Have a JVC Pro HD camera, I am using a different brand 32 gig sd #10 sd cards, keep getting card error messages, camera stops recording and says the camera is trying to recover images on the card. It happens in both the A and B slots with different brands of cards. The camera is almost 3 years old and gets a lot of use all in the studio. We use it to capture seminars so it is on for 8 to 9 hours a day for 150 to 200 days a year. The cards are also that old but some of them are brand new, been having the same problem with both. Seems like a camera problem. Can the connections be bad in the camera? any help greatly appreciated.
Might be electronic, might be mechanical, might be heat, might be any combination of the three.
This may sound glib, but if your camera's less than $2,000 replace it. If it's more, time to have it serviced by a professional. After three years of hard duty it deserves a checkup.
It's also a good idea to reformat your SD cards every now and then in something other than the camera (maybe you do) but that doesn't really seem to be the problem. -
This is a problem associated, not only with camcorders, but any very heavily used SD and mini-SD card reader. Dirt and oxidation has accumulated with the reader contacts and need to be cleaned out. To compound it, these contacts have lost their springiness and do not exert as much pressure as they did on the SD card when they were new, making connectivity hit and miss. Often, opening the thing up and gently prying/bending the contact vanes so that they exert more pressure is the way to go. It's not impossible with that camcorder but it's infinitely more complicated than a stand alone SD card reader or even a smart phone so unless you're an adventurous dyed-in-the-wool techie or you do this for a living, hard to recommend doing that.
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
JVC GC-PX100 camcorder
By VirtualDoobMon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 3rd Feb 2015, 16:47 -
Utility for JVC Everio Camcorder
By masfia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 6th Sep 2010, 04:53 -
Tracking problem with JVC camcorder.
By The-Geek in forum Newbie / General discussionsReplies: 0Last Post: 28th Aug 2010, 11:23 -
JVC mini dv camcorder
By biancoape in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 14th Feb 2010, 08:14 -
Camcorder JVC used as webcam
By wrummmmm in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 11th Jul 2009, 06:56
