Hy,I want to make 3000 videos, they are more likely slideshows and most parts, effects would be iterative.
My video would be so:
Starting image with a text (the name of the product) - FADE (+background change) - product picture 1 - SLIDE IN/OUT - picture 2 - ... - ... - FADE - Ending image (always the same).
I was thinking, we could make directories with the images in it and a txt with the product name. And a batch action could be reading the txt and the images and rendering every video in every directory.
Could it be made in some way? Is there a solution for this?
Thank you forwards for your answer!
BR
You must program a special application or a complex batch process for this.
If you are familiar with linux command line software can you check http://dvd-slideshow.sourceforge.net/wiki/Main_Page
Maybe the dvd slideshowgui creator could help with some batch feature https://forum.videohelp.com/threads/188464-DVD-slideshow-GUI-development-thread -
Unfortunately I don't use linux as an advanced user and I doesn't have time to learn and educate for this job.Could you maybe recommend someone who I could hire for this project? It would be a huge help.
After Effects rendering produce pixelated video...
By arminio in forum EditingReplies: 7Last Post: 10th Feb 2012, 10:44 -
rips don't produce playable video?
By idiotbox37 in forum Blu-ray RippingReplies: 1Last Post: 28th Jun 2011, 00:22 -
i need a software that can produce video with text message in it
By shimi in forum EditingReplies: 2Last Post: 27th Feb 2010, 00:42 -
How to produce a good Promotional Video...?
By Bansaw in forum Newbie / General discussionsReplies: 8Last Post: 19th Mar 2009, 15:38 -
Software needed to produce this video
By SusieQ in forum Newbie / General discussionsReplies: 3Last Post: 23rd Feb 2009, 18:02
