Dear users,
I want to stream a video capture device on network using MPEG-2 format. I'm able to record, save and play MPEG-2 videos using DirectShow but I have no idea about network streams.
I want you to name filters I should use for this.
Thank you very much
Best wishes...
Results 1 to 9 of 9
a. I know that ffmpeg and vlc can be used to stream from a DirectShowSource over a network,
b. if you google for "DirectShow rtmp filter" you will find multiple commercial solutions (DirectShowFilters/-Frameworks)
since you mentioned that you have 'no idea about network streams' testing the trial and later buying a commercial solution might be the easiest way. -
Dear Selur,
I don't want to use other application like VLC. I should implement on my own.
Aha, so what I need is RMTP filter. I've heard about RMTP which is a stream protocol and I think some live internet TVs use this protocol which even Windows Media Player is able to play it. Thank you.
Why did you mention commercial filters? Is it means that there isn't free filters for MPEG-2 stream?
Thank you
Best wishes -
Only free solution I know of would be to encapsulate the content into asf and the use the WMASFWriter/Reader interface which uses http iirc. (see: http://social.msdn.microsoft.com/Forums/windowsdesktop/en-US/f28de003-abe6-4949-8a3f-6...howdevelopment and http://www.codeproject.com/Articles/80413/Streaming-Server-using-Direct-Show-and-Windows-Med).
Haven't heard of any free streaming api which uses DirectShow Filters.
Cu Selur
Ps.: probably could also use Avisynth with Directshowsource and TCPServer, or write up some Client/Server stuff in C++ using the Qt framework. -
Googled a bit and found that there are free rtp Server/Client DirectShow filter: http://rtpstream.com/cgi-bin/mwf/board_show.pl?tid=8#tid8
I Salute you dear Selur
Thank you very much sir
Best wishes... -
Well, thanks to Selur; I'm gonna share what I did till now:
What I learned: RTMP stands for Real Time Messaging Protocol and uses TCP port 1935. There is other RTMP variants like RTMPS (with SSL) and RTMPT (encapsulated within HTTP) and etc.
There is a lot of commercial RTMP DirectShow filters. Unfortunately almost there is no free RTMP DirectShow filter. I downloaded this filters which Selur gave me but did not test them. I'll write down the result in this post; so other people can read and use my experiences about RTMP stuff.
Peace -
Well, I actually could stream and render MPEG Transport Streams using Elecard filters. Unfortunately I couldn't do it with free ones.
hacking about with broadcast video and meta data
By transcodeJux in forum Video ConversionReplies: 0Last Post: 31st Jan 2012, 12:05 -
Need help. I want to broadcast video on livestream
By zalzala in forum Video Streaming DownloadingReplies: 11Last Post: 26th Jan 2012, 11:36 -
HELP? - Need to record and broadcast digital video simultaneously.
By mpalm887 in forum Newbie / General discussionsReplies: 3Last Post: 11th May 2011, 06:39 -
Decoding MPEG-4 HE-AAc v2 audio in Stereo from DVB-T Broadcast
By tolinn in forum DVB / IPTVReplies: 0Last Post: 10th May 2010, 12:49 -
recording and broadcast live video
By George2 in forum Newbie / General discussionsReplies: 2Last Post: 1st Jul 2009, 11:57
