There's a guide for it in the links on the left. However, if the audio is screwed from the original avi, there isn't much you can do to it.
Hmm... my first post. Heh. Sounds like a problem with the audio conversion sampling rate. Change it so that the everything in the audio/converions menu match your rip/capture and run it through again. Lol, chickmunks... thought the same thing when it happened to meeh. Hope this works for ya.
clink -
Shidoken,
Using VirtualDub, you may want to extract the wav file only. This should give you an uncompressed audio file. Hope this helps.
Regards,
The Daywalker -
Hmm... I see. I'm trying to do all this from the divx version. I'll try the virtual dub thing and see if it works.
try this link and download AVI2VCD
http://www.mnsi.net/~jschlic1/
if i remeber correctly, it will extract a file that will decmpress the audio from the divx.
-mark
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 07:21 -
DivX audio Q
By Tafflad in forum Newbie / General discussionsReplies: 7Last Post: 25th Jul 2011, 12:13 -
No audio on divx file
By didikai in forum AudioReplies: 5Last Post: 30th May 2010, 09:33 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 23rd Feb 2008, 23:35 -
no audio on some divx files
By philquad in forum AudioReplies: 6Last Post: 1st Dec 2007, 23:16
