Did any one manage to compile x265 (from multicoreware) for Mac OS X?
I tried to get it to compile, but didn't succeed.
(Background: I would like to add x265 to Hybrid on Mac; Windows&Linux already works, but without binaries,...)
Results 1 to 18 of 18
Probably you should join the x265 mailing list and start pestering Steve Borho
I already get enough spam as it is and try to avoid any kind of mailing lists.
Then send him an e-mail, at least. That's what I did, before joining the mailing list.
AFAIK, Tom Vaughan is the only one who doesn't want Steve Borho to receive e-mails about the X265 Project
Before I do that I wait for some user to confirm if there really is a problem with building x265 on MacOS X, to be sure this is not me not getting if working,....
Added an entry to the issue tracker over at bitbucket, see: https://bitbucket.org/multicoreware/x265/issue/2/compiling-on-mac-1068-using-xcode-doesnt
if you think that is funny look at the ffmpeg issue I'm fighting atm., since the want uncut/unshortened output the ticked looks like hell,...
btw. bitbucket has the worst formating in tickets I have seen for quite some time,...Last edited by Selur; 6th Nov 2013 at 09:45.
I don't think and I didn't say it's funny, I just tried to say you did the right thing ATM.
I built successfully x265 on Mac OS X Mavericks after installing cmake with
hg clone https://bitbucket.org/multicoreware/x265 cd x265/source cmake . make
houdini -
Thanks for the info!
Is compiled static? If so could you share the binary? I would like to test if it works on my Mac OS X 10.6.8 system. -
Apparently it builds static. Here is a link for the x265 binary:
http://dl.free.fr/npMynjkd3
houdini
otool -L ./x265
./x265:
/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1197.1.1)
/usr/lib/libc++.1.dylib (compatibility version 1.0.0, current version 120.0.0)
houdini
yup, that's why it aborts on older mac versions with: "Illegal instruction"/usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version 1197.1.1)
-> so no x265 for me (and Hybrid) until they fix the compiling issued on Snow Leopard. (my mac doesn't support newer versions) -
since the reporting to the bug tracker didn't get any response at all I posted to the mailing list:
https://mailman.videolan.org/pipermail/x265-devel/2013-November/002418.html
and from the looks of it compiling x265 only works on Mavericks and is broken for all other Mac OS X versions.
What about this, does it work?
cmake: gcc flag introspection to fix Mac OS X 10.6 build
https://bitbucket.org/multicoreware/x265/commits/38719294293fd409a35e37c4b75c061cef247816 -
So back at home, tested and .... I does work!
(now I just need a source for up-to-date mencoder/mplayer builds for mac, but that's another problem)
Thanks to Steve Borho and all others that helped fixing this!
Cu Selur
Mac OSX choppy MKV playing help
By gebthec in forum MacReplies: 8Last Post: 25th Sep 2011, 03:34 -
Looking for a specific application for Mac OSX
By iwiiiiiiiiii in forum MacReplies: 6Last Post: 13th Jan 2011, 17:05 -
Unprotected (homemade) BD-R to ANYTHING editable - Mac OSX
By NJboss in forum Blu-ray RippingReplies: 0Last Post: 6th Feb 2010, 13:46 -
Professional Video Converter to use on MAC OSX
By Wael in forum MacReplies: 3Last Post: 10th Nov 2009, 07:14 -
Install aegisub on Mac OSx
By Anicsi in forum MacReplies: 5Last Post: 11th Aug 2009, 08:26
