxx
  25. Hybrid fully functional 8 and 10 bits (HEVC encoder version 0.9+68-78c1f43f12f57ba6)
    Hybrid 10bits.04.04.14v1_17_59_50_6010_10.265"
    x265 [info]: HEVC encoder version 0.9+68-78c1f43f12f57ba6
    x265 [info]: build info [Windows][GCC 4.8.2][64 bit] 16bpp
    x265 [info]: Compiling by snayper [x265.ru]
    x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.1 Cache64
    x265 [info]: WPP streams / pool / frames : 17 / 4 / 2
    x265 [info]: Main10 profile, Level-4 (Main tier)
    x265 [info]: Internal bit depth : 10
    x265 [info]: Max RQT depth inter / intra : 1 / 1
    x265 [info]: ME / range / subpel / merge : umh / 60 / 4 / 2
    x265 [info]: Keyframe min / max / scenecut : 1 / 250 / 40
    x265 [info]: Cb/Cr QP Offset : 3 / 3
    x265 [info]: Lookahead / bframes / badapt : 15 / 4 / 1
    x265 [info]: b-pyramid / weightp / weightb / refs: 1 / 1 / 0 / 1
    x265 [info]: Rate Control / AQ-Strength / CUTree : CRF-28.0 / 1.0 / 1
    x265 [info]: tools: cfm esd rd=3 lft sao-lcu sign-hide
    encoded 179 frames in 106.22s (1.69 fps), 1318.06 kb/s, SSIM Mean Y: 0.9860045 (18.540 dB)
    x265 [info]: frame I: 3 Avg QP:24.92 kb/s: 3837.18 SSIM Mean: 0.992583 (21.298dB)
    x265 [info]: frame P: 97 Avg QP:28.33 kb/s: 1917.52 SSIM Mean: 0.985924 (18.515dB)
    x265 [info]: frame B: 79 Avg QP:30.81 kb/s: 486.35 SSIM Mean: 0.985854 (18.494dB)
    x265 [info]: global : 179 Avg QP:29.37 kb/s: 1318.06 SSIM Mean: 0.986005 (18.540dB)
    x265 [info]: Weighted P-Frames: Y:17.5% UV:16.5%
    x265 [info]: consecutive B-frames: 21.0% 79.0% 0.0% 0.0% 0.0%
    finished after 00:01:46.628
  26. Member
    Jan 2014
    Kazakhstan
    Degradation? ... Then developer should look at what is wrong with him
  27. Originally Posted by Gravitator View Post
    Friend, simply replace the files x265_0.9 _x64_8bpp +68 (x265.exe) and x265_0.9 _x64_16bpp +68 (x265-16bit.exe) and restart the Hybrid is ready or use the files on x32 if your system is Win32.
  28. Member
    Jan 2014
    Kazakhstan
    I very slowly turns to track the changes (old computer)
    "C:\PROGRA~1\Hybrid\x265.exe" --preset veryslow --input - --input-res 2560x1440 --fps 23.976 --frames 242 --bitrate 1200 --colormatrix bt470bg
    x265 [info]: build info [Windows][ICC 1400][64 bit] 8bpp
    x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64
    x265 [info]: WPP streams / pool / frames : 23 / 2 / 1
    encoded 240 frames in 5272.58s (0.05 fps), 1201.56 kb/s
    x265 [info]: frame I: 1 Avg QP:34.26 kb/s: 13232.26
    x265 [info]: frame P: 62 Avg QP:33.76 kb/s: 2561.16
    x265 [info]: frame B: 177 Avg QP:36.19 kb/s: 657.34
    x265 [info]: global : 240 Avg QP:35.56 kb/s: 1201.56
    finished after 01:27:57.716
  29. [QUOTE=Gravitator;2316696]I very slowly turns to track the changes (old computer)
  30. Member
    Jan 2014
    Kazakhstan
    I choose here this
