    Dec 2005
    Canada
    Selecting the cut/cuts on keyframes, it works ok I assume that's direct stream copy.
    Making non-keyframe cuts on the same source doesn't generate any output - no error message generated.
    In the pane above the log, there's a single line, "MKVExtractor at 100" - if that's significant.
    Here's the log in case anyone has any suggestions.
    MkvInfoAnalyszer call: mkvinfo.exe --ui-language en -s "C:\Users\Superuser\Desktop\sw.mkv"
    video track numer: 1
    video stream frame rate: 24.982
    Track 1: video, codec ID: V_MPEG4/ISO/AVC (h.264 profile: High @L2.1), mkvmerge/mkvextract track ID: 0, default duration: 40.029ms (24.982 frames/fields per second for a video track), language: und, pixel width: 480, pixel height: 360, display width: 480, display height: 360
    Track 2: audio, codec ID: A_AAC, mkvmerge/mkvextract track ID: 1, default duration: 23.220ms (43.066 frames/fields per second for a video track), language: und, sampling freq: 44100, channels: 2
    frame count: 31852
    MkvvInfo detected 31852 frames 240 of them are key frames
    video stream key frame count: 240, average distance: 132
    MediaInfo call: "C:\Users\Superuser\Desktop\MkvCutter_rev20131010\ MkvCutter\MediaInfo.exe" --Full "C:\Users\Superuser\Desktop\sw.mkv"
    video scan order: progressive
    profile@Level: High@L2.1
    cabac: 1
    cabac: 1
    reference frames: 4
    aspect ratio of input: 1
    frame rate mode: cfr
    audio format: AAC
    profile@Level: LC
    initializing the avisynth script environment,..
    Loading avisynth.dll
    loaded CreateScriptEnvironment definition from dll,..
    looking for avisynth version,..
    current avisynth version: AviSynth 2.60, build:Aug 28 2012 [18:17:07]
    Importing C:\Users\SUPERU~1\Desktop\sw.avs into environment,..
    grabbing clip infos,..
    checking colorspace,..
    current color space is Yv12
    invoking ConvertToRGB
    initializating the clip anew,..
    adjusting slider to frame count,..
    showing first frame,..
    set cut-start to: 4621
    collecting cut list and audio cuts,..
    current cut: 04621-10743
    -> time cut: 00:03:04.973-00:07:10.029
    B1: adding startCut to cuts: 4618 4621-4867 4868
    B2: adding middleCut to cuts: 4868 4868-10739 10740
    B4: adding endCut to cuts: 10740 10740-10743 10803
    -> calculated audio length: 00:04:05.055, in seconds: 245.056
    -> calculated video length: 00:04:05.056, in seconds: 245.056
    building trim and video parts,...
    adding(4) sw_cut_001.mkv <> Trim(3,length=246) for 4621-4867
    adding(6) sw_cut_002.mkv <> KEEP for 4868-10739
    adding(2) sw_cut_003.mkv <> Trim(0,length=3) for 10740-10743
    New temp folder: C:\Users\Superuser\Desktop\temp
    mkvParts count: 3
    Calling video cutter,..
    m_mkvVideoParts:
    4618-4868
    4868-10740
    10740-10803
    Saving options:
    -o
    C:\\Users\\Superuser\\Desktop\\temp\\1.mkv
    --split
    parts-frames:4618-4868,4868-10740,10740-10803
    --no-audio
    --no-subtitles
    --no-buttons
    --no-track-tags
    --no-chapters
    --no-attachments
    --no-global-tags
    C:\\Users\\Superuser\\Desktop\\sw.mkv
    to: C:\Users\Superuser\Desktop\temp\1_mkvOptions.txt
    Saved C:\Users\Superuser\Desktop\temp\1_mkvOptions.txt.
    Video split call: "C:\Users\Superuser\Desktop\MkvCutter_rev20131010\ MkvCutter\mkvmerge.exe" @"C:\Users\SUPERU~1\Desktop\temp\1_MKVO~1.TXT"
    -> new temp file: C:\Users\Superuser\Desktop\temp\1-001.mkv
    -> new temp file: C:\Users\Superuser\Desktop\temp\1-002.mkv
    -> new temp file: C:\Users\Superuser\Desktop\temp\1-003.mkv
    deleted C:\Users\Superuser\Desktop\temp\1_mkvOptions.txt
    video splitter created the following files:
    1: C:\Users\Superuser\Desktop\temp\1-001.mkv
    2: C:\Users\Superuser\Desktop\temp\1-002.mkv
    3: C:\Users\Superuser\Desktop\temp\1-003.mkv
    mkvSplit finished,..
    handling split files,...
    trim value for sw_cut_001.mkv: Trim(3,length=246)
    createAvisynthSkript(C:\Users\Superuser\Desktop\te mp\1-001.mkv, Trim(3,length=246))
    Avisynth file name: C:\Users\Superuser\Desktop\temp\1-001.avs
    Saved avisynth script:
    LoadPlugin("C:\Users\Superuser\Desktop\MkvCutter_r ev20131010\MkvCutter\LSMASHSource.dll")
    LWLibavVideoSource("C:\Users\Superuser\Desktop\tem p\1-001.mkv", cache=false)
    Trim(3,length=246)
    to: C:\Users\Superuser\Desktop\temp\1-001.avs
    trim value for sw_cut_002.mkv: KEEP
    adding C:\Users\Superuser\Desktop\temp\1-002.mkv to be reencoded
    trim value for sw_cut_003.mkv: Trim(0,length=3)
    createAvisynthSkript(C:\Users\Superuser\Desktop\te mp\1-003.mkv, Trim(0,length=3))
    Avisynth file name: C:\Users\Superuser\Desktop\temp\1-003.avs
    LWLibavVideoSource("C:\Users\Superuser\Desktop\tem p\1-003.mkv", cache=false)
    Trim(0,length=3)
    to: C:\Users\Superuser\Desktop\temp\1-003.avs
    Mkv extractor call: "C:\Users\Superuser\Desktop\MkvCutter_rev20131010\ MkvCutter\mkvextract.exe" tracks "C:\Users\Superuser\Desktop\temp\1-002.mkv" 0:"C:\Users\Superuser\Desktop\temp\1-002.264"
    mkvExtract finished,..
    Analyzing C:\Users\Superuser\Desktop\temp\1-002.264 with h264_parse,..
    h264 call: "C:\Users\Superuser\Desktop\MkvCutter_rev20131010\ MkvCutter\h264_parse.exe" "C:\Users\Superuser\Desktop\temp\1-002.264"
    reference frames: 4
    b-frames: 2
    weigthed p-frames: 1
    weigthed b-frames: 2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    qpMin: -3
    chroma offset: -2
    h264_parse finished analysing the input,..
    creating x264 reencode call for: C:\Users\Superuser\Desktop\temp\1-001.avs
    -> x264 call: "C:\Users\Superuser\Desktop\MkvCutter_rev20131010\ MkvCutter\x264.exe" --profile main --level C --cabac --ref 3 --deblock 0:0 --partitions i4x4,i8x8,p8x8,b8x8 --me hex --subme 7 --psy-rd 1.00:0.00 --merange 16 --trellis 1 --8x8dct --deadzone-inter 21 --deadzone-intra 11 --qblur -2 --bframes 3 --b-pyramid strict --b-adapt 1 --b-bias 0 --direct spatial --weightp 2 --keyint 250 --min-keyint 24 --scenecut 40 --rc-lookahead 40 --qcomp 0.60 --qpmin 0 --qpmax 69 --qpstep 4 --ipratio 1.40 --aq-mode 1 --aq-strength 1.00 --non-deterministic --thread-input --crf 19 --demuxer avs --fps 2498200/100000 -o "C:\Users\Superuser\Desktop\temp\1-001_reencode.264" "C:\Users\Superuser\Desktop\temp\1-001.avs"
    creating x264 reencode call for: C:\Users\Superuser\Desktop\temp\1-003.avs
    -> x264 call: "C:\Users\Superuser\Desktop\MkvCutter_rev20131010\ MkvCutter\x264.exe" --profile main --level C --cabac --ref 3 --deblock 0:0 --partitions i4x4,i8x8,p8x8,b8x8 --me hex --subme 7 --psy-rd 1.00:0.00 --merange 16 --trellis 1 --8x8dct --deadzone-inter 21 --deadzone-intra 11 --qblur -2 --bframes 3 --b-pyramid strict --b-adapt 1 --b-bias 0 --direct spatial --weightp 2 --keyint 250 --min-keyint 24 --scenecut 40 --rc-lookahead 40 --qcomp 0.60 --qpmin 0 --qpmax 69 --qpstep 4 --ipratio 1.40 --aq-mode 1 --aq-strength 1.00 --non-deterministic --thread-input --crf 19 --demuxer avs --fps 2498200/100000 -o "C:\Users\Superuser\Desktop\temp\1-003_reencode.264" "C:\Users\Superuser\Desktop\temp\1-003.avs"
    encoding next file,...
  2. if you can upload a clip and a cutlist (somewhere and send me a pm) which fails to produce an output I can look into it.
    Dec 2005
    Canada
    PM sent.
  4. answered btw. I get email notifications for PMs so you don't have to post that you send me a PM
    Update: problem got fixed and a new version was up uploaded
